Question about Samsung SGH-A877 Impression Cell Phone
My Samsung impression wont let me calibrate it. It vibrates when i touch the cross but nothing else happens
    Sergeant:
  • 389 Answers
To be honest if you are just now aquiring this phone I would take it back to your celluar provider and show them what's going on and they should give you a new one.[This happens alot.] This small glitch also leads to larger glitches.
Posted on Nov 07, 2010
The calibration on my samsung impression was way off so i used the unlck code *2767*3855# the phone shut down and restarted and at the calibration screen tapped the center of cross many many times cross...
OK..your touch screen was jammed or not working and you did reset via code *2767*3855# then the phone restarted with the calibration cross....you tapped the cross but nothing is happening.......what to do? first shutdown the phone remove the battery for 30 sec also remove the simcard put the battery again start the phone when the calibration screen pops up tap on the cross here you must feel the tapping is working by feeling a light vibration of the phone.....then tap on the lower bar of the screen which has color (light gray) different than the calibration screen the cross will move to another corner......repeat this for all four corners then you should see and OK on the bar to save and exit to the normal screen........done
Jan 03, 2011 | Samsung SGH-A877 Impression Cell Phone
My touch screen stopped working on my samsung impression so i put the rest code in and the phone reset then its now stuck on the calibration screen and the touch screen wont respond
Dont kno if "Impression" is similar to "Omnia" but 'REMOTE SCREEN ALIGNMENT' program installed on PC skips 'align screen' on your phone. Also "welcome.not" (made in notepad) & pasted into your root files. A REGISTRY EDITOR will allow you to input the touchscreen configuration numbers manually. Of course, none of these will be much good if you dont have 'Windows" phone or cant access your Registry!!
If all this fails, ASK 'XDA DEVELOPERS', or 'MoDaCo'.
Oct 29, 2010 | Samsung SGH-A877 Impression Cell Phone
WHen I touch contacts, dial or menu nothing happens. When I go to my call list and touch a contact it opens the contact 3 or 4 rows up.
try and reset the fone's calibration.. go to settings and in their check phone settings u will find a thingy called calibration select it and follow instructions...
Sep 02, 2010 | Samsung SGH-A877 Impression Cell Phone
Impression touch screen is not calibrated and i cannot get to the main menu
go into:
menu, settings, phone, calibration
that how to calibrate it .... even after calibrating it if you still cant navigate to the main menu
All you do is get your vaccuum the handheld part and just go thru the edges as it **** out all dirt and water particles that may exist. It only takes about a minute. After you **** the screen and the back of the phone without taking out the battery the calibration should work again!
If it still doesnt work
turn the phone upside down and drag your finger across the button. I guess what had happened is you used it so much the sensor got pushed down in the black part where it says SAMSUNG.
If it still wont help.... its better to have it checked for any internal component failure.
Aug 28, 2010 | Samsung SGH-A877 Impression Cell Phone
How do you recalibrate samsung impression a877 via codes since the lcd isn't working?
Click on Menu, Settings to access phone settings. once you click on Phone you'll see the item Calibrate click on that and follow instructions. make sure you tap center off cross or you calibration will be off.
Jul 19, 2010 | Samsung SGH-A877 Impression Cell Phone
I am use samsung corby from last five month.but now the touch screen not working prppley
You need to calibrate the touch pad. I believe you can locate that in the settings of the phone. Then calibrate it. Just follow the cross lines by pressing the center of the cross line.
Jul 13, 2010 | Samsung S3650 Corby / S3650 Genio Touch...
I cant acess my setting to calibrate my phone. When i touch the menu button it acts like Im touching the center of the screen. When I try to dial the number using the touch screen it doesnt dial the number...
Ok there might be a battery issue. Or there might need to be a touch calibration reset. To do that go to your settings and select touch calibration and do it again.
ALSO IF YOUR PHONE IS STILL IN WARRENTY AKA WITHIN 1 YEAR OF PURCHASE THEN CALL 1800 801 1101. THEY WILL HELP YOU. YOU WILL NEED YOUR IMEI NUMBER OFF THE BACK OF THE PHONE. IF NOT CALL THE INSURANCE HOTLINE WHICH IS ON THE AT&T WEBSITE.
Jun 24, 2010 | Samsung SGH-A877 Impression Cell Phone
My samsung sgh-a877 wont calibrate correctly. The touch screen is messed up. I tried several hard restores, nothing will fix this, supposedly. Calibrated several times, as well. It keeps getting worse. ...
sir i tried and tested it in chinaphone ,lets see if it also works in samsung...press power key and # , if not works insert a working sim and send message to that sim ...if the phone received the message it will automatically calibrated thanks and goodluck
Jun 12, 2010 | Samsung SGH-A877 Impression Cell Phone
Touch screen is not sensitive on touch
You can change the touch screen vibration settings:
press
-Menu
-Settings
-Phone
Press Vibration Feedback
Set the desired Vibration Intensity setting
Press Save to keep the Vibration Feedback settings
www.usedcellphoneshop.com
May 18, 2010 | Samsung SGH-A877 Impression Cell Phone
Samsung SGH-A877 Impression Cell Phone Logo
119 people viewed this question
Top Samsung Cell Phones Experts
Computer Repairing
Computer Repairing
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
