How much RAM should I put on my evga motherboard the Supermicro X8DTN+ Motherboard
  • 345 Answers
This depends on what windows you run and what kinda programs are you going to run. Like if you run lots of games you need more memory and if just doing like internet surfing or writing documents then less. 32 bit operating systems can see up to 4GB of memory and 64 bit Operating systems can see i believe up to 16GB or so. Windows vista and windows 7 need more that xp. For windows vista and 7 it is recommended to have at least 1GB for basic operations so i would recommend at least 2GB. The more the better for the feed back from the computer. More memory more programs you can run at once. Hope this helps.
Posted on Nov 07, 2010
Loud continuous beeping
There is nothing in the motherboard manual about a long continuous beep:
Supermicro Products Motherboards 4th Gen Core C7Z87 OCE
I would check to make sure none of the cables are backwards (ie the 16 pin is the likely culprit). Otherwise, I would attempt to boot using a single stick of RAM, check the CPU socket for bent pins, or check the warranty status and return the product for repair/replacement:
http://www.supermicro.com/support/rma/
Feb 09, 2014 | SuperMicro C7Z87-OCE Desktop Motherboard -...
X6dh8-g2+ no video continous beep
Hello here is the homepage:
http://www.supermicro.com/products/motherboard/xeon800/E7520/X6DH8-G2.cfm
Try to boot with only one stick of ram at the time, to find the failing ram module.
This is usually caused by a problem with the system memory, or possibly the video card. The memory is more likely--the system complains long and loud sound, if it can't find any usable memory, as there is no way to even start the boot process when this is the case. The motherboard itself could also be the problem.
The mainboard is useing Up to 16GB DDR2 RAM.
Try not to buy cheap ram, they are always failing.
Good luck
Feb 21, 2013 | SuperMicro Computers & Internet
8 gig of ram installed but win 8 pro 64 bit only see 4 gig, Win 7 Home Ultimate 64 bit had same result
Hello the homepage is here:
http://www.supermicro.com/products/motherboard/PD/955/PDSG4.cfm
Check for one of the modules is in place in the ram socket
and blow it out for dust with compressed air.
One of the modules could also have a defect.
The mainboard supports:
Up to 8GB dual channel unbuffered
ECC/non-ECC DDR2 667/533/400 MHz
Try also to upgrade the mainboard drivers with this tool:
http://www.intel.com/p/en_US/support/detect?iid=dc_iduu
Good luck
Oct 29, 2012 | SuperMicro PDSG4 Motherboard
When I power up everything seems to work but there's no display in the monitor and nothing on the POST-CODE LED, and no beeps. I tried to find the problem by unmounting all the pieces installed on the...
Dear pablo_you ,
This problem may cause because of many reasons.one of the main problem that cause due to the ram and the VGA controller.Please remove your both rams and put one by one if necessary please insert some spare ram and check.if both rams seems to be OK.please check by connecting directly to the VGA port.
Thanks
Jun 19, 2011 | Intel DP55KG Motherboard
When I try to boot my EVGA P55V micro mother board all it just goes beep beep beep, repeatedly I'm using a EVGA e-GeoForce 9600 GT card nothing apears on my screen it doesnt even look like its booting, the...
that beep (1 long and 2 short) indicated your ram has problem, from your suggestion i can know that your ram was died, change your ram with new one it will solve your problem
Feb 25, 2011 | Evga P55V 120LFE651TR LGA 1156 Intel P55...
Supermicro x6da8 won't post. Can't get into BIOS either.
disconnect all power connections to the board and take the battery out for a few minutes and then put it all back and see if you can acess the bios. If you still cant, try a bios flash and if that brings you no joy, board is done
Jun 27, 2009 | GE Supermicro X6DA8-G E7525 EM64T S604...
Unit doesn?t start unless we took all the memory cards (RAM) fro
reset bios setup to factory defaults.
Pull cmos cell for 15 minutesd then check .
Also check RAM frequency is not comflict with each other.
Jun 10, 2009 | SuperMicro X5DAE Motherboard
Computers & Internet Logo
19 people viewed this question
David Payne
David Payne
