Question about Hoover Vacuums
How do you install the torsion spring onto the front wheel unit of a Hoover vacuum, model U5760-910? Thanks!
Also,the manual for your vacuum is available online at http://www.hoover.com/CustomerService/Manuals/Default.aspx.
Posted on Nov 07, 2010
  • Call me T Nov 07, 2010
    The wheel plate and torsion spring had popped off and I wasn't sure exactly how it went back on. The comments in the illustration were very helpful!
    Thanks!
I had an electrical problem with my Hoover U5753960 upright vacuum which I resolved; however, after putting the unit back together I was left with a circular spring with a hook on one end and a straight...
Hello, francis
I was trying to help you out here. Maybe this will help some? I was going back to some customers that asked questions in the recent past and even farther back. It appeared that no one answered some of them, So, I thought I would take some of my own personal time
to see if I can help. Even though this a Informational site may not have your exact model or brand, But this site will help you a lot. Here is the site link about everything you want to know about vacuum cleaners and possibly yours, from repair to trouble shooting it.
http://home.howstuffworks.com/vacuum-cleaner.htm
Please if this helped you at all, if you can find the time and in your heart to rate my help and some kind words written would be appreciated for my free help, I would appreciate it. Like I said I just tried to help, If anything this is good information for future problems. If you felt that my free help was a waist of time for you, I'm sorry.I do not get paid to help people on the site, I do it cause I like to help.
Here is also my direct link to my own pages of other areas of my expertise for other problems you might have in Automotive, Appliance, and Electronics. Drop In anytime for my help.
Thanks, Mike
http://beta.fixya.com/users/mc1bean
Aug 23, 2011 | Hoover U5753 Bagless Vacuum
The wheels with the spring broke off and I'm trying to put a new one on but I don't know where the spring goes.
This spring can be very confusing to install. It slides onto the wheel assembly near where the attaching pin is longer ( there are flat protrusions on both sides of the wheel assembly). One end of the spring pushes up on the assembly when it is in place, and the free end must be pulled down and inserted into the small slot in the bottom of the base. Pull down on the shorter end of the spring, holding the longer end, and slide it onto the round area on the wheel assembly. As you put the wheels back on, pull on the longer end and insert it into the slot in the base.
Jan 24, 2011 | Hoover Tempo Widepath Upright Vacuum -...
Need a front wheel assembly for my Hoover Tempo model u5144-900. I see similar looking Hoover wheel assemblies online for different models, will they fit mine?
The Tempo series cleaners look similar, but are different colors. The wheel assemblies will work if they look identical in appearance to yours.
Aug 07, 2009 | Hoover U5144900 / U5146900 / U5147900...
How to install spring
on this machine the spring goes to the front wheel assembly under the machine. if this has came off then the wheel assembly is broken. i believe the part # is 36432027. hope this helps
Jul 27, 2009 | Hoover U5753-900 WindTunnel Bagless...
Hoover 5470-900 no longer contacts carpet with beater brush
your floor adjustment spring is broken there is a plastic slider and clip if it is broken the height adj will not work you should get a new vacuum because this repair can cost as much as a new vac.also this is a common problem with the hoover brand I would get a sebo or an oreck they have a great warrentty and you will more than likly never buy a other vac.
Jan 24, 2009 | Hoover U6437-900 / U6439-900 Windtunnel...
Hoover front wheels replacement
on the wheel assembly you will see on each end the studs with the flat ends on them,slide the studs in the slots and fold wheels forward and push in.in the middle at the front of the wheels you will see a flat catch ,push it up into the base right behind the brush roller and it will snap in
Oct 04, 2008 | Hoover Elite U5061-900 Bagged Upright...
I have a Hoover Steam Vac V2, model #F7430-900. The spring loaded valve on the soap dispenser needs replacing -is this possible or do I have to get the entire tank. Thanks
Hoover Steam Vac V2, Model #F7430-900
Thanks
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure.
You cannot replace the spring loaded value on the soap dispenser – it is a whole assembly and would need to replace the entire tank, you can buy them new or sometimes a local vacuum dealer may have a good used one on hand and that would work as well – check the yellow pages for a local vacuum dealer or Hoover dealer for replacement of the part.
http://www.hoover.com Telephone
Contact our Customer Service Department at 1.330.499.9499
Monday through Friday
8 a.m. - 7 p.m. EST
Apr 16, 2008 | Vacuums
How to install front wheel assembly on Hoover Bagless windtunnel vaccuum
There is a spot that sticks up on the holder for the wheels, the hole in the spring goes there, then it fits between the holder and the base asm.04f5295.jpg
Feb 24, 2008 | Hoover U5753-900 WindTunnel Bagless...
Wheel carrier spring
What is the correct model number???
Feb 23, 2008 | Hoover F7425-900 SteamVac V2 Widepath...
Vacuums Logo
2,124 people viewed this question
Top Hoover Vacuums Experts
Jim Parker
Jim Parker
Kirk Thompson
Level 1 Expert
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
