Question about Brother GX-6750 Typewriter
5 new ribbons, 2 different typewriters, same issue: Ribon will not advance,
  • Brother Master
  • 3,594 Answers
Go to brother.com, click on support, poke around there you will find a manual.
DickyO
Posted on Nov 12, 2010
Ribon will not type
it may have come loose from its post or something in the ribbon drive broke
Jul 05, 2014 | Brother ML-300 Typewriter
WP3400 & AX-12M
  1. Is the daisy wheel locked in the forward position?
    1. Pull the black lever back, away from the platen.
    2. Lift out the daisy wheel and inspect it for damage; replace the daisy wheel if it is damaged.
    3. Re-insert the daisy wheel and push the black lever towards the platen until it locks in place.
  2. Is the ribbon moving?
    1. Lift the ribbon cartridge out of the typewriter
    2. Inspect the ribbon for damage
    3. If the ribbon is silver, it is exhausted and must be replaced
    4. If the hammer has been striking in one place, there will be a clear area near the center of the ribbon.
    5. Turn the colored knob on the left side of the ribbon cartridge counter-clockwise to advance the ribbon a small amount. Replace the ribbon if it will not advance.
    6. Re-insert the ribbon
  3. Turn on the typewriter, insert a piece of paper into the typewriter and type a few letters
    1. Did the hammer move forward?
    2. If the hammer moved, did the ribbon advance with each keystroke?
If the hammer did not move or the ribbon did not advance, the typewriter will require service. If the typewriter still does not make an impression on the paper, your typewriter will require service.
Dec 09, 2013 | Brother Office Equipment & Supplies
Replaced ribbon but now the ribbon doesn't advance. Could it be ribbon itself is defective or could I have replaced it wrong? Ribbon is wrong replacement?
Try removing the ribbon, advancing it a foot or so by hand. Install it, mark the feed wheel type and see if it is turning.
DickyO
Aug 02, 2011 | Olympia Monica 2 Typewriter
Anytime she goes to print a badge the ribbon breaks. It's the correct ribon. She's put in a new ribon and the same thing happens.
When the ribbon keeps breaking on fargo DTC300 or any similar models (the ones that share similar mechanics) three steps are to be taken.
1- Verify, clean, calibrate or replace the ribbon sensor (maybe you'll see an error like "Panel Searching" that means " the ribbon sensor can't read the ribbon panels normally).
2- Clean the "card path" (the feed and platen rollers) for dust dirt and debris using the manufacturer's cleaning kit (or a clean
lint-free cloth with isopropyl alcohol) and the "clean printer" option.
3- Clean the inside and outside of the printer (pay attention to the printhead) with dust-off, lint-free cloth, isipropyl alcohol and enjoy.
Or, for more advanced ts take it to a certified tech!
Mar 02, 2011 | Fargo DTC-300 Thermal Card Printer
Selectric II- changed the ribbon, new ribbon won't advance
The ribbon is probably not threaded to the lift of the white slacker finger just left of where it comes out of the cassette.
DickyO
Sep 30, 2009 | Lexmark Wheelwriter 15 Series II...
Old typewriter Brother DELUXE 800 : ribbon reference ?
This is what you are looking for:
Brother Typewriter Ribbon spool black and red SC-20BR-BRO Compatible
The typewriter ribbons for use in Brother manual typewriters are usually all the same. What matters is the size (diameter and hight) of the spools.They differed only in that they were available in different colours (usually black or black and red) and in different materials: some ribbons were made of nylon (cheaper) and other made of silk (more expensive and higher quality) .
Maybe some old and good stationer's (papeterie) still carries them or has some in stock.
Or else you may want to contact the customer support service of Brother, in France, for advice on where to find them in your Country.
Sep 07, 2009 | Brother Office Equipment & Supplies
Brother CE-70 typewriter. Was typing perfectly well. Over about 15 characters the impact on the print head reduced to nil. Although printhead appears to strike the daisy wheel the character does not strike...
Make sure that the ribbon is moving. If characters are piling up in the same spot on the ribbon you will get this problem. Easiest fix is to replace the ribbon. Many brand new ribbons can have a problem. If this dosent solve the problem it may be a mechanical problem with the mechanism that drives the ribbon, requiring a technician to repair.
Oct 22, 2008 | IBM Wheelwriter 30 Typewriter
GX-6750
The ribbon doesn't advance at all? Try turning the ribbon by hand. If it is really hard to turn, or doesn't advance when you turn the knob (make sure you turn it in the direction of the arrow), then the ribbon is defective and you just need to get a good one.
If the ribbon turns easily, the leave the ribbon off, type and watch to see if the black knob on the left of the ribbon plate (the place where you put the ribbon), that turns the ribbon, is moving.
Also I have found that some brands of ribbons simply do not work on this machine. If the ribbon and the ribbon drive is working, try a different brand of ribbon.
Oct 22, 2008 | Brother GX-6750 Typewriter
IBM Selectric III Typewriter Ribbon help
There are two different ribbons for the selectric III one has the ribbon lift guides built into the ribbon the other the guides are part of the typewriter. The first is a General Ribbon T=387 the other is a G.R. T-385.
Hope this helps;
DickyO
Sep 01, 2008 | Lexmark Wheelwriter 15 Series II...
Brother GX-6750 Typewriter Logo
29 people viewed this question
CheckitRight
CheckitRight
Ron Dufek
Ron Dufek
James Cagle
James Cagle
