Question about Bose Companion 3 Computer Speakers
My bose companion 3 has unbalance sound between left & right. the left one (the red one) is very good, but the right one the sound is very low. need help...
SOURCE: Bose 3 Companion Voltage
Hello people, I have a problem and was hoping you could help me with it.
I have bose companion 3 speakers and not thinking i plugged them into 220 input instead of 110. They don't seem to work anymore. I am trying to open them up to see if there is something i can do.
But it seems impossible to open them up. The screws on the back dont do anything... and there is one big golden cover underneath which i cannot open.
Does anyone knows how I can open or fix them up?
Thank you
Posted on Aug 01, 2008
SOURCE: bose companion speaker stopped working!?
What happened to you is probably mere coincidence with your cousin's use of the headphones and this is throwing you off. I own the Bose Companions also and they stopped working as well. However, I traced the problem to the "wall wart" power supply. Not sure why but Bose is now using an interchangable plug on them. If you look at the power supply you will see a "PUSH" button. If you depress it the plug can slide out. When it is slid back in and locked in place the connection between the plug plate and the power supply is not a good one. Try fiddling with it. But even if the connection is not the culprit, something in the power supply is. I swapped another power supply with the same connector and spec's ( amps must be the same ) from another item and the speakers worked perfectly.
Posted on Dec 14, 2008
  • 10 Answers
SOURCE: Where Can I purchase a bose companion 5 control pod?
you have to call customer service at 1-800-367-4008.Run about $35.
For the broken cable, have you tried to fabricate a new cable for it?
Posted on May 25, 2009
  • 9 Answers
SOURCE: can i connect my bose companion 5 to a lcd t.v
yes use an auxilliary
Posted on Jun 17, 2009
cjackHD
  • 71 Answers
SOURCE: Does the Bose companion 3 have an internal fuse?
Yes. The companion 3 system can be repaired for $75. Call Bose at 800-367-4008. They will also give you a new 1 year warranty.
Posted on Jun 21, 2009
I have a Bose sound system companion series 3 ii and the lights just yellow and no sounds coming out and it turned red and no sound was still coming out.It was working fine about half a an hour ago
the drivers might have been corrupted by something or you might have got a virus run your antivrus program and test for a virus then
you might have to uninstall then reinstall either the sound drivers or the sound card make sure you have both of these devices baked up to a disc before uninstalling
a yellow? question mark means you need to install/update driver right click to install driver
Dec 25, 2010 | Bose Companion 3 Computer Speakers
My Bose Companion 3 coputer speakers are 2 years
i hav the same problem but all three shut off ,and i have to shut off and turn on again
Jul 29, 2010 | Bose Companion 3 Computer Speakers
Speakers causing computer problems companion 5
Hi, I have these also & mine occasionally go to the red light while the PC is on.. Are they visible in the 'Sound' in control panel as Bose USB Audio' is this set to default? Is the USB kept in the same socket? & are they too close to other speakers?.. Let me know
Mark
May 04, 2010 | Bose Companion 5 Multimedia Speaker System...
Loud hum when Bose Companion 3 Series II speakers are turned on.
I had the same problem for many months. I asked a sound & video professional and he suggested I move the subwoofer away from any power source. I had the subwoofer next to my UPS. Once separated and moved all wiring away from the power supply (about 12") the low bass hum was practically gone.
Jun 28, 2009 | Bose Companion 3 Series II Multimedia...
Crackling sound
That sounds like an internal fault on your Bose system.
Leave the Bose unplugged from power and from computer for one hour, to get rid of electrostatic charges accumulated inside capacitors.
If that does not get rid of the problem, then there is an internal fault, either a short on speaker wiring, or a fault on the internal amp circuit board.
May 01, 2009 | Bose Companion 3 Computer Speakers
Bose Companion 3. Speakers are very faint in sound. The touch pad seem inoperable. (the green light on pad does not come on.)
Check first that you have connected the speaker to the right output. For example on many computer there is an aux output marked in blue that can give you this problem.
If the problem does not depend from the source, then that sounds like an internal fault on your Bose system.
Mar 05, 2009 | Bose Companion 3 Computer Speakers
Bose companion speaker stopped working!?
Try going to control panel, sound, then configure the system to the Bose. Hope that works.
Apr 05, 2008 | Bose Companion 3 Computer Speakers
Left speaker sometines has no sound? Please help
I bought a set of Bose companion 3 speakers and the darn RCA jacks are cheap and wiggling loose. The cost to send back and repair out of warranty is about $125!! BOSE companion speakers may sound good, but for my money, I'd rather go with more reliable computer speaker systems like Creative or Logitech. BOSE IS WAY TO OVER-RATED, but HEY....they suckered ME out of $275!!!
Feb 06, 2008 | Bose Companion III Computer Speakers
Bose Companion 3 Computer Speakers Logo
154 people viewed this question
Top Bose Audio Players & Recorders Experts
Invebo
Level 1 Expert
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
