Question about Sony KDL32EX500 32 in. TV
Our Sony TV was turned off this morning. Now when we try to turn the TV on the standby button is flashing and we get no power to the TV. Our remote also is not working on the TV. Is there a reset button or something? We have tried unplugging it and waiting for a period of time with no success.
  • Sony Master
  • 8,457 Answers
Sorry,there are no resetting button,unplugging,waiting for a period of times,ruplugging tv it back that is ur reset back to the factory setting.Tv have the same problems,not working.The power supply board have problems,it dying.That the board,where the power a/c cord plug into it.Tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.
Posted on Nov 07, 2010
Mum pressed some buttons on amp now the amp wont respond to the original remote or the universal remote. buttons wont work, batteries good and lights up. is there a button that blocks ir signal?
Looking at the user guide it appears that the amp has a standby mode.
See not below on turning standby on. Question can you see the standby light flashing.
I would also suggest using function on the amp to remove any possible issues with the remote.
One would expect the system to return to normal operation by pressing the power button again. If not what do you see on the display.
Note:
Press 1 to turn on the receiver.You can also turn on the receiver using 1 on the remote control. When you turn off the receiver, press 1 again. "STANDBY" flashes on the display panel. Do not disconnect the AC power cord (mains lead) while "STANDBY" is flashing. This may cause a malfunction.
Jul 08, 2017 | Sony Audio Players & Recorders
My sony kdl-46v3000 standby light blinks 5 times tv wont turn on
The TV enters standby mode when there is no signal for 30 seconds. https://docs.sony.com/release/KDL46V3000.pdf
I searched standby using Ctrl+F and found this information. It seems you should be able to bring it out of standby using the power button on the remote. You want to make sure there is an input connected and if it is connected to a PC that the PC isn't telling the TV to go into standby.
Try pressing the input button and changing inputs once you press the power button and the Standby is flashing.
If this doesn't work you may need to contact Sony Support.
1-800-222-SONY(7669)
Apr 10, 2014 | Sony Bravia V-Series KDL-46V 46 in. LCD...
Bush lcd32f1080p
Probable power supply failure.
Mar 13, 2014 | Televison & Video
TV Turns Off On Its Own
Standby light flashing is error sign and shows tv got problem some where in its circuit boards.
You will notice 3 seconds long pause between red standby light flashing so count pause to pause and post how many times it flashing to diagnose problem of tv.
Thanks.
Jul 01, 2010 | Sony KP-65WS500 65" Rear Projection...
Sony Trinitron Wega Standby blinks & the TV won't turn on
Those blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
http://electro-medical.blogspot.com/
http://homenol.blogspot.com/
If blinks continue without any pause, the main board is faulty.
Search the site by type in the "brand name" to your device, in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Apr 12, 2017 | Sony FD Trinitron WEGA KV-32FS120 32" TV
How to turn standby off
The TV circuit may have detected a problem within its parts. You may have to check some leaking capacitors in the board or loose solders or burned components just to make sure. Normally leaving the TV unplugged overnight should reset it.
Sep 07, 2009 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Sony Trinitron
I am having the same problem my tv will not turn on all of the sudden, standby light flashing, cnnot get it to do anything
Jun 08, 2008 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Open Questions:
Sony TV EX500 32 inch was not turning on Turned on with below SOny TV support: 12:09 AM Connecting... 12:09 AM Connected. A support representative will be with you shortly. 12:09 AM Support session established with Pamela - (C4IC). 12:09 AM Pamela - (C4IC): Hi. Welcome to Sony Online Support. I’m Pamela. 12:09 AM Customer: Hi 12:09 AM Customer: I am facing problem with my SONY tv 12:09 AM Customer: power on problem 12:10 AM Customer: I purchased it 1.5 year back 12:10 AM Pamela - (C4IC): I understand that the TV is not turn ON and the light is blinking. Is that correct? 12:10 AM Customer: till now i had problem with HDMI only. 12:10 AM Customer: Yes 12:10 AM Customer: yesterday screen started blinking 12:10 AM Customer: but after few mins, everything was fine 12:11 AM Customer: but today when i turned it on, i saw same thing. 12:11 AM Customer: So i did factory reset 12:11 AM Customer: and now it doesnt turn on 12:11 AM Customer: it was responding to menu after turning on. but blinking. 12:12 AM Customer: I turned off ambiant sensor from menu. 12:12 AM Customer: now it doesnt turn on even for a nano second 12:12 AM Customer: red light is blinking. 12:12 AM Customer: when i press power on, it show green and immediatly red ligh 12:12 AM Customer: what do i do 12:13 AM Pamela - (C4IC): Thanks for all the information. I will assist you in this regard. 12:13 AM Pamela - (C4IC): Are you with the unit now? 12:13 AM Customer: yes 12:14 AM Pamela - (C4IC): I am going to ask you some additional questions, in order to determine what is causing the TV not to turn ON. 12:14 AM Customer: ok 12:14 AM Pamela - (C4IC): Let me know the # of times the standby light blinkng on the frpont panel of the TV. 12:15 AM Customer: i have to check 12:15 AM Pamela - (C4IC): Sure, please go ahead. 12:16 AM Customer: i plugged power cable to switch 12:17 AM Customer: it showed red light 12:17 AM Customer: then i click power on on my remote 12:17 AM Customer: it showed green on tv 12:17 AM Customer: in few milliseconds , i heard a sound.. 'tnn' 12:18 AM Customer: then green light turned to red and screen is black 12:18 AM Customer: it is blinking continuously for 5 times 12:18 AM Customer: then a pause of a while 12:18 AM Customer: and then again 5 times blink(in red light only) 12:18 AM Customer: then pause 12:19 AM Customer: and so on...blink continue in sequence of 5 12:19 AM Pamela - (C4IC): Thanks for the information. 12:19 AM Pamela - (C4IC): Let me know if the TV is connected to a surge protector or to a power strip. 12:19 AM Customer: power strip 12:20 AM Pamela - (C4IC): Let's try power resetting the TV and check if that helps. 12:20 AM Customer: how do i do that 12:20 AM Customer: ? 12:20 AM Pamela - (C4IC): First, turn OFF the TV. 12:20 AM Pamela - (C4IC): Then, disconnect the power cord of the TV from the wall outlet for one minute. 12:20 AM Pamela - (C4IC): After one minute, reconnect the power cord directly to a different known working wall outlet without using any power strip or surge protector. 12:20 AM Pamela - (C4IC): Then, turn ON the TV and check. 12:22 AM Customer: turned on... green light is there..after few milliseconds, there was a brightness on tv but with a sound, it turned in black screen and green light turned to red 12:22 AM Customer: n red light blinking 12:22 AM Pamela - (C4IC): Did you try connecting the TV to a different wall outlet? 12:22 AM Customer: ok.. trying 12:23 AM Pamela - (C4IC): Okay, please go ahead. 12:25 AM Customer: A different behavior this time 12:25 AM Customer: i attached tv power cable to a power strip and power strip to different wall outlet 12:25 AM Customer: now turned on 12:26 AM Customer: green and yellow both lights are blinking 12:26 AM Customer: nothing there on screen 12:26 AM Customer: its black 12:26 AM Customer: this time it has not turned to red 12:26 AM Customer: yellow and green lights are blinking 12:27 AM Pamela - (C4IC): Please connect the power cord directly to a known working wall outlet without using any power strip or surge protector. 12:27 AM Customer: ok 12:29 AM Pamela - (C4IC): Let me know the status of the issue. 12:29 AM Customer: i put power cable on different port 12:29 AM Customer: wall outlet i mean 12:30 AM Customer: this time TV came up with green light 12:30 AM Customer: stream is there on tv screen 12:30 AM Customer: but it is blinking a lot 12:31 AM Customer: same problem which i saw since yesterday 12:31 AM Customer: TV channel stream is playing properly but screen is blinking 12:32 AM Pamela - (C4IC): Unfortunately the available troubleshooting has not resolved your issue. 12:32 AM Pamela - (C4IC): Based upon these results, it appears that the issue can be resolved only after physically examining your TV. 12:32 AM Pamela - (C4IC): Therefore, I suggest that you contact our authorized service technicians to get the unit physically examined. 12:32 AM Pamela - (C4IC): May I have your area zip code so I can check if there are any Sony authorized service locations near you? 12:32 AM Customer: 201301, noida, in India 12:33 AM Pamela - (C4IC): Thanks for the information. 12:33 AM Customer: Yes, i purchased TV from authorized SONY TV showroom. They must be providing service. I am not very sure 12:34 AM Pamela - (C4IC): In that case, I will forward a link to the page where you can find the contact information about the Sony service center in India. 12:34 AM Customer: what actually problem earlier... you asked to change port and now TV turned on... why so, is there any fault with that wall outlet.. I daily connect to same wall outlet.. 12:35 AM Pamela - (C4IC): Yes, there may be some power conflict. 12:35 AM Customer: today when i connected to same port, TV didnt turn on... but after your steps, TV turned on.. 12:35 AM Customer: power conflict?? 12:36 AM Customer: what does power conflict mean? 12:37 AM Pamela - (C4IC): Power conflict may be some issues with the wall outlet to output the power. 12:37 AM Pamela - (C4IC): I will forward a link to the page where you can find the contact information about the Sony service center in India. 12:37 AM Pamela - (C4IC) has sent a link: http://www.sony.net/SonyInfo/Support/ 12:37 AM Customer: My TV is just few inches above my refrigerator.. and these days due to hot weather outside, i have set refrigerator on high power. 12:37 AM Customer: could it be a reason? 12:38 AM Customer: i heard there is a humadity sensor, n due to more humadity, TV doesnt turn on.. i read on internet, people use blow dryer and vaccum cleaner to reduce humadity and to turn on their TV, when they face this problem 12:39 AM Customer: is it right way? 12:39 AM Customer: Many people solved problem this way... i havent tried because i dont have blow dryer.. could humadity be a reason on not turning on? 12:40 AM Pamela - (C4IC): It is not recommended to operate the TV below 41 degree Fahrenheit (5 degree Celsius). 12:41 AM Customer: Temp here is 32 celsius these days in night. 12:42 AM Customer: I will call TV service senter to repair blink problem... do u have any troubleshooting guide for blink problem? 12:44 AM Pamela - (C4IC): We have tried the possible troubleshooting steps. 12:44 AM Pamela - (C4IC): I suggest that you get the TV physically examined by the service technician to kno
May 17, 2012 | Sony KDL32EX500 32 in. TV
Sony KDL32EX500 32 in. TV Logo
510 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
