Question about Maytag Washing Machines
I have a maytag bravo. mod # mvwb300wq1. when i try to start it on any cycle it just says "lid" and beeps and will not start. what should i do?
Anyone figure this issue out? Same problem
Posted on Nov 07, 2014
Did you get a solution? Having the same problem.
Posted on Sep 09, 2011
Hello, I have a Maytag Bravos MVWX550XW washer that will not rinse or spin, only wash. The drum moves. I replaced the washer inlet valve, did not fix the problem. Removed the lid switch assembly...
hi Melanie.
this is all i could find out.
If the water won't drain out of your washing machine, either something is stuck in the drain hose or pump, or the pump is broken. Both fixes are simple if you're even just a little bit handy with tools. We're showing the repair on a Maytag washing machine.
How to Drain Washing Machine That Won Drain Family Handyman
What is wrong with a washer that does not spin? If your washer fills with water but doesn't agitate, the problem is likely to be a faulty lid switch, a broken belt, or a problem with the motor. (Note: Direct-drive washing machines do not have belts.) To diagnose the problem, do the following: 1Check the washing machine's spin cycle
Washer Doesnt Agitate or Spin
Maytag Washing Machines will not rinse or spin Google Search
Dec 12, 2017 | Maytag Washing Machines
Maytag Bravos MVWB300WQ1. While sitting idle I heard a click and now the machine will not turn on plus it popped the circuit main circuit breaker.
The clicking sound may have been insulation / plastic in one of the electrical components cooling down after failure. The problem is more than likely the motor or lid switch. If you are capable, remove motor wires / plug, insulated same, plug into the power, turn on & see if it trips the circuit breaker. if it does not it is the motor, if it still trips check other electrical components.
Apr 20, 2014 | Maytag Bravos MTW6600T Top Load Washer
Lid lock broken can I overide?
Washer not starting Cycle:
I would have to slam the washer lid before the washer recognized the lid was shut.
What I did to fix:
1. Ref the link below for Schematics
http://blog.kennyluong.com/Tricking-A-Maytag-Bravos-Washer/
2. Looking at the Lid Lock section of the Schematic:
Place a jumper between pins 2 and 3 of J15
This engages the 1st switch (Lid Lock) so, I don't have to slam the lid anymore
3. Since my Lock switch (2nd switch), which is engaged with a magnetic, is working, my work is done.
If you find that your machine is still not starting the cycle, you will need to
replace the Lid Lock mechanism or ref the above link for temp bypass.
Mar 30, 2014 | Maytag Bravos Top Load Washer
Maytag bravos x lid lock overide or bypass
dpthom's wife is the smartest woman on earth! :)
Feb 11, 2013 | Maytag Bravos Top Load Washer
Lid lock button is flashing and wont unlock
I u unplugged the machine and it stopped blinking, the lid unlocked but when I tried starting it again the same thing happened. I cleaned the contacts on the lock but that did not help.
Jan 08, 2013 | Maytag Bravos MTW6600T Top Load Washer
Maytag Washer Lid lock light
Its normal for the machine to cycle the lock before starting its cycle. I'm assuming your machine is a bravos style.
May 30, 2012 | Maytag Washing Machines
Washing Machines Logo
204 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
