Question about Whirlpool 25.3 Cu. Ft. Side-by-Side Refrigerator with Thru-the-Door Ice and Water - White-on-White
The freezer isn't cold. The refrigerator seems to be working fine.
  • Whirlpool Master
  • 43,501 Answers
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Posted on Nov 07, 2010
I have a haier model # htq18jabww-01 and the freezer seems to b working fine but the fridge does not seem to be cold at all...any soultions??
The "Cold-to-Coldest" adjuster in the freezer steals chilled air from the refrigerator to add more to the freezer. It's a mechanical damper. Set it fully CCW to cold (warmest position). I also put duck tape over half the chilled air outlets in the freezer to increase the chilled air pressure feeding the refrigerator section. Set the thermostat in the refrigerator to 8 or 9 and the freezer works fine and everything in the refrigerator is 38F.
Apr 18, 2012 | Haier HTQ21JABWW Top Freezer Refrigerator
Hi, I have a Samsung refrigerator and the top part isn't cold enough and the freezer is working perfectly fine. I need help fixing the fan.
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
Sep 03, 2011 | Samsung Refrigerators
My refrigerator isn't cooling. The freezer is working fine though. Any suggestions?
heatman101
Jul 07, 2011 | Refrigerators
Freezer appears to be working, but not the refrigerator section - at most that will only get to 50 degrees. Manually switching to propane makes no difference.
Sounds like your cooling fan is out. If the freezer is fine and the fridge isn't, then the cooling fan isn't blowing the cold air the the fridge. Or you could have ice obstructing the airflow.
Jul 01, 2011 | Refrigerators
Freezer part is working fine. fridge part is barely cool on the highest setting
Sounds like your cooling tube ia blocked by an ice buildup or something. Some refrigerators have a fan to draw the cold from the freezer to the refrigerator and if the fan quits, then the cold is not drawn out of the freezer.
If it isn't a frost free freezer then it is probably just a case of needing to defrost the freezer.
Jun 01, 2011 | Admiral Refrigerators
GE TFX 22CR Freezer works but not Refrigerator.
If the evaporator fan isn`t working, the frig will not circulate the cold air needed from the freezer to the fresh food compartment. You will need to remove the panel and check for ice around the fan. Make sure it can turn free. If it isn`t blocked and you can turn it freely and there is voltage going to it, the fan motor has gone bad and needs to be replaced if there.
Nov 11, 2008 | Refrigerators
Whirlpool 25.3 Cu. Ft. Side-by-Side Refrigerator with Thru-the-Door Ice and Water - White-on-White Logo
73 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
