Question about HP COLOR LASERJET CP 3505 N PRINTER
How to change toners on 3505 printer - HP COLOR LASERJET CP 3505 N PRINTER
  • 28 Answers
Open the front door (above the HP logo, not below it) and you should see your toner cartridges. If you see only black ETB unit, pull it just like you pulled the door, sometimes it stays in that position. Now you should definitely see your cartridges.
Posted on Nov 07, 2010
2 Suggested Answers
  • 17 Answers
SOURCE: HP COLOR LASERJET CP 3505 N PRINTER: Magenta toner is light in color.tryed changing the...
Known problem with this machine the fan is located next to the magenta laser scanner at the base of the machine. this fan blows dust on to the scanner lenses and makes the prints light. Needs to be taken apart and cleaned. take it to a local service center if they know what they are doing should be less then an hour.
Posted on May 20, 2010
My HP3505 we just installed a ne black toner, now when we print it leaves a small line about 3 inches in from right side of paper every 1 inch. all the way down. Is this becasue or drum is dirty
hi
if you have not replaced the image drum (fuser) after three or four toner replacement changes, you will need to replace the fuser assembly to avoid unwanted lines and grainy or faded prints.
it is also a good idea to replace the rollers as well, if they have not been replaced either
RM1-2763-020CN fuser assembly worth about $200 with exchange of your old fuser
RM1-2727-000CN, worth about $10-$15
please send me 4 thumbs up
Aug 15, 2011 | HP COLOR LASERJET CP 3505 N PRINTER
50.2 code on a hp 3505
Hi:
A 50.2 error is a fuser error. This is the assembly that heats up and fusees the text to the paper. It is located at the top of the printer. The fuser is not warming up and is throwing this error. The fuser would have to be replaced.
Andrew
Aug 09, 2011 | HP COLOR LASERJET CP 3505 N PRINTER
My hp 3505dn printer prints a full page coat of black over the print job
Black toner cartridge failure, replace it for another (Q6470A) and try print.
Jul 22, 2011 | HP COLOR LASERJET CP 3505 N PRINTER
10.xx.xx errors all relate to supplies. If you recently replaced a toner cartridge then likely the chip on that cartridge is bad.
Jun 08, 2011 | HP COLOR LASERJET CP 3505 N PRINTER
My HP CP3505n is given me the message 10.92.03 cartriges not engaged. Because once we recieved the Black toner Cartridge one of my friends was trying to install it but he couldn't. So, he tried again by...
Your helpful friend may have only broken something on the toner.
Have them buy you a new toner, and see if that fixes the issue.
If not, take some pictures of the inside of the printer and we'll see what we can come up with as a fix....and you'll still have that extra toner your friend bought you as compensation for their genius.
Mar 15, 2011 | HP COLOR LASERJET CP 3505 N PRINTER
10.92.03 error showing while printer door closed.
One of the cartridges may not be seated correctly. Open the door and remove all the cartridges. Close the door and power the printer on. Then, replace each toner one at a time, closing the door in between each one. This should allow you to determine which toner is not seated correctly. Remove and reseat that cartridge. Clear any foreign debris from the area. You may have to replace that cartridge in the event it is defective.
Nov 11, 2010 | HP COLOR LASERJET CP 3505 N PRINTER
I have a yellow streak down the side of the pages how do I stop it?
You may have yellow toner building up inside the printer which is causing this issue. By having a maintenance cleaning done it should reslove the issue.
Jun 08, 2010 | HP COLOR LASERJET CP 3505 N PRINTER
May 18, 2010 | HP COLOR LASERJET CP 3505 N PRINTER
Color Laserjet 3505 13.20 service error
There is a set of sensor flags on the bottom of the paper input unit (paper feed assembly). You may be able to see them if you take out tray 2, remove the toner cartridges, and turn the printer on its back. One side of the rod can get stuck, it will make it look curved, it should be straight. "un-stick" the stuck side (typically the left side) so the flags can move freely.
Apr 03, 2009 | HP COLOR LASERJET CP 3505 N PRINTER
HP COLOR LASERJET CP 3505 N PRINTER Logo
89 people viewed this question
Clive
Clive
