Question about LG 24 in. LD-12BW5 Free-standing Dishwasher
LG DISHWASHER WORKS BUT VERY NOISY MODLE:LD-2040WH
WORKS BUT VERY NOISY CANT SEE WHERE TO OPEN THE MOTOR PART. LG DISHWASHER
    New Friend:
The main water pump on this model does not last long. The water seal between pump and motor starts to leak that result in the adjacent motor bearing corroding and eventually failing, resulting in excessive noise. Later the water leak becomes so bad that it triggers the "E I" water leakage display and prevents it from completing the program. The pump and motor is sold as one unit and the whole unit must be replaced. I have tried to replace the faulty bearing and repacked the rubber seal with silicon grease but with no success. If anyone have repaired the water seal successfully please let us know.
Posted on Feb 07, 2013
4 Suggested Answers
Krazytech
  • 725 Answers
SOURCE: Dishwasher sounds like it is straining LG LD-2040WH
E1 leakage error
The excessive RPM of Washing Motor happened during Wash cycle due to water leakage.
Water leakage in Hose connections. Water is leaked by damages. The Motor Water Seal leakage of Sump assembly. The height of Drain Hose connection (sink-Drain Hose) is not over 20 . Impeller of the Washing Pump is worn away.
Replace the connections of Hose. Check the point of damages and repair or replace the related parts.
Replace the Impeller of the Washing Pump.
Posted on Sep 27, 2009
  • 106 Answers
SOURCE: E1 display in diswasher
If you've checked everything, you will need to replace the impeller possibly.
Leakage error > Conditon: Excessive RPM of washing motor happened during wash cycle due to water leakage. Possible cause: Water leakage in hose connections,water is leaked by damages. The motor water seal leakage of sump assembly. The height of drain hose connection ( sink drain hose ) is not over 20". Impeller of the washing pump is worn away.
Posted on Mar 30, 2010
SOURCE: Repair door springs - LG dishwasher - LD-2040WH.
my lg door keeps on falling done something wrong with door springs ; how do i repair it.
Posted on Jan 13, 2011
My lg Le 1415m1 has limited flow pressure have replaced wash pump motor still did not fix
LG LD-1415M1 Support: Find Manuals & Warranty Info ' LG ...
www.lg.com/au/support-product/lg-LD-1415M1
LG ElectronicsProduct Support. Home Appliances; Dishwashers; LD-1415M1. LD-1415M1 ... What should I do Low Rinse Aid indicator lightens up? Why is water not supplied ...
LG ElectronicsHome Appliances; Dishwashers; LD-1415M1. LD-1415M1. Search For ... What should I do when dishes are kept in a dishwasher after a cycle? Are plastic or ...
Nov 19, 2015 | LG Dishwashers
I have a LG model no LD-2040WH dishwasher that is troublesome at the moment. During the washing cycle, it gives a very high pitched screeching noise. It has now displayed an error code E1. I have take
The problem could be the washer motor bearing. LG motors have the impeller unit coupled to the motor and the water seal between the motor and impeller is a problem. The drop of water that leaks ends up on the bearing and it eventually gives problems. This can be seen by close inspection of the front bearing for slight rust indications .They use poor quality bearings but replacing the bearing is easy BUT you need to replace the water seal as this is the cause of the problem. Unfortunately the water seal is part of the plastic impeller unit and must be replaced. Not necessary to replace the whole motor as the bearing is easily replace and cheap. (the noise made by this fault is more of a slightly high pitch grinding / whine)
Jan 18, 2015 | LG Dishwashers
LD-2040WH
The IE or 1E error or fault code indicates that the washer is not filling with water. Check to be sure the water supply valves are open. Also, check to be sure the water supply hoses aren't kinked or clogged. Next, remove the hoses from the washing machine and run water into a bucket to test the pressure and flow of the water. If all of these check out and you have good water pressure and flow to the machine, you should replace the water inlet valve.
Aug 27, 2014 | LG Dishwashers
My LG dishwasher LD-2040WH washed and as soon as the element goes on it switches off by itself. I put it on the gentle cycle and then it switch off and now there is nothing going on it is completely dead...
see the w. diagram for test
1) Test the switch door for defective, this switch can be open or defective and can be open the starting relais and turning off the main motor.
2) Timer: test for defective, clean contact, repair wires loose, broken, or burn.
May 09, 2012 | Whirlpool 24 in. DU940QWD Built-in...
LG DISHWASHER LEAKING WITH E1 ERROR CODE.
Hi phtanner,
The E1 error can be fixed by following my Tip below:
L.G DISHWASHER E1 ERROR...
Follow these directions, and the problem will be fixed.
Kind Regards :-)
* If this solution helped you, please rate it.
Jul 28, 2011 | LG 24 in. LDF 7811 Stainless Steel...
Mar 30, 2010 | LG 24 in. LD-12BS6 Stainless Steel...
Nov 28, 2009 | LG Dishwashers
E1 leakage error
Aug 30, 2009 | LG Dishwashers
LG 24 in. LD-12BW5 Free-standing Dishwasher Logo
387 people viewed this question
Top LG Dishwashers Experts
Mike
Mike
Mike
Are you a LG Dishwasher Expert? Answer questions, earn points and help others
