Question about Bosch 24 in. SGS43C12 Classixx Free-Standing Dishwasher
I have a Bosch Classixx SGS43CO2GB which is working but not heating the water or drying? Is this something I can fix myself, and if so where could I get another heating element? THanks
  • 1462 Answers
SOURCE: bosch classixx slimline dishwasher not running through cycle
fault is that there is a leak. the tray at base of dishwasher is full of water which operates a float and turns on drain pump. tilt over 45deg and water will run out and then it will work or remove bottom front panel and mop out (better). then find leak
Posted on Mar 20, 2007
daddy1264
  • 76 Answers
SOURCE: How do I replace the heating element for a Bosch SHU53 dishwasher
are you sure its the element, the control boards on them get bad soldering joints and the you get the impression that the element is bad, but its the solder joint that controls the element that goes bad....you can resolder that
Posted on Dec 30, 2008
SOURCE: Bosch dishwasher not 'steaming' plates dry
My Bosch dishwasher used to give off loads of steam when I opened the door after it finished it's cycle-now there is no steam and the plates etc are cold and not dry...Does this sound like the heating element? This dishwasher is approximately l0 yrs. old (built in).
Posted on Apr 30, 2009
  • 457 Answers
SOURCE: water not heating up in my Bosch classixx
your water temp is noot correct. the heater only really maintains the temp it does not raise the temp from cold to hot. if this is helpful send me a 4thumbs up post.
Posted on Feb 28, 2010
  • 167 Answers
SOURCE: bosch classixx dishwasher saying check water also
Bosch dishwashers have a food filter to catch food particles. You have to clean it occasionally, or it plugs up and stops water flow. This could be your problem. (Most other makers use a little grinding blade to finely chop the particles so they can be sent down the drain.)
Posted on Oct 04, 2010
Bosch classixx dishwasher not heating water on cooler wash works on hot wash
Most dishwashers don't heat the water. They run on whatever temperature water you have it set for. They have heating coils on the bottom but that's for drying, not heating up the wash water.
Nov 30, 2014 | Bosch 24 in. SRS43C12 Classixx Slim-Line...
Problem heating and water getting hot
You have a faulty element. Please replace it.
Mar 12, 2014 | Bosch 24 in. SGS43C12 Classixx...
Bosch Classixx dishwasher fault
it can be a dry joint on the electronic board, or a defective thermostat, or the element, or an interrupted wire in the lower point of the door
Dec 23, 2013 | Bosch Dishwashers
Why does my Bosch Washing Machine (Classixx 1400) no longer heat the water? I have already tried replacing the washer heating element.
This video will show you how to replace the Bosch washing machine heating element and thermostat with step by step guide on the process
Jun 10, 2011 | Bosch Classixx WVF 240S Front Load Washer...
Our Bosch Classixx Condenser Tumble Dryer works but there is no heat. I have cleaned the Condenser Unit and the filter and emptied the water, but still no heat. Please advise. Thanks Craig
my wte84105gb condenser dryer (bosch) as a symbol on it looks like a glass with wavey lines inside it will not dry please advise what to do .
Feb 26, 2010 | Bosch Axxis WTA4400 Dryers
Bosch Classixx 1000 Express washing machine won't fill with water
cheak the filter witch is at the intake and if when it is going to fill does it buzz if dose that means the vale is working if not call a repaire man out hope this helps
Jan 22, 2009 | Bosch Classixx WVF 2402 Front Load...
Bosch Classixx condenser dryer not heating and turns itself off.
Most likely the heating element or a thermostat.
Oct 12, 2017 | Dryers
Bosch classixx 1200 express
Not a programme error but carbon brushes on motor.Fixed by local engineer.
Aug 30, 2008 | Bosch Classixx WFC 2465 Front Load Washer
Bosch classixx 6 1200 washer
Problem will be ... machine will use your hot water during the rinse cycles! So, No.
Aug 14, 2008 | Bosch Classixx WFL 2066 Front Load Washer
Bosch classixx slimline dishwasher not running through cycle
Mar 17, 2007 | Bosch 24 in. SRS43C12 Classixx Slim-Line...
Bosch 24 in. SGS43C12 Classixx Free-Standing Dishwasher Logo
113 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
