Question about Hitachi CP-S210 Multimedia Projector
How do i clean the air filter in a hitachi cp s210
Wardenswife
SOURCE: Resetting Air Filter Timer once cleaned.
Menu, options, filter time. When the filter time is displayed, press the reset button for at least 3 seconds. The reset menu will appear and you can select RESET.
Posted on Mar 04, 2008
Marrie
  • 563 Answers
SOURCE: how to clean air filter in HITACHI CP-X385
Hi there
Look at the bottom of the Projector , you'll see a thin grey line with two edges on it. That is the filter. Grip on the sides and gently pull it out.
Posted on Mar 26, 2008
  • 105 Answers
SOURCE: Resetting the air filter timer
Hitachi CP- RX60:
Press the RESET button on the remote control or the right-pointing triangle button on the projector for about 3 seconds. Once you see the RESET dialog, use the upward-pointing triangle to RESET. I can't see what you are or are not doing...so please see page 39 of the user's manual (download found below)
Source:
http://www.aboutprojectors.com/Hitachi-CP-RX60-projector.html
Hitachi-CP-S335 :
"The lamp time is the time counted after the last resetting. It is shown in the OPTION menu as the use time of the lamp. Pressing the RESET button on the remote control for about 3 seconds displays a dialog. To reset the lamp time, select the RESET option using the (triangle) button."
Taken from pg 36 of the users manual (download link below)
Source:
http://www.aboutprojectors.com/Hitachi-CP-S335-projector.html
Posted on Apr 24, 2008
SOURCE: Hitachi CP-x430 "Check air flow"
I have run in to this time and time again. This is why I like to keep things clean. take the bulb out and blow the unit out with air and make sure you wipe off what you can with Q-tips The blub allows air to flow thew the filament so what ever dust that might touch the fillament while its burning will burn at a higher temp. this will send and indication to the unit to send a message that says replace bulb soon and If there is not enough air flow it will say CHeck air flow take the fliter out and clean it with water dont replace it. IF you do just buy a carbon pad and cover the hole(not recomended foir those who are not handy) but keep things clean and it will save you $ in the long run. How many bulbs do you want to buy?
Posted on Mar 10, 2009
  • 207 Answers
SOURCE: clean air filter and reset
Here's the PDF to your particular unit. Check out page 28 of the PDF (Page 27 on the actual manual) Good luck!
http://www.hitachi-homeelectronics.us/supportingdocs/forhome/DisplayTechnologiesGroup/lcdprojectors/SupportingDocuments/01CPX385EN.pdf
Posted on Apr 29, 2009
Lamp and temperature light are lit but projector is working fine, should i be worried?
Yes!
The temperature lamp means it is overheating which will finish up cooking the LCD units, (blue first) and the lamp light is on as the lamp is about to expire.
Clean the air inlet filters and replace the lamp.
Oct 31, 2010 | Hitachi CP-S210 Multimedia Projector
How do I reset the filter timer on the hitachi cp s210?
The reset function is in the options menu. Once you scroll through the menu locate the filter timer, forward to the timer locate reset, you then need to hold down the reset button on the bottom RH of the remote control.
May 07, 2009 | Hitachi CP-S210 Multimedia Projector
Red dots on screen of
Typically this is an indication of dirt in the optical path. Try blowing out the area using compressed air. Also, make sure that the lens is clean. Use a cloth and solution made specifically for cleaning lenses.
Dan
May 05, 2008 | Televison & Video
How to clean air filter in HITACHI CP-X385
On the right side of the projector there are vents, put a vacume cleaner up to the vents, and the filter will be cleaned.
then on the top of the projector click the down arrow, then go down to option, use the down arrow to highlight the filter time, then hold the reset button on top of the projector for about three seconds. Clean the air filter every 100 hours.
Mar 17, 2008 | Hitachi CP-X385 Multimedia Projector
Hi there
Mar 17, 2008 | Hitachi CP-X385W Multimedia Projector
Hitachi projector cp - s210
hi there,
I have just done the exact same thing today. Press menu button on projector. Scroll (navigate) to the mirror option. This give you the options to mirror image left to right or up and down.
This should fix any of your problems.
Cheers
Luke
Feb 03, 2008 | Hitachi CP-S210 Multimedia Projector
Feb 01, 2008 | Hitachi CP-X385 Multimedia Projector
Hitachi CP-S210 Multimedia Projector Logo
187 people viewed this question
Top Hitachi Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Hitachi Office Equipment and Supply Expert? Answer questions, earn points and help others
