Question about Whirlpool 24 in. DU850SW - Multiple Color Free-standing Dishwasher
My dishwasher is 10 years old and it is not cleaning draining all the way and leaks out soap . please help =) model #du800swkqo
  • 52 Answers
SOURCE: Whirlpool GU980SCGQO not draining and I'm expecting 27 dinner guests Sunday
Ok, there are a couple of things it could be. The pump motor could be stuck, which is the most likely. Remove the bottom panel and look underneath. Spin the impeller until it spins freely, then try to start the dishwasher. Make sure the door is open before you do this, so that the impeller doesn't run while your hand is in it =)
Also, check the drain hose for a check valve. Sometimes these get stuck in the wrong position and it won't drain well. If none of these work, let me know and I'll help you further.
Posted on Apr 17, 2008
reg501
  • 413 Answers
SOURCE: Dirty dishwasher problems
Could be a a couple different issues.. Not filling with enough water or food chopper broke or food chopper filter screen clogged.
Check water level:
Run the DW and wait for the main wash to start (water will fill. pause then complete fill) The water should be no more than 1/4 inch below the heating element. If not there..replace water inlet valve.
Inspect food chopper:
Remove lower spray arm and rear water supply tube to upper spray arm. Remove torx screws that secure the sump cover. Remove the rounded cover on the left side to expose the chopper assembly. Inspect for breakage of blockage. There may be an additional plastic screen to remove first.
If I can assist you further, please let me know
reg501
The FixYa Team
Posted on Jun 22, 2008
heatman101
  • 43501 Answers
SOURCE: dishwasher is not cleaning dishes
I have an older dishwasher also and recently my wife also complained about it not cleaning right... so me being the man I am tried in vain to clean the things... Bought new spray arms online and installed them in minutes...now the thing works like new... However I have also found that if the heating element goes bad then that also can mess things up bad... So I would buy new spray arms, and also check out the heating element to make sure it is working... Here is a tip that will help you with the online buying...
Dishwasher Spray Arms not Spinning
How to Buy Appliance Parts Online
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The Heating Element not Working
Dishwasher Maintenance
heatman101
k
Posted on Sep 29, 2010
heatman101
  • 43501 Answers
SOURCE: 10 year old whirlpool dishwasher model DU810DWGQ1
Here is a tip that I wrote that will help you with your dishwasher not drainingproblem...
Dishwasher Problems - Water will not drain out
heatman101
Posted on Oct 07, 2010
heatman101
  • 43501 Answers
SOURCE: Periodically, my Whirlpool Gold Dishwasher does
Here is a tip that I wrote that will help you with your dishwasher not draining problem...
heatman101
Posted on Feb 22, 2011
10 year old whirlpool dishwasher model DU810DWOO1 does not completely drain. Leaves about an inch of water in the bottom all the time. The dishes do not get very clean.
heatman101
Oct 07, 2010 | Dishwashers
Dishwasher detergent door won't release soap
There are three common problems that cause the Soap Dispenser or Cup not toopen. I have a tip that will explain these problems in detail....
Dishwasher Repair Problem Detergent Cup does not Open
heatman101
l
Apr 06, 2009 | Hotpoint 24 in. FDW60 Free-standing...
Not all of the soap dissolving, some left in dispenser and bottom
Kitchenaid lists 130 dishwashers with this model. Need the rest of the number
KUDSO1DLxxxx
Back in the day, when I worked on K Dishwashers, the drain valve was the problem typically.
It would get a piece of glass, from broken glass or other item, or a toothpick, whatever stuck in the drain valve. It would not completely close. During the wash cycle, water would be trickling down the drain and by the time the soap dispenser opens, the water would be gone or nearly gone.
Check this. When you hear the dispenser snap open, stop the dishwasher and open the door.
If you have little or no water, you are losing the water during the wash cycle.
Let me know.
Gary
Nov 22, 2008 | KitchenAid 24 in. KUDS01FLBL Built-in...
Dishwasher Leaking
Hello jferguson29.
Welcome to fixya.
You said, water splashing over tub into door panel. It leaks with or without being loaded with dishes.
You checked the lower wash arm but found no visible cracks or breaks. The leaking water is clear not soapy.
What is the brand and model number?
And how old is it???
There are a couple reasons water may be leaking out the door of a dishwasher.
1. The water is most likely coming out the bottom of the door where there is no rubber seal.
2. The rubber seal is around the door jam on top and both sides and not on the bottom. This means if the dishwasher has to much detergent in it the soap suds push only the water higher than the front edge of the wash basin and out the bottom of the door where there is no seal!
3. Fill only the soap cup that can close for the secondary wash. The open cup is a pre-wash and mostly not needed unless the food is baked on.This just wastes money to fill both of them every time.
4. And if you are using liquid detergent you only need half the amount from the powdered soap!
try less soap. Remember to much soap too can cause the water overflow.
5. And the last would be that the drain is clogged and caused a back up large or small and then the overflow!
is there water in the bottom when the wash is done?
Soap is usually the culprit, not that there can't be a leak in an old drain or water supply hose!
Go with the soap idea first!
Let me know how you are!
How old is the washer ?
Please remember to leave a rating before you go!
Thank You ,Huuum
**************************************************************************8
Here is an interesting report I just read!!!!!!!!!!
Repair or replace?
When to pull the plug on your old washer
Typically, you'll also find a troubleshooting section for more-serious problems
in the owner's manual.
Should you pay for a repair or buy a new model?
The answer depends mostly on the age of your washer,
how much you bought it for,and the cost of the repair.
Follow these guidelines:
When a repair makes sense.
If your washer is under warranty or less than four years old ,
paying for a repair makes sense.
Note that washers under warranty might require service from a factory-authorized technician;
readers have found them on a par with independent repairers.
When a repair might be a wise choice.
If your washer is out of warranty and is four to seven years old,
it might make sense to pay for a repair. Customers generally pay $100 to $200 for a repair.
But you might want to buy a new model even at this stage,
given that today's models have added features.
Higher energy efficiency is another plus: Energy Star-qualified models made after April 28, 2008,
are 43 percent more efficient than conventional models built before 2001 and 56 percent
more efficient than those built before 1993.
When it pays to replace.
The repair costs more than half the price of a comparable new washer.
Data also shows that it doesn't pay to fix a less-expensive washer
eight or more years old.
Thanks to better recycling programs, less than 10 percent
of washers you replace are likely to end up in a landfill.
Thanks for giving me the opportunity to help!
Please do not forget to give a rating before you sign off!
Oct 03, 2008 | Dishwashers
FRIGIDAIRE DISHWASHER FDB1050REC0 LEAKS UNDERNEATH
Thank You ,Huuum
Sep 27, 2008 | Frigidaire 24 in. FDB1050REC Stainless...
Whirlpool 24 in. DU850SW - Multiple Color Free-standing Dishwasher Logo
62 people viewed this question
Top Whirlpool Dishwashers Experts
Mike
Owen Barnes
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
