Question about Sport & Outdoor - Others
What are the steps involved in closing an above ground pool with 25000l of water?
  • 666 Answers
You will want to drain a good portion of the water up to a third if you have any algae or scum in the pool you will want to shock and add anti algae to the water that is left turn off the filter and cover the pool
Robb
Posted on Nov 07, 2010
Above ground pool leak
Is this an above ground pool or an in ground pool? As a general rule you don't want vinyl to go too long without water. Water helps things stay in place. If the vinyl starts to shrink and bow inward there is a good chance that it will lose its elasticity and split when the pool is being refilled. I would advise you to go ahead and refill the pool. Leaks can be repaired underwater. In the event of a split I'd go back to the installer and pursue a new liner at his expense.
Jan 28, 2013 | Pool & Spa
WHAT AND HOW DO YOU VACUUM INTEX ABOVE GROUND SALT WATER POOL
I used the manual vacuum that came with the pool during the summer because I actually got in the pool and vacuumed), but ultimately, now that it is cold, I went to the pool store and bought a much bigger vacuum (that still hooks up to the water hose) and then a longer pole. It's just too darn cold to get in the water during the winter. :-) Hope this helps!
Nov 02, 2012 | Intex Automatic Salt Water System for ...
Where do i add salt to my intex automatic salt water system
Ad salt right in the pool water. Filter and brush around to disolve. Do not try to generate chlorine for 12 hours or so.
Make sure your salt content is as close to 3000ppm as possible
Jun 16, 2011 | Intex Automatic Salt Water System for ...
We have had a lot of rain and had to let water out of our above ground pool do we need to add more salt to the pool
It is quite possible that you do
It seems every one on here doesn't realize that they need to have the salt water test kit that reads #;s not color
If you were to close to minimum then you will need more salt
What you need to do is get the strips and test
you need to be as close to 3000ppm as possible
lower than 2800ppm and you will not be generating enough chlorine
any higher than 3500ppm and you could get cloudy,taste bad, and trigger an alarm for high salt
Bottom line is you can not guess at the salt content!
Jul 16, 2010 | Intex Automatic Salt Water System for ...
Pool size
YES IT WILL WORK WITH ANY SIZE POOL
Jun 18, 2010 | Intex Automatic Salt Water System for ...
I am starting an above the ground pool with a salt water system
25 pounds per 1,000 gallons or 3 kg per 1,000 liters of water.
Jun 02, 2010 | Intex Automatic Salt Water System for ...
Would like to know how to close a salt water pool for winter
There is nothing special about closing a pool based on using a salt water generator system. You can use any chlorine based chemicals for your winter dosing and you drain the lines, including the generating cell, just as you always would.
Oct 09, 2009 | Intex Automatic Salt Water System for ...
Sport & Outdoor - Others Logo
15 people viewed this question
Top Sport & Outdoor - Others Experts
Marvin
Marvin
John Tinnemeyer
Are you a Sport and Outdoor - Other Expert? Answer questions, earn points and help others
