Question about Mitsubishi MSZ-A12NA Air Conditioner
How to turn heat on for split system MSZ GE 12NA
  • Mitsubishi Master
  • 43,501 Answers
Here is a tip about Mitsubishi Air Conditioners and how to get the manuals forall of the Mitsubishi line. The manual include both troubleshooting andinstallation.
Mitsubishi Air Conditioner Troubleshooting and Repair
heatman101
Posted on Nov 07, 2010
Need to help elderly mother learn to operate. I am in another state. She cannot understand the brochure and I do not have access to it or the unit. Where can I find directions for MS2-GE that I
Your question seems to be cut off at the end. If you have a Mitsubishi MSZ-GE60VA, MSZ-GE71VA or an MSZ-GE80VA model split unit air conditioner, here is a link to the manual online. If you have another model you can either post that information here or do an online search with the model number and "manual" in the search.
Jan 10, 2015 | Heating & Cooling
Mitsubishi air con msza24yv. when we turn it on to the heating mode the operation light keeps blinking and nothing happens
Wait 5 mins after turning the unit on to make sure it is not on a pre heat, and if problem is still there check fault code on controller
Jul 04, 2011 | Mitsubishi MSZ-A24NA Split System Air...
I have an air conditioner Mitsubishi MSZ-A26YV, it has stopped heating, even if it's on the heat setting [sun emblem] and is set to highest temp, only cold air comes out, otherwise it does all other...
It's not indicated to turn directly from cooling mode to heating mode. You must wait about two or three minutes before the change. After the spliter start, you must wait few minutes to get hot air.
Mar 30, 2011 | Mitsubishi MSZ-A24NA Split System Air...
I have a Mitsubishi mini split system heat pump model MSZ-A12NA. The problem is the wireless remote has been lost. How do I get another one? Or, can a regular hard wired heat pump thermostat be used? I...
just lift the filter panel on front of indoor unit and turn it on manually,remember this just sets the a/c to 24 deg,the unit decides whether to heat or cool it to 24 deg....at least it gets it goin so u can order a replacement
Feb 21, 2011 | Mitsubishi MSZ-A12NA Air Conditioner
Our mitsubishi split system heat pump MSZ-A 12NA is emitting an odor - swamp water smell.
Usually if you get a musty smell, the unit is short cycling. This means the compressor is coming on, then turning off for a couple minutes, then coming back on. The best way to tell if this is the issue is to turn the unit way down stand outside and see if the compressor is turning on and off. If it's staying on, let me know and we will go from there.
Sep 28, 2010 | Mitsubishi Heating & Cooling
MSZ-A24NA Split System Air Conditioner: it stopped heating, air comes out but no heat, brr...
Is it defrosting??? Your problem is quite brief and that is the only advice that I can offer based on your question.
Hope this helps I take the time to answer your question so please rate me
May 18, 2010 | Mitsubishi MSZ-A24NA Split System Air...
The heat is not getting hot and keeps turning off
Here is where you can find all the info you will ever need about Mitsubishi Air Conditioning units...
Check out this tip that I wrote about that...
http://www.fixya.com/support/r5643983-mitsubishi_air_conditioner
heatman101
Jan 31, 2010 | Mitsubishi MSZ-A15NA Split System Air...
What sq m is covered by a MSZGA71KIT split air con?
That should cool up to a 60 metre squared room. I would have the room measured up by a professional and they will also calculate heat loss and recommend the right unit for the job.
Hope this helps I take the time to help you so please rate me
Dec 13, 2009 | Mitsubishi MSZ-A15NA Split System Air...
Mitsubishi MSZ-A12NA Air Conditioner Logo
447 people viewed this question
Top Mitsubishi Heating & Cooling Experts
D. E. Hev
MightyMikeJr
Are you a Mitsubishi Heating and Cooling Expert? Answer questions, earn points and help others
