Question about Philips Audio Players & Recorders
I have a philips 22ah786/44 stereo receiver. The out-puts are for bare wire ends, a red wire & black wire for EACH speaker. When I hook up a speaker it works ok. I want to go out to my laptop computer and use RCA jacks, one for left and one for right. The cable is plugged into a USB adapter from Roxio (Roxio Creator Special Edition 2011). I am wanting to copy my records onto CD's. So, I simply cut off the red RCA and white RCA at the other end, and put the bare wires into the "L & R" lugs but I am not getting the sound coming across. I may not have the right switch thrown, or there needs to be a black wire attached to the back of the receiver also??? Second question: How can I get a User Manual? PDF perhaps. This equipment is from my parents who bought it new. Thank you, Dwayne dwdewhitt@wamail.net
  • dwdewhitt Nov 07, 2010
    Thank you for the advice and resources.
    The headphone jack is the biggger size.
    There are no other out-put ports on this receiver. Can you tell me why the speaker outputs wont work? I am always interested in learning.
    Many thanks.
  • dwdewhitt Nov 08, 2010
    Thank you for the additional explanation. Your prompt assistance has been good. Thank you!!
    President:
  • 2,777 Answers
There is no free manual available for this model receiver, about the only thing I can find is a service manual, which is $10 here:
http://cgi.ebay.com/Philips-Service-Manual-Stereo-Receiver-22AH786-44-/380188610065?pt=LH_DefaultDomain_0&hash=item588501ce11&x=62&y=9
However there is a simple way to accomplish what you are trying to do. You can't just hook up RCA's directly to the speaker outputs, they do not function the same way speaker wires do. You CAN hook up the headphone output plug to a minijack to RCA cable though and use that.
Here is the cable you need, I think that receiver has a standard minijack headphone plug in, but you may need the minijack to large headphone adapter, which is the second link here. This is the cable:
http://www.amazon.com/gp/product/B00004Z5CP?ie=UTF8&tag=dependascient-20&linkCode=as2&camp=1789&creative=390957&creativeASIN=B00004Z5CP
Here is the adapter for 1/8 to 1/4 inch headphone adapter:
http://www.amazon.com/gp/product/B00142BZSY?ie=UTF8&tag=dependascient-20&linkCode=as2&camp=1789&creative=390957&creativeASIN=B00142BZSY
Thanks,
Tim
Posted on Nov 07, 2010
  • Tim Grayson
    Tim Grayson Nov 07, 2010
    There should be a headphone port, possibly even on the front of the receiver.
    Basically they speaker outputs will not work with RCAs because they are a different "format". The speaker outputs send a sinusoid wavelength out of them... pulses of electricity that a speaker picks up and then vibrates according to, thus producing sound. RCAs are looking for a more digital style signal, basically more like a computer signal to talk to them more than just vibrations...
    It's hard to explain but just trust that they are very different styles of signals.
    Thanks,
    Tim
I have a sony str-DE695 and I am trying to hook up my speakers/record player to it. The record player has an RCA chord with one white and one black end. The speakers has the same chord but with one red and...
the inputs should be marked phone (if on the reciever the colors are red/white and the colors of the rca ends are black white put the black plug in the red and white plug into the white input..if the stereo doesn't have rca speaker output ports you'll need to cut off the speaker rca's and strip the wires bare then comnnect usually copper (red) silver (white) or pos (silver) neg (copper.
Sep 26, 2012 | Sony STR-DE695 Digital Audio/Video Control...
Please send me a diagram of how the wiring is to be set up on the back of the speakers
The red connector on the speaker should be connected to the Pos.(+) connection on the Receiver/Amp. The Black to the Neg. (-) connection. ( for the proper speaker) Front Left, Front Right,etc. All, or most paired wire has either a black stripe,different shape on one,or different colour wire(silver/copper) So if you hook up the Blk striped or silver to the Neg.(black terminal) on the speaker, do so at the other end (receiver ) If both speakers aren't hooked up the same, they will work, but there won't be as much Bass because the speakers will be out of phase.(when one speaker cone is moving out,the other will be moving inward.
Dec 03, 2011 | KEF Audio Model Three Main / Stereo...
Gauge cluster lights won;t light - replaced cluster, dimmer switch - did put new stereo in car? Fuses, bulbs all good. What could be the problem?
When you put the stereo in, what did you do with the red wire with a green stripe? The aftermarket radios don't always use these, so you have to wrap the ends, depending on whether or not you used a wiring harness. If that wire is shorted on the chassis, it will blow the dimmer fuse.
1995 Honda Accord Car Radio Wiring Diagram
Car Radio Battery Constant 12v+ Wire: Blue/White
Car Radio Accessory Switched 12v+ Wire: Yellow/Red
Car Radio Ground Wire: Black
Car Radio Illumination Wire: Red/Black
Car Stereo Dimmer Wire: Red/Green
Car Stereo Antenna Trigger Wire: Yellow/White
Car Stereo Amp Trigger Wire: Violet/Red
Car Stereo Amplifier Location: N/A
Car Audio Front Speakers Size: 5 1/4?
Car Audio Front Speakers Location: Doors
Left Front Speaker Positive Wire (+): Blue/Green
Left Front Speaker Negative Wire (-): Gray/Black
Right Front Speaker Positive Wire (+): Red/Green
Right Front Speaker Negative Wire (-): Brown/Black
Car Audio Rear Speakers Size: 6 1/2?
Car Audio Rear Speakers Location: Rear Deck
Left Rear Speaker Positive Wire (+): Blue/Yellow
Left Rear Speaker Negative Wire (-): Gray/White
Right Rear Speaker Positive Wire (+): Red/Yellow
Right Rear Speaker Negative Wire (-): Brown/White
Nov 28, 2010 | 1995 Honda Accord
How do I hook up the bare wires speakers to the back, sound is coming out not good.
Sounds to me like you might have the polarity reversed. Meaning you might have hooked the positive to negative and the negative to the positive. Positive will will be red negative will be black on your receiver. On the speaker wires negative will always be solid black. Positive could be solid red, black with a red stripe, or black with any color stripe. Make sure you have solid black hooked to black and the other hooked to red. Hope this helps:)
Nov 30, 2009 | Insignia 200W Stereo Receiver
I don't know how to attach my speakers to the red
If you have bare ended wires , you simply unscrew the red and black plugs at the amp they should have a hole in the end of the plug and on the side also just place the red wire into the side hole of the red plug and finger tighten the red screw the same on the black plug
Jun 06, 2009 | Polk Audio RTi100 Main / Stereo Speaker
Can,t figure out how to wire it up to my 1995 jeep and would like to find out how to wire it up?
Dont know what model you have so here u go!
1995 Jeep Wrangler Car Stereo Radio Wiring Diagram.
Car Radio Constant 12V+ Wire: Red/White
Car Radio Switched 12V+ Wire: Purple/White
Car Radio Illumination Wire: Blue/Red
Car Radio Dimmer Wire: Red/Black
Car Radio Antenna Trigger Wire: N/A
Car Radio Amp Trigger Wire: N/A
Front Speakers Size: 4′ x 6′
Front Speakers Location: Dash
Left Front Speaker Wire (+): Gray
Left Front Speaker Wire (-): Yellow
Right Front Speaker Wire (+): White/Red
Right Front Speaker Wire (-): Brown/Red
Rear Speakers Size: 4′
Rear Speakers Location: Rear Roof
Left Rear Speaker Wire (+): Gray/White
Left Rear Speaker Wire (-): Brown/White
Right Rear Speaker Wire (+): White/Black
Right Rear Speaker Wire (-): Brown
1995 Jeep Cherokee Car Radio Stereo Audio Wiring Diagram
Car Radio Constant 12v+ Wire: Pink
Car Radio Switched 12v+ Wire: Violet/White
Car Radio Illumination Wire: Light Blue/Red
Car Stereo Dimmer Wire: Orange
Car Stereo Antenna Trigger: N/A
Car Stereo Amp Trigger Wire: N/A
Car Audio Front Speakers Size: N/A
Car Audio Front Speakers Location: N/A
Left Front Speaker Positive Wire (+): Dark Green
Left Front Speaker Negative Wire (-): Brown/Red
Right Front Speaker Positive Wire (+): Violet
Right Front Speaker Negative Wire (-): Dark Blue/Red
Car Audio Rear Speakers Size: N/A
Car Audio Rear Speakers Location: N/A
Left Rear Speaker Positive Wire (+): Brown/Yellow
Left Rear Speaker Negative Wire (-): Brown/Light Blue
Right Rear Speaker Positive Wire (+): Dark Blue/White
Right Rear Speaker Negative Wire (-): Dark Blue/Orange
1995 Jeep Grand Cherokee Car Stereo Radio Wiring Diagram
Radio Switched 12V+ Wire: Red/Gray
Radio Dimmer Wire: Orange
Radio Power Antenna Trigger Wire: Green/Red
Radio Amplifier Turn On Trigger Wire: N/A
Front Speakers Size: 6 1/2′
Left Front Speaker Wire (+): Green
Left Front Speaker Wire (-): Brown/Red
Right Front Speaker Wire (+): Purple/Yellow
Right Front Speaker Wire (-): Blue
Rear Speakers Size: 6 1/2′
Rear Speakers Location: Rear Doors
Left Rear Speaker Wire (+): Brown/Yellow
Left Rear Speaker Wire (-): Brown/Light Blue
Right Rear Speaker Wire (+): Blue/White
Right Rear Speaker Wire (-): Blue/Pink
window.google_render_ad();
Jun 03, 2009 | Pioneer DEH-P2000 CD Player
Stereo Wiring 1984 VW Rabbit
The red wire is power, brown is ground. There also may be a second power wire (possibly yellow) that is switched though the ignition (test this with a light), if you hook it up that way you won't drain your battery by accidentally leaving the stereo on!! The best way to determine what wires go to what speakers is to take each pair and brush the ends across the ends of a "D" cell battery! the corresponding speaker will produce a bit of static! The wires with the stripes are the negative side of each speaker circuit. Hope this helps...;-)
Apr 08, 2009 | 1984 Volkswagen Rabbit
Adding extra wire to speakers so I can move speakers.
Red and black are high end and blue and grey are sub speakers.
Apr 15, 2017 | Panasonic SC-AK500 CD Shelf System
Nakamichi RE 10, Ser # D14104843
The end holes are designed for plug-in speaker jacks, either single-ended or double ended to span the red black simultaneously (the spacing has to be right, though). Tighten the red/black parts first.
Otherwise you need to bare a little wire (not sure you either can or want to do that with Monster Cables); unscrew the black or red connectors sufficiently and wrap the bare wire around the base, being careful to avoid stray conductors reaching across to other terminals. If you look closely there might be a small hole drilled through the terminals, accessible from below. Ideally you would bare the wires, tin the ends with solder, stick them through those holes and tighten the plastic knobs.14-ga lamp cord would work fine, too, and it's cheap, cheap, cheap.
The 901's will absorb unlimited amounts of CLEAN audio power.
Jun 24, 2008 | Nakamichi RE-10 Receiver
133 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
 Grubhead
Grubhead
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
