Question about Frigidaire Electric Dryer
My Fridgedaire dryer FEQB4000FSO beeps 9 times and won't run. The internet blogs say its a bad controll panel. How can I fix it?
3 Suggested Answers
  • 61 Answers
SOURCE: I have a FEQB4000FSO dryer that continually beeps,
first see where the beeping is coming from you might have a load finish alert setting on your dryer as in when it finishes the cycle it beeps but the contacts might have gotten stuck together so they are making the noise always try first unplugging the dryer for couple seconds than if that doesnt help  get the wiring schametics its usually on the inside bottom pannel your panel should have two or three screws on bottom of the bottom panel and check on the wiring schametics if you have the buzzer (probably name used in the schametics) if yes than try to see where it is so you can just disconnect it
but easiest thing to do is just unplugg it and plug it back in after 30 seconds
Posted on Jun 07, 2009
  • 173 Answers
SOURCE: my fridgedaire dryer will beep (cycle signal)
Clean exhaust vent on rear of machine. Could be a overheating alarm going off.
Posted on Jul 08, 2009
I have a whirlpool cabrio gas dryer that take along time to dry. It has a code of F1 stored on it.The dryer vent is clean.Is the control panel bad.
change gas valve coils. for f1 error, if dryer is running don't worry about it. in future if your dryer beeps and flash f1 error you can unplug dryer get main control board out check dry solder on motor control rely it it is dry solder you can solder and you good to go or not solder problem then you need new control board. good luck.
Jan 21, 2017 | Whirlpool Dryers
Dsxh47eg0ww
I would replace parts. It still is cheaper than a new unit. So get the new control panel and do it yourself and save money. The average life of a dyer is dependant only on when the owner gives up. I just serviced on last week that was 25 years old.
Jul 08, 2013 | GE DSXH47EGWW Electric Dryer
My Kenmore elite HE4 quiet pak 9 electric dryer is working, but it emits a constant series of 3 beeps, and sometimes shuts off before the cycle is complete. I have to unplug it to stop the beeping....
You are getting moisture in the control panel buttons. After a while the panel will not function at all. The light in the dryer tub will still come on when the door is open. When you unplug your machine and it sets for awhile you are allowing the moisture to dry and the machine can reset. Some people use a hair dryer to dry out the control panel for a temporary fix. Eventually, you will have to get it replaced once it stops resetting for you.
Oct 25, 2010 | Kenmore Elite HE4 Electric Dryer
I bought the fridgedaire dryer in 2005 and it has to run 3 times for ~40 min each to get the clothes dry. At first I thought it was from the # of turns prior to vent access in my apt (3 elbows and 30 ft...
due to the issue you had in your old home this is what id look for,,,,lint is bilt up in your unit remove the filter and use a dryer brush to clean lint as best you can,,,,,,second remove the vent hose from the back of dryer then with vent OFF try a load to dry if it drys in one setting then you have deturmind the dryer is ok but the vent hose is bad,,finally a bad thermostate or broken heater coil may be the issue and wold needservice,,,try the free stuff first thoe and good luckwww.myabcspace.com/washerwizzards
May 17, 2010 | Dryers
PLEASE HELP! Dryer cuts off and gives an E68 code.
e68 code
this is a fault code that means there is a stuck key on the board you may have to remove the control panel and check the keys if this does not work you may have to replace the panel or control board
Good luck
Oct 05, 2009 | Frigidaire Dryers
I have a FEQB4000FSO dryer that continually beeps, running or finished. The lights flash and I can't reset it...HELP! it makes me crazy!
Jun 07, 2009 | Frigidaire FEQ1442ES Electric Dryer
Beep beep beep
Temporary Fix: unplug the dryer or cut its power at the circuit breaker panel, when not in use. If the dryer alerts/alarms are set to silent and the beeping happens when it's not in use, chances are it's the same beeping you hear when you first introduce power to the unit or press start. This may indicate a short affecting the control board. If you need to press start multiple times to get the dryer started, then the control board components are most likely starting to fail.
Apr 09, 2009 | Maytag Neptune MDE5500AY Electric Dryer
Dryer wont start
look under control panel look for a burned spot or burned wires some thing is throwing the breaker under the control panel one of the controls may be bad with this kind of dryer may have to replace controls
Apr 07, 2008 | Whirlpool GEW9250 Electric Dryer
Frigidaire  Electric Dryer Logo
56 people viewed this question
Top Frigidaire Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
