Question about Toshiba Tecra 8200 Notebook
My computer has a bad memory slot - Toshiba Tecra 8200 Notebook
Lgr40 memory
could be a parity issue. Make sure of the following
Both memory are the same in size (for better performance) and buffer rate (all can be found on the memory card sticker/label.
Note that some can look the same and everything but then then there are not what the machine memory dimm slot takes....you should check in the computer manual if you have any.
Also take the memory out (both) and insert them individually in one memory slot after the other and turn the computer on to see if it works. You may have a faulty memory as well or a bad memory dimm slot.
Good luck and do let me know what happens next
May 18, 2014 | Computers & Internet
DELL OPTIPLEX IS ONLY ACCEPTING ONE MEMORY AT A TIME AND SYSTEM HAVE TWO MEMORY BANK
Inset 1working memory stick in a slot. Then try the next slot. If the good stick works in both slots, you have a bad memory module.
Aug 02, 2013 | Dell OptiPlex 360 Desktop Computer
I have a dell inspiron 545. I lost my display and the computer now beeps four times, pauses and beeps four more times. Can you tell me what happened to my computer?
This is normally a memory error. Turn off the computer, and open the side of the case. Pull and re-seat all memory chips. Turn power on, if it still beeps. Turn off power, pull all the memory chips and re-seat one only. Turn on power if it beeps againg, pull the chip out and try the other one. Repeat for all chips. If you find any that do not cause the beep issue, you have found your bad memory chip. If not, try the same one at a time memory test in a different slot on the computer. If no beeps, then its a bad slot and dont use that memory slot.
If none of this works; as unlikely as it seems you could have all bad memory chips, or a bad mother board.
Jun 12, 2012 | Dell Computers & Internet
Dell inspiron has no display and beeps four times and then pauses and beeps four more times
4 two tone beeps on startup
Sounds like your memory or video card is the issue. I would try the memory.
Maybe your memory is bad or the memory slot is bad.
Remove the Power Cord, Open the Case and remove one of the memory chips. Set the chip aside then try rebooting the computer. If it boots, then you know the memory chip you set aside is bad so mark an x on it with an ink pen. If it fails to boot then move the chip to the next memory slot and try rebooting. If it fails take the chip out and set it aside, then put the other chip in and try booting it in both slots. If it boots, just to verify that the chip set aside is bad, mark an x on it and put it into the open memory chip slot and try booting.
May 29, 2012 | Intel D865PERL Motherboard
Continuous beeping noise on boot up
Sounds like you have a bad memory chip or one of the memory slots is bad.
Remove the Power Cord, Remove the battery, Remove the cover that houses the memory on the bottom of the laptop then remove one of thememory chips. Set the chip aside then try rebooting the computer. If it boots, then you know the memory chip you set aside is bad so mark an x onit with an ink pen. If it fails to boot then move the chip to the nextmemory slot and try rebooting. If it fails take the chip out and set itaside, then put the other chip in and try booting it in both slots. If itboots, just to verify that the chip set aside is bad, mark an x on it and putit into the open memory chip slot and try booting.
May 02, 2012 | Computers & Internet
Toshiba flashing power light
More than likely it's your memory or video card. Does anything ever post to the screen when you press the power button? If not, it could be the video card is bad.
Remove the Power Cord, Remove the Battery, Remove the cover that houses the memory on the bottom of the laptop then remove one of the memory chips. Set the chip aside then try rebooting the computer. If it boots, then you know the memory chip you set aside is bad so mark an x on it with an ink pen. If it fails to boot then move the chip to the next memory slot and try rebooting. If it fails take the chip out and set it aside, then put the other chip in and try booting it in both slots. If it boots, just to verify that the chip set aside is bad, mark an x on it and put it into the open memory chip slot and try booting.
Apr 27, 2012 | Computers & Internet
3 beeps after interval
Usually and indication of a memory issue. Power off the computer and pull all memory out. Place memory in one at a time into a slot and power on. If it fails on a particular chip, that would be the bad memory module. If it fails on every chip, the slot could be bad. If it does not fail and any chip, try each slot individually. It should fail on one slot and that would be a bad slot on the board.
Hope this was helpful
Mar 12, 2012 | Intel D845GLLY Motherboard
Memory problem
First pull cmos cell from motherbord for 10 minutes.
then open processor fan and processor then clean dust from motherbord and all parts then reconnect processor and its fan.
Then refix RAM memory .
then if it beeps so long then most of it is your RAM problem.slot is more time works fine in that case.
Check your RAM in ALL MEMORY MODULE SLOT.
Aug 25, 2009 | HP (D7580-60003) Motherboard
I wanted to upgrade the memory on my pavilion zt1130 notebook from 256mb so I purchased to 512mb memory cards and replace the resident memroy under the keyboard. It runs faster but as soon as I put the...
According to Hp website your computer will handle two 512 Mb RAM chips. Make sure they are PC133. If computer will not boot with both inserted properly, one of them is bad. Put one in slot 1 and none in slot 2 and see if it boots. Then switch the chips put the extra chip in slot 1 and none in slot 2. See if it boots. This way you can troubleshoot a possible bad chip.
Aug 15, 2009 | Office Equipment & Supplies
Toshiba Tecra 8200 Notebook Logo
150 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
