Question about Dell XPS M1210 Notebook
1210 can't write to CD, registry issues - Dell XPS M1210 Notebook
    President:
  • 261 Answers
Hiwhats your os use different software like nero alchole clone
Posted on Nov 19, 2011
How to download and install " Mass Storage Controller" drivers for my laptop -- Sony Vaio model VGN-FE770G , as in Device manager it is not being able to locate on its own and the driver is...
Hi amitabh2610,
You need to install the Memory Card Reader Driver in the Computer to fix the issue with the Mass Storage Controller. Below are the links to download the Memory Card Reader Drivers for your Computer model. Please open the below links in a new Internet Explorer window to run the files.
ftp://download.sony.com/US/pc/TIDMSC-00967112-US.EXE
ftp://download.sony.com/US/pc/TIDMSC-01424702-US.EXE
Please download and install both the files in the Computer. Also, please make sure that you restart the Computer after each installation for the settings to take the effect. Installing these Drivers should fix the issue with the Mass Storage Controller issue.
Let me help you with the issue with the CD ROM Drive now. amitabh2610 , you will need to edit the System Registry to resolve the issue with the CD ROM, this issue is due to the corrupted registry. Using the Registry editor incorrectly can cause serious problems that may require the operating system to be reinstalled and can result in the potential loss of data. Hence, it is recommended to backup the Registry before editing it.
To backup the System Registry,
Open the Run window and type regedit. Then, in the Registry Editor Window, please click File and select "Export". Select a location to save the file and name it as Registry Backup. Once you have created the Registry Backup, you can proceed with Editing the Registry.
To edit the System Registry.
In the Registry Editor window, in the left pane , double-click the HKEY_LOCAL_MACHINE folder first, then System folder under it, then CurrentControlSet, then Control, Class and then select the {4D36E965-E325-11CE-BFC1-08002BE10318} folder. Now, in the right pane , right click the UpperFilters registry value and click Delete. Then, right click the LowerFilters registry values and click Delete. In the Confirm Value Delete dialog boxes, click the Yes button. After that close the Registry Editor window and restart the Computer.
This should fix the issue with the CD ROM Drive.
Good Luck!
Hope this helps.
Please post back if you have any questions or if you require further assistance.
Thanks for using FixYa.
Nov 03, 2010 | Sony VAIO VGN-FE770G Notebook
Cant install ND 6650A code 39
The issue is with the registry of the Computer. Please follow the steps to resolve the issue. Please back up the registry before performing the steps.
  • Please press "Windows+R" key to open the Run command, type regedit and then click OK.
  • Please click on File-->Export and then enter the name and select the location to backup the registry.
  • In the navigation pane, locate and then click the following registry subkey:HKEY_LOCAL_MACHINE-->SYSTEM--->CurrentControlSet-->Control-->Class-->{4D36E965-E325-11CE-BFC1-08002BE10318}
  • In the right pane, click UpperFilters.
Note You may also see an UpperFilters.bak registry entry. You do not have to remove that entry. Click UpperFilters only. If you do not see the UpperFilters registry entry, you still might have to remove the LowerFilters registry entry.
  • On the Edit menu, click Delete and select Yes to confirm.
  • In the right pane, click LowerFilters, on the Edit menu, click Delete and select Yes.
Note If you do not see the LowerFilters registry entry, exit the Registry.
  • Exit Registry Editor and restart the Computer.
This should resolve the issue.
Good Luck!
Thank you for contacting.
Jun 29, 2010 | Dell DVD-rom DVD Drive
Optiarc dvd rw driver shows code 19 error .i have tryed to reinstall ,but no use.
The below step will surely resolve the issue..
CD/DVD drive in device manager and the CD/DVD properties in device manager shows error code 10 , 19 , 31 , 32 , 39 or 41, please use the following steps:
This issue occurs due to an incorrect registry entry, which might be created due to installation of an incompatible CD/DVD burning program. We will remove the registry entry and re-install the CD/DVD drive and the issue will be fixed.
1. Click on Start and type regedit in the search box and hit enter. It will open Registry Editor window.
2. It will open registry editor.
3. Click on File and Export, it will open a new window.
4. Select Desktop from left pane in the new window and put file name as regbackup and click on Save.
5. It will create a back up of the registry on desktop.
In case something goes wrong during modifying registry, this registry backup can be used to restore to original registry.
6. Now in registry editor click on triangle symbol next to the following items in the left pane:
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
7. Locate 4D36E965-E325-11CE-BFC1-08002BE10318 below class and click on it. Make sure you have selected the correct entry as all the entries looks almost similar.
8. Look at right pane and check if you see UpperFilter and LowerFilters entries.
9. Please right click on UpperFilter and LowerFilters and select delete.
10. make sure there are no other UpperFilter and LowerFilters entry in that window.
11. Close registry editor.
12. Now please click on Start and type device manager in the search box and hit enter.
13. It will open Device manager window.
14. Click on + sign near CD/DVD entry and it will show the name of the CD/DVD drive with a yellow mark near it.
15. Right click on it and select uninstall.
16. It will remove the CD/DVD entry from device manager.
17. In Device manager, click on Action > Scan for hardware changes to re-install CD/DVD drive.
18. Now you should see the CD/DVD drive entry.
19. Do you see any yellow mark near it now?
20. Please click on Start > Computer and check if CD/DVD drive is listed.
21. Please insert a CD or DVD and check if the computer reads it.
May 08, 2010 | Computers & Internet
I instal windows 7 and i miss dvd driver , code error 39
In most cases that is an issue with the registry pertaining to some registry keys. Details are here. Should hopefully solve it.
Apr 23, 2010 | Dell Studio 1537 Laptop Computer PC...
***** problem? it wont be recognized by compute, why oh why??? can you please help
try to change ur jumper setting of ur cd rom drive,set into master mode or slave mode! and try to change ur cd rom cable also.. check ur bios if ur cd rom drive is enable.
Jun 19, 2009 | Toshiba (P000242100) Internal 14x CD-ROM...
Install hp psc 1210
lost my cd for my printer hp psc 1210 where can I download for free
Aug 05, 2008 | HP PSC 1210 All-In-One InkJet Printer
Dell XPS M1210 Notebook Logo
32 people viewed this question
Alun Cox
