Question about Mitsubishi WD-52525 52" Rear Projection HDTV
Mitsubishi HD Diamond series WS-55907
I have just bought this beautiful television from an older couple and have found out that I need to override the passcode for the television v-chip.
    New Friend:
If you forget your passcode, you can
view the locked TV without entering your
passcode. This is done by pressing the
number 9 and QV buttons on the remote
TV control at the same time, when your
passcode is requested. This process
temporarily unlocks the TV.
Posted on Feb 01, 2013
  • Kimberley Feb 01, 2013
    When entering the V-Chip Lock menu, this process deletes your old passcode and prompts you to enter a new passcode.
  • 927 Answers
Good day k g;
I think the code is oooo.
If not let me know and I will double check.
Good Luck, Big Irish.
Posted on Jun 21, 2008
MITSUBISHI WS55907 Diamond 1080 TV bought in 2000 was powered off, unplugged, for a year. Turned the set on with remote last night and worked fine, had very crisp picture.
Your TV was waiting between 2000 and now to suffer power supply failure. It is very frustrating to go from everything working perfectly to nothing.
Oct 31, 2016 | Mitsubishi WS-55907 55" Rear Projection...
Picture warped and distorted on Mitsubishi WS 55907
sounds like a convergence failure. Is it possible to post a picture? If not does the image appear as if its 3D?
Jul 12, 2009 | Mitsubishi WS-55908 55" Rear Projection...
HDTV Mitsubishi WS-55819 55 Inch Diamond Shield
You will need to contact a Mitsubishi Authorized repair facility. The entire electronics package must be removed and sent back in to Mitsubishi. The problem is the Formatter circuit board which is no longer available as a replacement part. The repair cost is very expensive and must be quoted by the facility you contact not me. Expect 4-6 weeks turnaround.
Nov 28, 2008 | Mitsubishi WS-55819 55" Rear Projection...
Mitsubishi HD Diamond 1080 WS-55907
with the tv on, with the original mits remote, punch in this sequence menu, 8,2,7,0 the should bring up the option menu. the first line should have "initial" highlighted. if it does press "enter" on the remote. in a second or two the tv should switch to ant a probably channel 3. power the tv off then back on. this action puts the tv back to customer defaults, in other words just like it was when it came out of the box. there should be no passwords required.
good luck
Jun 15, 2008 | Mitsubishi WD-52525 52" Rear Projection...
TV will not turn on.
Same problem and Just had repair man out. Said it was the signal board and that with this model it is a very common problem. Mitsubishi no longer makes the parts to fix it. If you want to scout online for one th product number for a signal board is 930b868003
May 27, 2008 | Mitsubishi WS-55907 55" Rear Projection...
Error code 22 on a Mitsubishi WS-55907 55'' HDTV
your set is the V17 series so a code 22 means short protect. Which means the TV has a short circuit condition and is shutting down to prevent further damage. You can get a manual for the V17 sereis at the following link for 15.99 and they will provide free unlimited support to help you with the diagnosis and locating parts. Your set is coverd in the V17 sereis service manual under the mitsubishi section. Here is the link in case youd like the service manual and free support.
http://servicemanuals.vstore.ca/
Mar 08, 2008 | Mitsubishi WS-55907 55" Rear Projection...
Double vision
convergence fail. try resoldering the 2 convergence ICs in the middle baord located on the large heatsink. this might fix unless the problem has gone it course
Feb 21, 2008 | Mitsubishi WS-55907 55" Rear Projection...
Mitsubishi WD-52525 52" Rear Projection HDTV Logo
83 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
