Question about Bosch SHU5316UC Dishwasher
Does not wash the top rack properly - Bosch SHU5316UC Dishwasher
  • Bosch Master
  • 43,501 Answers
Hi, I have an older dishwasher also and recently my wife alsocomplained about it not cleaning right... so me being the man I am tried invain to clean the things... Bought new spray arms online and installed them inminutes...now the thing works like new... However I have also found that if theheating element goes bad then that also can mess things up bad... So I wouldbuy new spray arms, and also check out the heating element to make sure it isworking... Here is a tip that will help you with the online buying...
Dishwasher Spray Arms not Spinning
How to Buy Appliance Parts Online
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The Heating Element not Working
Dishwasher Maintenance
heatman101
Asker's Testimonial "explanation very clear. will give it a go and see howsimple it was. thanks Ronnie " - ronnieshomes
Posted on Nov 07, 2010
My Hotpoint dishwasher works fine except that it will no longer wash the dishes in the top rack. It's like the water is not coming up far enough from the bottom to do the job.
There should be an upper spray arm to wash the upper rack, it may be stuck. Look at its position, run the machine a few seconds and see if it moved. The spray nozzles on the arm often get clogged with food particles. the pipe feeding the spray arm has to extend when you pull the rack out and retracts when you push it in. Make sure it works properly and has not disconnected.
Sep 04, 2017 | Hotpoint Dishwashers
No hot water
If you have no hot water to a dishwasher. check that it is hooked up to the hot water in the first place and that the valve is on. if hooked up to the cold most units do not heat the water to the proper level.
Jan 28, 2015 | Whirlpool Gold WDT710PAY Fully Integrated...
Quite Partner 2 no top rack wash cycle
The top rack in your dishwasher not working, the recirculate pump may be clog or Gump up with food broken glass and plastic check sump,
Apr 20, 2014 | Whirlpool Dishwashers
My Whirlpool Quiet Partner II does not clean the upper rack of dishes properly. They are greasy. I have checked the top spray arm for blockages. There were none. I am fairly certain that water is
Make sure the center loading is not obstructing the water jet to the top shelf. Top shelf is only for glasses and saucers , use Jet-Dry .Pre rinse and clean bottom pan strainer from dirt debris.
May 14, 2012 | Whirlpool GU2400XTP Built-in Dishwasher
THE DISHES ON THE TOP RACK HAVE JUNK IN THEM DRIED ON FROM THE DISHWASHER. HOW DO I FIX THIS PROBLEM?
Make sure that the vertical tube which dispenses the water is not clog. If water can not go up the tube the top rack will not get washed properly. Sometime food particles fall into the spray ports and clog the water from coming out. Tip, try to remove as much solid food particles as possible prior to washing the dishes. Good Luck
Jan 06, 2011 | Dishwashers
Dishes not clean?
Check all the water jet orfices in the moving arm. Try cleaning without loading the top rack.
If cleans well, mostly the upper rack dishes not arranged properly.
I hope you are using the main wash detergents. Rinse aid is just to remove the stains after the main wash rinse.
Apr 01, 2010 | Dishwashers
My frigidaire dishwasher does not wash on the top
Insufficient water can cause your symptoms
Nov 02, 2017 | Frigidaire Dishwashers
Top rack wont clean
Take the top rack out of the machine.The remove the wash arm they usually unscrew by turning a nut in the middle and wash under running water also check that the holes are free from any food deposits.Replace and give it a test this should work now.The other possibility is that the bottom arm is not fitted correctly,in wich case remove the bottom arm and fit properly.
Let me know how it went.
Dec 30, 2009 | LG LDF6810 Built-in Dishwasher
Top shelf dishes are not washed
possibly low water pressure...
racks might be in backwards if it's an older model with wheels on shelf system... rubber bumpers should face out...
could be a blockage in the upper sprayer arm... or the upper arm had come off and was remounted in a position that doesn't line up with the jet of water from below...
could be bad loading technique... sounds simple enough but you should never put large bowls or pots that lay horizontally on the lower rack because it really screws up the cleaning effectiveness. Large items should always go on the top rack or be washed by hand if they don't fit on the top rack.
Sep 02, 2009 | Whirlpool Dishwashers
Bosch SHU5316UC Dishwasher Logo
65 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
