Question about Casio Parts Cash Register PC Desktop
Casio QT - 2100
Last night when trying to complete end of day reports, the till seems to have locked. It makes a noise when you touch the buttons but does not change screen it is stuck on were it was at last night. \I have turned it off and on but no luck...can you help?
  • 737 Answers
Hi.
Firstly, make sure you have the keyboard cover on the correct way, and it is seated securely. If you are on a different side of the keyboard, it won't operate correctly.
Otherwise, you can try a flag clear. This will jump the machine out of the current task, and drop you to REG mode.
Turn off the power under the machine.
Hold the TOP RIGHT CORNER button down. It doesn't matter what is on this button. It will usually be one of your items.
While holding, turn the power on again, and wait about 2 seconds. You will see a copyright message on the display.
Now let go of the button, and press the RIGHT side of the SUBTOTAL button (it is a double size button, so press the right hand end of the button).
The machine will check files. Wait until you see 'Flag clear' on the display, and press the YES button.
When the machine reaches REG mode, log a clerk on, and you should be away.
If you have any problems, just let me know.
Mark
Posted on Jun 23, 2008
How can i get my te m80 till to print it was printing but now nothing on the paper my grandchild was plying with buttons
If it still prints an end of day report, the receipt is probably turned off (press PAPER SAVING button).
If the end of day report comes out blank, make sure you have the shiny side of the paper to the front (only prints on one side). If those things are not the problem, it is probably time for a new printer. The Seiko printers in that model were total rubbish and frequently need replacing if you print a lot.
May 13, 2015 | Retail Supplies
Casio qt 2100 e061 printer error .... hallo can you help
Since this question is still open, the error means the printer was not found. The cables and printer connection should be checked (or a faulty printer of course). If anyone needs the Casio QT-2100 manuals, one of the users has them here:
http://the-checkout-tech.com/manuals/cashregisters/Casio4.php
Jun 10, 2014 | Casio Parts Cash Register PC Desktop
On front screen its come up with "Unfortunately, system UI has stopped" report or ok. But it wont let you do any thing. I only just set it up last night. It wont even let you turn it off completely.
After researching about this online, it seems to be a software update issue. You can try to do a factory reset, and if you can get into apps, you can try downloading a "face lock" app, which seems to help as well. I hope that this helps!
Oct 28, 2013 | ASUS Google Nexus 7 Tablet
Casio qt 2100 programming I/O for epson tm-t88III
I haven't worked on the 2100 for years but I know you can't use a TMT88 series as a slip printer. The TMT88 is for receipts or kitchen. If you want to print special slips, you would need to get a dot matrix slip printer. This model is compatible with the SA-3015 and SP-1300 Slip printers.
Feb 21, 2013 | Casio Parts Cash Register PC Desktop
Screen has frozen Casio qt 6600
flag clear the till, and try again,
if it is a long report the till will stop and then start
flag clear power off the till on the side
hold the button down at the front
power on the till
press the ok button
then after 30 sec to 3 min
press yes
Feb 09, 2013 | Casio QT-6600 Cash Register Touchscreen...
Got casio qt2000 till, using hospitality 1.35 build 181. Single connection to PC com3:, no printers terminal only and cash draw. Simple single bar senario, Drinks, Read takins and item groups at end...
I think you enter date in std Casio format: PGM1 mode, Type YYMMDD then press X/TIME button
If you go to Z mode and try a report, what happens?
If anyone needs a manual for a Casio QT-2000, C-tech collective have User/ Programming, service manuals here: http://the-checkout-tech.com/manuals/cashregisters/Casio3.php
Dec 01, 2010 | Casio Parts Cash Register PC Desktop
Hi, i m looking for casio till qt-2100 button sheet
What do you mean by button sheet? Do you mean the clear plastic that goes in the menu sheet holder, or the paper sheet with the alphabet on it for programming (programming keysheet), or the paper sheet that has your products written on it (menu keysheet)?
Oct 14, 2010 | Casio Parts Cash Register PC Desktop
Qt-2100 wopnt turn on
Try this first:
Turn power off at wall.
Hold the top right corner button on the keyboard (usually an item button. must be top right button) keep your finger on it.
Turn power on at wall and wait 5 seconds.
Let go of button.
You should see a copyright message on the screen.
Press the right hand part of the subtotal button.
Wait until it asks to flag clear and press YES button. It should arrive at the logon screen. Now log on and try it.
If anyone needs a Casio QT-2000 or QT-2100 manual, go here http://the-checkout-tech.com/manuals/cashregisters/Casio3.php
Sep 29, 2010 | Casio Parts Cash Register PC Desktop
2001 Dodge Grand Caravan. has been making a loud whining noise for about a week. started slipping last night. seems to get worse when going from a complete stop and when shifting into gears. other than...
MOST LIKELY HAS A PLUGGED TRANSMISSION FILTER.
TORQUE CONVERTOR CLUTCH FAILURE COMMON.
CHANGE TRANSMISSION FILTER AND ROAD TEST.
IF NOISE IS GONE AND RUNS NORMALLY, CHANGE TORQUE CONVERTOR AND RESEAL TRANSMISSION.
May 19, 2010 | 2001 Dodge Grand Caravan
Casio Parts Cash Register PC Desktop Logo
136 people viewed this question
Top Casio Retail Supplies Experts
Electroboy
Electroboy
Gareth Cockram
Gareth Cockram
Are you a Casio Retail Supply Expert? Answer questions, earn points and help others
