Question about Cub Cadet Garden
Can you charge the mower battery - Cub Cadet Garden
    Problem Solver:
  • 7 Answers
Well, first you need to give more information about the lawn mower. first off, is it a rider? what model tractor is it? if its a cub cadet it will be on the side of the hood, either 3 or 4 digit number. and also, what kind of battery does it have in it? it will have the info on the top of the battery. i wish i could help you more, but, its hard with the info youve supplied. hope to hear from ya, look forward to helping you... -Brian-
Posted on Nov 07, 2010
I have a cc 500 bat push mower the battery charger was leftout on rain the light dont come on for charger is it fried also does it have a plug that i can plug extenstion cord in or do I n
The charger lead should have been connected to a Residual Current Device, or Earth Leakage Breaker that should have flipped the power off. There should be a reset button on the plug.
Charge the mower for 14 hours before initial use. Charge mower indoors in a dry area out of the weather. DO NOT charge in rain or wet locations. IMPORTANT: Use only the battery charger provided with this mower. Plug the battery charger into the battery first, and then into any standard 110/120 volt household electrical outlet. See Fig. 3-9 for B battery charging location. A C NOTE: If an extension cord is required, use one that is at least wire size 16 AWG. Connect the extension cord to charger before plugging extension cord into electrical outlet. NOTE: You may charge the battery with the battery removed from the mower. IMPORTANT: Always recharge battery fully. It takes 14 hours to recharge a completely discharged battery. A flashing light on the battery charger indicates the battery is less than 80 percent charged; a solid green light indicates the battery is 80 to 100 percent charged. A full charge will be achieved in less than 14 hours if the batteries were only partially discharged. NOTE: It is recommended that the mower be charged once every two months during storage. IMPORTANT: Always disconnect battery charger (or extension cord, if used) from the electrical outlet first, then disconnect battery charger from battery. NOTE: It is recommended that the mower be charged immediately after it has been discharged. Storing batteries in a discharged state could reduce future performance. WARNING: The battery contains corrosive fluid and toxic material - HANDLE WITH CARE. Keep away from children. Do not puncture, disassemble, mutilate, or incinerate. Explosive gases could be vented during charging or discharging. Use in a well ventilated area, away from sources of ignition.
Cub Cadet CC500 BAT Operator Manual Charging The Battery
Cub Cadet CC 500 BAT Review Pros Cons and Verdict
It is a 48 volt battery, so the charger for this is special. contact Cub Cadet direct for a replacement.
Service Parts
Aug 09, 2017 | Cub Cadet Garden
Cub cadet 1641 stalled and now starter will not engage but battery is fine?
if its just clicking take battery to auto store let them test its free if not battery i thnks it the battery it my be not charging the battery start lawn mower up pull positive side off test voltage at cable should 12.5 to 13.5 volts if not it is not charging battery if is maybe was low on charge lawn mowers will not fully charge battery not unless your on them all the time so check that
Sep 02, 2014 | Garden
Why doesn't craftsman mower tractor yt 3000 charge?
If the battery is below around 11.8 volts it never will charge. The charging systems on these mowers are made to "maintain" the charge. Check the battery, if below 11.8 volts charge the battery with a battery charger. Then see if the mower will maintain the level. If not, you may have a bad battery. Your local automotive store can check it for you.
Jul 08, 2014 | Craftsman YT 3000 42" Briggs & Stratton 21...
Battery drains and won't charge
I would start by having battery tested. If u remove it and take it to auto parts store they will test it for free. It could be that the battery will not hold a charge or your tractors alt. is not putting out a charge
Apr 04, 2014 | Garden
Battery will not stay charged.
Will the battery stay charged with one terminal disconnected?
if yes the you have a wiring problem. If no get a new battery.
What is the battery voltage when mover is running?
12.6v = not charging while running
13.7v = good charging
Oct 23, 2013 | Garden
Worx 17'' Cordless Lawn Mower (Model WG787). I've got a barely three month old lawnmower and the battery is fully charged yet the blade only barely spins. Seems to be virtually no power despite the charged...
The batteries are defective in this unit. It should be returned to the dealer that you purchased it from and get exchanged, or your money back. Another way to test this mower is to charge the batteries fully, then test them. If they are truly fully charged, run the mower until it slows down, and test the batteries again. If they are still charged, (unlikely) then the problem is in the motor itself and still should be returned.
Sep 09, 2017 | Worx 17" Cordless Lawn Mower with...
My mower has a key and battery but what for?
What brand of mower? Most lawn mowers with electric start will have a separate charger that you can plug into a standard wall outlet to charge the battery. There aren't many that charge the battery off the mower itself except for some Toro models.
Sep 18, 2012 | Garden
My Craftsman 16 hp and 42 battery not charging is it normal?
get mower started and check the charging voltage at battery. it should be at least 13.5 at battery.check cables to battery and the inline charging fuse, its located somewhere in charging system.if its charging, but battery is still dead. it could be a bad battery. or alternator. . Examine the lawn mower electrical system by starting the lawn mower up, and then removing the battery. If the lawn mower turns off after the battery is disconnected, the lawn mower electrical system is the culprit.
its a good possibility that the battery is bad if it has been in use for 4-5 years.
check the fuses first. good-day !
Oct 02, 2011 | Garden
Mower will run if jump started and continue to run but when turned off and back on will not start until jumped again.Meter does not show mower is charging
The battery needs to be checked.If its running with jump start this indicates that mower is fine but the battery is not supporting it for normal start.In some cases the battery has low charge so getting the battery charged helps.In some cases the battery is dead so battery needs to be replaced.And in some cases the battery is new ,its charged but actually the terminals from the battery gets rusted and do not get connected so this leads the problem.So check the battery,if its low on charge get it charged,if its not getting charged then replace the battery ,if its charged and new then clean its terminals and reconnect and check. But if battery is properly charged and connected properly ,then also you see the same problem then its fault in the starter and starter solenoid.It needs to be checked and replaced.
Thanks. Keep updated for any more query.you can rate this solution and show your appreciation.
Jun 26, 2010 | Garden
I have a troy bilt riding mower, 6 years old, 26
many of these units use the starter motor as the generator to re-charge battery. check voltage regulator & wiring.
Sep 28, 2009 | Garden
Garden Logo
51 people viewed this question
Top Cub Cadet Garden Experts
Tim Whalen
Matt Olenzek
Matt Olenzek
dannydoesita
Are you a Cub Cadet Garden Expert? Answer questions, earn points and help others
