Question about GE Monogram ZISS420NRSS 42" Built-In Side-By-Side Refrigerator (ZIS-S420NRSS, ZIS S420NRSS)
I LOOK INGFOR THE THERMOSTATE PART NUMBER T-O-D 37TV31 31659 L140-30F 19705744P002 J0623 FOR THE MODEL GSH25JSTA SS
4 Suggested Answers
  • 82 Answers
SOURCE: OUR GE SIDE BY SIDE
Hello.
Can you tell where the sound is coming from, underneath or inside? If it is coming from underneath make sure the coils are clean and the fan below is blowing. Usually the compressor will labor under these conditions. Let me know if these all check out ok and I will go over some other things..
Posted on Dec 05, 2008
SOURCE: I replaced the water filter for my GE GSH25JSTA SS
I have had the same problem with the same model several times in the past. It also happens to me within a few days of replacing the water filter.
In my case, I believe the water line in the freezer door has become frozen. I usually let the freezer thaw for a couple of hours, and my water works again.
I have had constant problems with this model. I would recommend trying to sell your fridge now while it's still running, before the real headaches begin (mine has died 2x in the past six months, and I have not even had it for 2.5 years yet). No more GE's in my house.
Posted on Jul 20, 2009
  • 107 Answers
SOURCE: what size of this GE
25 cubic feet
Posted on Sep 22, 2011
How do I replace numbers that have come off ss frame
you don't. you have to replace the frame they are on. Usually cleaning solutions cause the letters or numbers to come off.
Jan 27, 2015 | GE Cooktops
I just brought a 2000 VX SS and would like to tell if it is a real "SS" how do I read the VIN...help please..
vin number decode
eg. 6H8VXX35F1L123456
6H8 = HOLDEN
VX= MODEL
X= LUXURY (K= EXEC, L= BERLINA, X= CALAIS)
35= BODY (69=WAGON, 35=SEDAN)
F= ENGINE (A=V6, F=V8 GEN3, R=V6 SUPER CHARGED)
1= YEAR (1=2001, 2=2002 ETC)
L123456= PRODUCTION NUMBER
If you have this code on the tag....
BC1= EX COP CAR
Dec 01, 2012 | Cars & Trucks
GE fridge model # GSH25JSTA SS keeps icing up on the back of freezer and stops cooling
you have a defrost problem,bad defrost heater,thermostat,sensor or computer board,your gonna need a meter to see what's bad,go here
http://www.searspartsdirect.com/partsdirect/part-model/GE-Parts/Refrigerator-Parts/Model-GSH25JSTASS/0432/0165000/G0604755/00003?blt=06&prst=0&shdMod=GSH25JSTASSthis is the parts that are behind the back inside freezer wall,look at 230,240 and 243 and on the outside back of the machine is the computer board part number wr55x10942,hopefully it won't be the board,shut down the machine and remove the back inside wall of the freezer,then go in the back and remove the cover of the mother board,you'll see a metal panel it's behind it,look at the bottom of the board,you'll see a gray plug with three connectors that it's plugged onto,you'll need a jumper wire with alligator clips on the ends,clip it on j9 and j11,this is the middle and the metal to the right in the gray plug,this will turn on the heater in the freezer,,plug the machine back in,if the heater comes on you have a bad board and change out the sensor if it has the black ring on it,no matter what you have to change the sensor if it has black on it,if it doesn't come on then check the thermostat and the heater,unplug the heater and check it for continuity,also look at the heater,if it looks black inside the glass change it out and change out the t-stat,if the heater is good check the t-stat,part number 240 in the picture,also you can cut the two wires going to the t-stat,connect them so you bypass the t-stat and jump out the board again,if the heater comes on the t-stat is bad and this is the most common part that goes,also if there's a white plastic ring around the top of the t-stat and it's popped up on one side it's bad,water got inside of it,froze up and pops the top off.here's a picture of the board and how to jump it out
http://www.flickr.com/photos/zenzoidman/4482598198/sizes/o/in/photostream/
j9 and j11.and here's another picture that might help you http://fixitnow.com/wp/2008/11/04/how-to-test-the-defrost-system-in-a-ge-arctica-or-profile-refrigerator/
you can leave the heater on to help you melt out the ice and with a hair dryer melt out all the ice on the coil,also if you need time to get the parts and stuff if you remove the back inside wall of the freezer and melt out all the ice on the coil your fridge will run for 10 to 12 days and then it will freeze up again but your food will stay good and then hopefully you can have what you need to fix it.hope this helps and good luck.
Sep 09, 2012 | Refrigerators
Freezer thaws and refreezes
HI.DO BASICS FIRST .CLEAN CONDENSER UNIT FIRST THOROUGHLY.INTERMITENT FAULT IS ALWAYS A BIT DIFFICULT TO DIAGNOSE.TRY IT IF OK U HAVE CRACKED IT BUT IF SAME THEN C WEATHER THE MOTOR AND CON/UNIT IS WARM WHEN DEFROSTING IF COLD IT COUD BE A LAZY DEFROST TIMER OR T/STAT THEN HEATER AND FAN.GOOD LUCK ALI
Jul 09, 2012 | GE GSH25JFR Side by Side Refrigerator
Need the specs for the Homedics ss-5010 power adaptor
Product Attributes
Product attributeProduct Line: SoundSpa
Product attributeProduct Model: SS-5010
Product Summary
Manufacturer: Homedics
Mfg Part#: SS-5010
Buy.com Sku: 211467114
UPC: 031262038029
UPC 14: 00031262038029
Package Weight: 1.9 lbs
Buy.com Sales Rank: 64081
Advertisement middle
Features
Product Type Desktop Clock Radio
Manufacturer Part Number SS-5010
Manufacturer Website Address www.homedics.com
Manufacturer HoMedics EMEA
Product Model SS-5010
Product Name SoundSpa Premier SS-5010 Clock Radio
Product Line SoundSpa
Brand Name HoMedics
Frequency Band/Bandwidth AM/ FM
Tech Specs
Brand Name HoMedics
Frequency Band/Bandwidth AM/FM
Feb 13, 2011 | Audio Players & Recorders
I have a GE side by side model #GSH25JSTA SS. It is 4 years old. The Water disenser stopped working about 6 months ago. We have replaced water filter and that did not seem to work. When we press the...
hey Jun, I have the same problem,, especially in the winter.. I just unplug mine for about 20 minutes,,,(DON'T open the frig while doing this!!!) .. seems to get the water flowing for me.....
Jun 14, 2017 | GE GSH25JSTSS Stainless Steel Side by Side...
I replaced the water filter for my GE GSH25JSTA SS side by side fridge and now the unit is no longer dispensing water
Mar 22, 2009 | GE Refrigerators
No water flow
turn the freezer side to zero fridge side will zero also . click for water it should work . just worked for me no water for 1month replaced the filter and everything.
Dec 06, 2008 | GE GSH25JSRSS Stainless Steel Side by Side...
OUR GE SIDE BY SIDE MODEL# GSH25JSTA-SS IS MAKING A STRAINING LOUD NOISE. HELP
Hello.
Dec 05, 2008 | Refrigerators
GE Monogram ZISS420NRSS 42" Built-In Side-By-Side Refrigerator (ZIS-S420NRSS, ZIS S420NRSS) Logo
811 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Randy Justice
