Question about Hisense LHD3204US 32 in. LCD HDTV
What is the width of this unit? I have a space of 30 3/8 inches. Will it fit?
    President:
  • 1,140 Answers
Yes, it will fit. Manufacturer quotes specification for this TV is 24.48 inches wide.
Regards,
BElectric
Posted on Nov 07, 2010
  • 2 more comments
  • DILLIGAF
    DILLIGAF Nov 07, 2010
    WAIT! I thought that dimension seemed to small for a 32" TV so I went back and checked some other sources. This TV actually measures 35 1/8 inches (892mm) so it wont fit. I'm sorry about the mistake but I was wrongly informed - by the Manufacturer's published data!
  • Tom Popdan Nov 07, 2010
    thanks very much for following up. I appreciate your help!
  • DILLIGAF
    No problem. Just wanted to add that you may find it difficult to get a 32" to fit in a 30 3/8 space. The screen width on a 32" is usually about 27.5 - 28 inches so you need one with a surround of not more more than approx 1 inch on each side.
    yes you are right, getting one to fit is not going to be easy. I found one so far, a Sony Bravia KDL32ex710 at 30.09 but the price tag is very steep. The closest Vizio I can find is an XVT323SV which is 30.99 and probably won't fit but the price is a little better. Thanks once again for the information.
What are the deminsions for a sealed box for a ten inch 1100 watt sony xplod xs-l101p5w?
The unit only requires .5 Cubic feet of volume for the enclosure. It would be best to figure out how much space you have to work with and then make a box to fit that space. If not measure the whole front of the speaker across the face. Allow 1/2 to one inch on either side. Lets say it is 12 inches. You need 14 to mount it easily, you can use less though. So you now know that your box has to be 14x14 length and width. Measure the distance from the magnet to the edge of the rim of the front. Lets say 5 inches, you now have 14x14x5. That comes to 980 cubic inches. To convert to feet you divide 980 by 1728 which is .56 cubic feet and that would be enough.. Measure (inside area, not the outside), make sure there is clearance for the magnet on the back so it is not touching the bottom of the box you need.
Dec 18, 2016 | Sony Car Audio & Video
What size should I get? Height 64 inches;32 inch width;26 inches deep.
The maximum size you get is determined by the space you have available after allowing for side and top ventilation which is critical to the functioning of the Refrig.
Allow at least 2-3 inches either side and 2-3 inches at the top if there are cupboards or shelving over the Refrig location.
measure out the maximum distance in depth you are happy with after allowing an inch or so clearance at the rear so you do not buy a unit that projects to far into the room space.
Then you can check manufacturer sizes and choose a frig brand that fits within that space you have measured out.
Nov 13, 2015 | Refrigerators
How to calculate cubic feet
About 46.8 to 50.7 cubic feet.
May 02, 2014 | Office Equipment & Supplies
How do you solve a rectangle is eight inches longer than its width. find the dimensions of the rectangle if the perimeter is 60 cm
The rectangle is 11cm by 19cm.
The perimeter is 60, so the width and length must add to 30. The length is 8 more than the width, or width+width+8=30. Solve that for width, then you can calculate the length based on the width.
If this is homework, be sure to show your work.
Oct 11, 2013 | Lands Phones
Exact Outside Width Of The Ge Jx2127sh Microwave Trim Kit. Does anyone know the exact total width of the GE JX2127SH Trim Kit? None of the GE sites list the outside width.  Extrapolating from the cutout...
I would go with it. The 1/8" on each side you are worried about can probably be trimmed if need be. The manufacturer is usually very precise on an measurements they publish.
Dave
Jul 04, 2017 | Microwave Ovens
How do i change a single 30 inch oven wall cabinet to a double
Measure the available cabinet space, height, width and depth. Shop out a unit that will fit or is close. The cabinet will probably need to be cut out and sometimes a drawer or doors may need to be eliminated. Check the amperage on the existing circuit at the electric panel to make sure it is sufficient to carry the new dbl oven. Every oven that I have installed coomes with a set of complete installation instructions
Nov 18, 2009 | Dishwashers
What are the measurement on kenmore airconditioner model #580.72056
INSTALLATION REQUIREMENTS
Your air conditioner will install into standard double
hung windows with actual clear opening widths of
22 to 36 inches (558mm to 914mm) (FIG. 1).
Lower sash must open sufficiently to allow a clear
vertical opening of 14 inches (356mm). Side louvers
and the rear of the air conditioner must have clear
air space to allow enough airflow through the
condenser for heat removal. The rear of the unit
must be outdoors, not inside a building or garage.
•_22" to 36" --
14"rain
Intedor wall
Sash
Winddow
"-_,_- Offset
-- Sill
-- Exterior
"" .... " FIG.
This came from sears.com
really is no dimensions for the unit itself just the opening that is needed for it to fit
Jun 21, 2009 | Kenmore 72056 Air Conditioner
Blade length problem
Hedge trimmers cut using either a single-action, where only the top blade oscillates, cutting against the stationary lower blade, or a double-action where a pair of double-sided toothed blades that slide back and forth at a high speed so you can sweep across hedges in both directions. The latter are more efficient. Blade length Consider the size of the hedge you will be cutting to get the right length blade. The longer the blade length, the more area it can cover and the quicker it will get the job done. However longer blades also require more power and larger heavier motors so weigh up blade size versus ease of use. Blade lengths range from 14 to 30 inches with long blades of 22 to 30 inches providing extended reach for taller or wider hedges. Blade width The blade width indicates the space between teeth and the maximum thickness the trimmer can cut through, eg. 20mm blade width will be able to cut through a maximum 20mm branch.
Aug 27, 2008 | Bond Manufacturing 6-pieceUltimate Pruning...
Installation Issues
Measure the actual case. If it is less than 20", then it will fit by removing the window kit side pieces, to leave the bare case. Make sure the unit is well supported & level.
Jun 13, 2007 | Frigidaire OPP 5 FAX052P7 Air Conditioner
Hisense LHD3204US 32 in. LCD HDTV Logo
111 people viewed this question
Top Hisense Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Hisense Televison and Video Expert? Answer questions, earn points and help others
