Question about Philips Magic5 Voice DECT Duo - Fax / copier - thermal transfer - 50 sheets - 14.4 Kbps Plain Paper
Phillips magic5 problem
No dial tone on my cordless handset it has worked i have tried to re-register with the fax machine also the handset will ring when there is a call but will not answer when you pick it up i have tried taking out the batteries but it still does not work
  • Anonymous Aug 23, 2008
    I've had the same problem.
    Just place the cordless phone into the wall socket and plug out all cables and plug them back in. It should work afterwards perfectly.
  • Mishmim Oct 11, 2008
    I did as mentioned and it has worked for one of the cordless but not the other.
    It says to register phone and when we do it comes back as not registered. Been trying for 2 days. Manual is a crock to download. After 1/2 hour it downloads ( I have a fast connection) then will not open.
    No contact email address for Sagem.
    Getting really fed up.
Hi, I had this problem and spoke to sagem at www.sagem.com/support.
the solution is simple, turn off your fax machine at the wall, take out your batteries from the handset and leave both off for 15 minutes. then turn on the fax machine and replace the batteries back in to your handset, at it will work.....
Posted on Dec 04, 2008
    Scholar:
  • 130 Answers
Plug the cordless into the wall jack. If dial tone is present, reinsert cordless phones cord into the EXT jack of fax. If no dail tone is present test EXT jack on fax with a regular phone. If no dail tone is present The fax is at fault.
Posted on Jun 16, 2008
There is a "sun" sign
the sun sign is unrelated to the problem. the sun signifies daytime setting pertaining ringing sound asf..
press DIAL immediately and listen whether it is engaged. If yes, fix your phone line.
if no, dial manually. if still unsuccessful come back here.
Apr 01, 2011 | Philips Magic5 Voice DECT Duo - Fax /...
I have a Brother 775 intelli fax machine. I can't send a fax. After loading the document, when I go to push in the fax number, the numbers do not register. I unplugged the machine from the power and the...
Hi there!
For you to send a fax with the Brother Fax 775 you can try these steps:
1. First make sure that you have a dial tone by lifting the handset or just by pressing the hook button. Once you have verified you have a dial tone press the hook button again to return to the main screen or hang up the handset. LCD should display the date & time
If you don't have a dial tone make sure that the telephone line cord is connected on the fax machine's Line jack. If you don't have a dial tone still connect it to another working outlet. If you don't have a dial tone still connect a working telephone on the wall jack to see if you'll get a dial tone. If you get a dial tone on the regular phone then problem is either with the line cord or the fax machine.
2. Once you have the date & time on the LCD screen, Load the document that you want to send on the automatic document feeder which is directly above the LCD screen.
3. The LCD screen should change from the date/time to "Enter Fax No. & Press Start" Once you got this screen dial the fax number and then press Start.
Hope this helps. Rate if it works.
Thanks!
Mar 30, 2011 | Brother IntelliFAX 775 Plain Paper Thermal...
How to replace the inkfilm in my Philips Magic 5 Primo?
hi, how do i register my cordless phone. because i donot have any dial tone.In the book said the cordless tel does not registered with the device. at the moment cordless screen displayed please register. Pls help me how to solve. thanks. khokan
Aug 10, 2010 | Philips Magic5 Voice DECT Duo - Fax /...
No Dial Tone
Dear Sanyte1226,
Double Check that all handsets are registered, and make sure that you don't have to many phones connected to the jacks throughout your home. If all fail, very slowly, make sure the phone is on speaker, and slowly move the telephone port into the jack SLOWLY like slower than slow motion. If you here clicking, keep pushing it in slowly until you here a dial tone. I know this has happened to me before.
Best of luck, The Writer.
Jun 02, 2009 | Uniden DXAI5188-2 Cordless Phone
No dial tone in Clarity C4230 setup
if you can get dial tone with another phone, look into manual for any instructions, usually a toll free number for help. ( BEST ) otherwise take phone back for exchange. may be problem in the board.
Apr 16, 2009 | Clarity C4230 Cordless Phone
No dial tone on handset
It may not be registed with the main unit. You may need to register the handset. With my uniden all i have to do is put it in the main base until it says what handset it is (it should be a number).
If you have any questions please dont hesitate to ask
Sep 25, 2008 | Uniden 2.4 GHz Cordless Phone System
"Unavailable"
you put it on the handset with the answering machine for a few seconds and that is how you register it.
Jun 27, 2008 | Uniden Cordless Phone
Faxmachine
CHECK 1.DO YOU GET DIAL TONE ON -ON HOOK DIAL BUTTON OR ON THE HANDSET ? IF NOT PLS CHECK THE PHONE LINE OTHERWISE--- 2.TRY RINGING THE MACHINE FROM OTHER PHONE,CAN U HEAR THE RING ? IF YES ,PLS CHECK WHAT NOS OF RINGS ,THE MACHINE IS SET TO RECEIVE, AS WELL AS SET THE CORRECT RECEIVE MODE , I.E. FAX /TEL/ANS-FAX... 3 IF U STILL DON'T GET FAX TONE WHILE RECEVING ,THEN TELEPHONE LINE CARD SHOULD BE BAD... TRY REPLACING TEH SAME ,SHOULD RESOLVE THE PROBLEM. HAPPY FAXING OMNIPRESENT HAPPY FAXING
Sep 21, 2007 | Office Equipment & Supplies
Brand new cordless handset -- no dial tone, no ring!
I doubt it's the battery. As I understand it the base works fine and the problem is only with a cordless phone. Are you using an external charger stand for the cordless handset? These phones need to be registered to the base unit. That is usually done by installing the cordless phone in the base unit but you may need to do that shortly after insalling the battery or you could have a register button or setting.
Jun 18, 2007 | GE 27851FE2 Phone
Philips Magic5 Voice DECT Duo - Fax / copier - thermal transfer - 50 sheets - 14.4 Kbps Plain Paper Logo
488 people viewed this question
Top Philips Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Philips Office Equipment and Supply Expert? Answer questions, earn points and help others
