Question about Frigidaire GLER642A Electric Dryer
Mi secadora arranca pero no calienta da vueltas pero no seca nada la acabo de comprar nueva y no seca.
5 Suggested Answers
SOURCE: NO PRENDE MI SECADORA KENMORE 400
no enciende la secadora kenmore
Posted on May 14, 2010
Master_Tech
  • 770 Answers
SOURCE: Por favor denme respuesta en Espa?ol
There is a thermal fuse on the top portion (side)of the heating element check to make sure it is not open this will not allow the unit to heat also the vent maybe clogged to the outside causing this to blow the fuse check that as well
Sorry I can read and understand Spanish but cant write it
Posted on Aug 05, 2008
heatman101
  • 43501 Answers
SOURCE: la secadora hecha aire frio
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Posted on Sep 13, 2010
heatman101
  • 43501 Answers
SOURCE: mi secadora enciende pero no
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Posted on Jul 14, 2011
Mi ford escape no arranca solo parparea las luces de aviso que las puertas estan abiertas
Buenas tardes amigos tengo problemas con el encendido de mi ford escape 2005 se activa ( el anti lock) ya le cambie antena llave y computadora y el problema persiste? Alguien que me de una ayuda. Antemano gracias.bendiciones.
May 19, 2012 | 2002 Ford Escape
Mi chevrolet inpala 2002 3.4 no arranca y la bateria esta nueva
tengo un impala 2002 y me hacia la falla que no prendia y al final fue un corto en la marcha. le cambiaron el porta carbones y la armadura y funciono excelente
Apr 18, 2012 | 2002 Chevrolet Impala
Mi secadora Whirlpool care II se oye el motor funcionando pero no gira el tambor de adentro
posiblemente sea que la correa del tambor se rompio. tambien pudiera ser que la usaron sin el filtro(lint screen) y se trago una media u otra pieza de ropa y esta atrapada en el abanico del motor o se le rompio la parte tensora de la correa. de todas formas tiene que desarmala para ver que tiene. suerte.
Feb 06, 2011 | Whirlpool Dryers
Tengo un Altima modelo 94, automatico, que cuando se calienta se mata da marcha pero no arranca, al principio creimos que eran los cables de corriente, pero ya lo revisaron y estan bien, las...
Checke los connectiones de la pila , tambien haga seguro que aye connection de la pila negativo al motor y tambien a la cabina o body del mueble ...
Nov 17, 2017 | Nissan Altima Cars & Trucks
MI SECADORA NO ENCIENDE QUE PUEDO HACER? YA PROBE LA ALIMENTACION ESTA BIEN¡
chequea la conexion de entrada de la secadora es muy probable que los cables esten dañados si no es eso chequea el push on o el interuptor de la puerta que cierre contacto si no es eso chequee los sensores termicos de la secadora que si estan en mal estado no enciende
Aug 16, 2010 | Frigidaire Dryers
Feb 15, 2010 | Kenmore 400 6942 Dryer
Problemas con el arranque de la maquina
Suena como si estuvieras usando los valores equivocados. Usa la opción llamada "Default settings". No son las mejores opciones para darte el uso óptimo, pero te aseguran que arrancará y funcionará normalmente. Debes entender que el usar valores incorrectos causa que el sistema se vuelva inestable, o que deje que funcionar completamente.
Refiérete al manual del tablero, para estar mejor enterado de qué cosa afecta cada valor que estés intentando usar.
¡Buena suerte!
Nov 25, 2009 | Soyo SY-P4VGM Motherboard
Jul 21, 2008 | Whirlpool LER4634J Electric Dryer
Frigidaire GLER642A Electric Dryer Logo
622 people viewed this question
Top Frigidaire Dryers Experts
Marvin
Marvin
Sal De
Craig Butler
Craig Butler
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
