Sony DVP-NS315 DVD Player Logo
Anonymous Posted on Nov 07, 2010
When I try to eject the DVD that is in the machine, it says LOCKED on the tV screen
  • Anonymous Nov 07, 2010
    No I figured it out myself!
Anonymous
Level 3:
  • Master 666 Answers
  • Posted on Nov 07, 2010
Anonymous
Master
Level 3:
Answers
666
Questions
0
Helped
149258
Points
1859
What you will want to do is go into the users guide and find the reset factory defaults option usually it involves holding a button or two while starting the device however are sometimes very different
hope this helps
Robb
1 Related Answer
Anonymous
  • 247 Answers
  • Posted on Dec 17, 2008
SOURCE: locked dvd on a panasonic tv/dvd/vhs combo
sometimes there is a button/switch that slides sideways and will lock the machine so buttons can't be pushed during transport. usually that switch/button is one of the power button/switches. otherwise call the manufacture for tech support here is the number:1-800-212-7262. hope this helps
tom
Refuses to eject says locked
You have the child lock turned on. See page 28 of this manual.
37helpful
5answers
2answers
Locked Tray DVP-SR320 Sony DVD Player
see this causes and fix it. God bless you
Possible causes:
  1. Worn, stretched, oily, flabby, belt.
  2. Dirty mechanism or gummed up lubrication.
  3. Stripped gear or other mechanical damage.
  4. Defective motor or bad connections to motor.
  5. Bad drawer/eject button.
  6. Missing/bad voltages from power supply.
  7. Defective microcontroller or other logic.
  8. Dealer antitheft lock enabled.
12helpful
2answers
DVD won't eject from Toshiba DVD player. I have already taken cover off and can manually engage the tray. When I try to eject with the remote I just get a little ''lock'' icon on my TV screen.
Press setup subtitle 3 audio 0 to unlock ...worked for me. Thank a user on Videohelp.com for solution:
http://www.videohelp.com/forum/archive/toshiba-sd-v295ku-locked-tray-solved-t362810.html
Locked dvd on a panasonic tv/dvd/vhs combo
tom
5helpful
Sony CD/DVD Player DVP-NS501P: It says LOCKED when I try to eject
What you have to do is unplug it and plug it back in it resets the dvd player
Pre-recorded dvd won't eject/entire system frozen
Try unplugging the machine so it will reset itself. Then plug it back in. That has worked for me in the past.
pjrsop
3helpful
2answers
Dvd is locked will not eject the dvd
dvd locked and will not eject on a panasonic triple play
39helpful
7answers
Locked dvd tray.
Press and Hold EJECT Button, While UNLOCK Is Displayed :-)
3helpful
Dvd not ejecting
I just found my solution. I pressed the power button on the remote and the stop button on the tv at the same time, and it unlocked the dvd eject.
Top Sony Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
ZJ Limited
ZJ Limited
matt martin
matt martin
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
