Question about Sharp Televison & Video
Why can't i see all my cable channels when i do a channel search of analog and digital, do i need a hd cable box for this set
  • 616 Answers
Model # usually helps, probably signal problem
Posted on Nov 07, 2010
Using a digital antenna to channel scan for broadcasted channels
It is no different that channel scanning for cable or analog over-the-air channels. You simply ensure that you have selected the digital tuner of the set prior to scanning. Some older flat panel sets do not have integrated digital tuners. A digital antenna alone will not allow these sets to receive digital broadcast channels. A converter box is needed to convert the digital broadcast signals to analog for the tuner in the set. Also, sets that do not have digital tuners may not support the resolution rate of digital TV broadcasts. Most digital HD broadcasts are 720p and a few are 1080p.
Jul 28, 2016 | Televison & Video
19" Element HD Digital LED TV Model ELEFW195 Does not scan Digital Channels just Analog Channels.
Auto-channel search can't find digital channels - Community ...
community.insigniaproducts.com/...channel...can...digital-channels/.../13...
Aug 6, 2010 - When I ran the auto-channel search it could only find 4 analog ... Notgetting Digital Channels on NS-26L450A11 ... I've plugged the cable from the wall into the TV, and preformed the auto channel scan, with "cable" selected.
Troubleshooting Guide for Digital-to-Analog Converter Boxes
https://www.fcc.gov/.../troubleshoo...
Federal Communications CommissionIf you aren't receiving digital signals on your analog TV, you can purchase a ...antennas are designed only for reception of either VHF or UHF signals (but not both). ...The channel scan will automatically search for digital broadcast channels ...
Antennas and Digital Television ' Federal Communication
Jan 13, 2016 | Televison & Video
The analog tv picks up a lot more stations and correct channels than the LED TV. Is it possible to set the Insignia LED NS-19E320A13 to analog? Is there a device available?
.YES IF ITS A DIGITAL TV U WILL GO TO MENU GO TO ANTENNA CHANGE FROM DIGITAL TO ANALOG OR AUTO ENTER THEN SEARCH ANOTHER WAY GET AN ANALOG TO DIGITAL SET TOP BOX FIX YA ANTENNA TO IT CONNECT TO TV BY HDMI.OR AV CABLES GET THE SET TOP. ON GO TO SCAN OR SEARCH AND YOU WILL HAVE ANALOG CHANNELS ON YOUR LED TV
Oct 08, 2015 | Insignia Televison & Video
Wont find channels on auto channel search
Ensure that you have a good connection to your antenna/cable/satellite, and that you have selected the proper signal type in your TV menu.
If you are using a cable box or satellite, you might need to search for an analog signal on channel 3 or 4. If your cable/satellite box outputs an HDTV signal, then search the digital channels. If you are using an antenna, search for digital channels and set it the TV to Air in the Channel menu.
Apr 07, 2014 | AOC Televison & Video
I need to connect my vcr/dvd combo unit to an Emerson HD TV so that I can record shows. Can you help me?
Most TVs only have audio out and several audio/video in connections. Unless you have an unusual tv, there is no option for a coax connection from the TV to a recorder.
Since this DVD recorder only has an analog tuner, you need to connect it to a set top box to record signals unless you are looking only at analog channel sources. If you are getting OTA, then a OTA digital-to-analog tuner is needed for most channels. (Only low power stations are still broadcasting in analog.) The cheaper ones that were available with the government coupon were SD tuners. HD content will need a separate tuner. If you have cable or satellite, check the signal (QAM is digital cable).
Next connect the coax from your analog source to the DVD recorder coax in and another coax cable to the coax out and the TVs coax in (if you want to - the pass through doesn't work with a set-top box for non-analog signals). Set the channel to the appropriate one (3 or 4 for the OTA d-t-a boxes; desired channel to watch for analog OTA or cable). Set the TV to channel 2, 3 or 4. Alternatively, use composite A/V cables from the set top box to the A/V Input of the DVD recorder and set the recording channel to Input 1.
Next connect A/V cables (composite or S-video) to the recorder's matching out to the TV A/V or S-video In. Set the TV to A/V 1 or Video 1 depending on the Emerson TV. You can watch tapes or DVDs. For better video quality on DVD playback, also connect component video cables from the DVD recorder Out to the TV's component in (if it is available). Then set the TV to the appropriate component video input when watching DVDs.
I hope this helps.
Dec 05, 2010 | RCA DRC8300N DVD Recorder/VCR
My picture is not good. I'm hooked up to digital
to get best picture and sound you need to use HDMI connection. This is normally if you have a HD cable box. If you don't have a HD box, use the coax connection directly from the cable line. On your TV, hit the menu button, use the arrow up/down to select manual channel search, select cable and hit enter. this will scan all the digital and analog channels.
Jun 16, 2009 | Sanyo Televison & Video
Can not get hd channels on my new tv..
First of all, digital/HD signals are broadcast at UHF frequencies. You need to know if you have an UHF antenna and, if you do, that it is pointed to the TV stations broadcasting HD.
Second, since most TV's have a setup mode that automatically searches for channels that are able to be received, go to that "Setup" menu on your TV and start the auto search. It will list both analog and digital stations. Note that the analog channel may be, for instance, Channel 39 but the digital channel will be Channel 39-1. Tune to the "dash 1" channel.
Dec 30, 2008 | Dynex 19 in. LCD Flat-Panel HDTV
Analog/Digital
HDLCD2600 come set for cable. Make sure the tv is set for "tv" or "air" then run the auto channel memory or search feature of the set. If you have the manual it's under "memorizing channels". If your still have problems, call Sansui TV's customer service number 800 289 0980.
Nov 04, 2008 | Sansui HDLCD-2600 26 in. LCD Television
Cable
Don't know where you are from, however, if you are with mediacom or a similar Cable provider, They informed me that their cable box does the converting and will only work when your tv is set to Analog. So, searching for "digital" channels will get you no-where. Set and search channels in analog and you "should" receive digital. Call your local cable provider and see if they tell you the same. Silly question, but are you signed up for digital service???
Feb 11, 2007 | iLO 3200 32 in. LCD Television
HDTV Cable box conflict
This set does not support 480I in the DTV mode, only 480P and 1080I is supported. Try setting the analog setting in the cable box to 480p and that should take care of watching the set in DTV. Most cable boxes have a setting for format changes in the customer menu, depending on the type of box. If you are able to change the format, then the other inputs will not work since they need a 480I signal, as well as VCRs. Another setup could be to use the S-Video cable or Video input jacks to get a better picture in 480I instead of using the cable input. However, when changing from HD to Analog, you will have to change to the correct input on the set as well. Hope this helps.
Dec 24, 2006 | Samsung HCJ655W TV
Televison & Video Logo
22 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
