Question about Elmo Projectors ELMO TT02RX DIGITAL DOCUMENT CAMERA Digital Cameras (ELM1304)
The image projected from the Elmo and computer is shaky. The images from the tv and vcr are fine. When I touch the menu button it is not shaky either. Any ideas on how to get rid of the shaky image?
3 Suggested Answers
Marrie
  • 563 Answers
SOURCE: ELMO Projector image not working
Hi schmidtkm
All the sympoms mentioned above is that of a faulty Mainboard that will have to be either repaired or replaced.
Trust me on this one , I work on Projectors every single day of my life.
Posted on May 13, 2008
SOURCE: Elmo TT-02u, Random freezes
The problem is a set bad capacitor that must be replaced by the factory. The units are very critical on the exact amperage that the power supply delivers. We have hundreds of tto2 and a few have had this problem. Elmo is aware of the problem and your warranty should cover the problem.
Posted on Jan 06, 2009
Elmo projector
sounds like you did not setup image screen.
Start
control panel
display
change display settings
multiple displays --- extend displays
detect - will show 1 &2 on each screen
apply
Apr 23, 2013 | Printronix T4M Dt/Tt 4-Inch 203 Dpi Rfid...
I open image mate and the laptop says that no document camera is connected. I have changed the cords and laptop still does not read the camera. The elmo will still project an image on the projector so...
I had the same problem with a TT-12 model. Dave from ELMO provided the resolution:
1. unplug the usb cable from your PC
2. on the ELMO:
a. Press MENU > PREFERENCES > USB MODE
b. ensure that APPLICATION is selected
c. exit the MENU and reconnect the USB cable to your PC
Oct 09, 2012 | Elmo Projectors ELMO TT02RX DIGITAL...
Picture is shaking during live events
If its just live events, I'm going to assume its your cable/satellite provider. If you watch blu-ray, DVDs and it doesn't shake your TV is fine.
The first step is to determine whether it's the LCD display, the image or the video feed from your cable or satellite provider. Make sure all your connections are secure and not
To test the LCD display, open your menu options to see if that shakes. If it doesn't then it's not a hardware problem and your TV is fine.
If your menu does shake, unplug everything from the TV. You will need to test if you have possible inference from other devices. One by one plug your devices in and view the menu for it to start shaking. This is one possible solution to the shaky image.
Again, other possible solution is your cable or satellite providers feed is shaky. You need to call them and inform them of the issue. A replacement receiver could solve the issue.
Jan 07, 2011 | Televison & Video
I bouht an old Elmo but the lens seems to be missing. How does this projector project anyway What sort of lens system? Thanks to whoever answers
The TRV-35 series are not slide projectors in the normal sense. There isn't a projection lens to enable an image to be projected on a wall or cine screen. The unit is a digital convertor for producing an image via a TV or PC.
Aug 11, 2010 | Elmo Projectors TRV-35H Slide Projector
Oct 09, 2008 | Elmo Projectors TT-02U Camcorder
Projection lights
You need to take the Toshiba remote that came with the machine and go into a menu area that deals with convergence. Here's what the manual says:
This TV used 3 separate TV tubes, red, green, and blue. The R, G, and B images are pojected onto the screen wheree they converge to form a full-color picture. You can see a clear picture only when the three images converge correctly. Corvergence my drift over time, or if yo move the TV. I you can see clear images on your TV screen skip this procedure.
Make this adjustment only after the TV as been on for at least 30 minutes.
Press the TOUCH FOCUS (auto convergence) button on the front of the TV at the bottom.
The TV will enter into the convergence mode and adjust the converge automatically (that's what it says.)
TO ADJUST IT MANUALLY:
Press MENU, and the press < or > until the PICTURE menu appears.
Then press UP or DOWN to highlight CONVERGENCE.
Press < or > to display the Center Convergence menu
There's a lot more the book says, but, I can say from experience that you just go through the different sub areas of this menu and converge each color separately, and bingo, it's fixed.
Good luck.
Sep 06, 2008 | Toshiba 43H71 43" Rear Projection...
Hi schmidtkm
May 12, 2008 | Elmo Projectors EV-2000AF Multimedia...
Double image playing DVD's
check your picture in picture, sounds like your dvd imput is set for split screen, dvd on both sides
Apr 20, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Questions regarding the elmo trv-35h projector.
Wow! What a job. The solution depends non your patience, technical skill, and the amount of time you have. You can use a telecine transfer box or, what I do, projeect onto a white card and video tape from the image on that card. A white card works as well or not better than a transfer box, because there are no cheap mirrors to distort the image. Here are some techniques: Use a variable speed projector, set to 18 frames per second (fps) to reduce flicker. Project onto a dull white card from about 3 feet away. Set your camcorder up behind the projector on a tripod. Use MANUAL FOCUS. Set the shutter speed to 1/60 MANUALLY. Set the white balance MANUALLY to artificial light. Using the automatic features on a camcorder will give you an unstable picture as the camera tries to adjust. You can capture directly to DVD or VHS tape, or better yet, directly into your computer. If your camcorder has an S-VHS output ( a round 4-pin plug)  and your VCR or DVD recorder has an S-VHS input, use S-VHS for better color. Leave the room lights on while capturing. Zoom up on your image, set your white balance on the camcorder and begin the transfer. I do not use a regular movie screen because it is beaded and gives you an image broken into little dots. Experiment until you get the best results. Then write down all the settings and use that as your guide for future transfers. If you need to edit, you can edit on your PC using I-Movie or a similar program, or use assembly editing from one deck to another - VCR to DVD-R or VCR-VCR. Use the pause and record button to skip over parts you want to delete. If you use your computer you can add titles and music. You can also add music using your VCR or DVD recorder if you have the patience.
Mar 21, 2008 | Elmo Projectors TRV-35H Slide Projector
Panasonic PT-51HX41 rear projection tv showing shadow/double images.
Unplug the TV from the ac wall outlet for about 4 minutes then plug it back in and turn it on. If it still has a double image then tell me if it's affecting the menu screen from the TV (not the cable menu). And is the double image in red and blue?
C-Dog
Feb 18, 2008 | Sony KP-41T65 41" Rear Projection...
Elmo Projectors ELMO TT02RX DIGITAL DOCUMENT CAMERA Digital Cameras (ELM1304) Logo
114 people viewed this question
Top Elmo Projectors Cameras Experts
Steve
Are you an Elmo Projectors Camera Expert? Answer questions, earn points and help others
