Question about Dryers
I have a Whirlpool dryer estate and we have to keep dyring our clothes a couple of times what is wrong with it and how to fix it
  • Dryers Master
  • 43,501 Answers
If your dryer is not drying like it once did or if you just have nottaken the time to give yourself a clean dryer in a long time then youneed to do that. At least once a year the dryer cleaning should takeplace. Lint build up in the dryer duct is one of the main causesfor your dryer to fail.
Here is the rest of this tip about DryerMaintenance
heatman101
Posted on Nov 07, 2010
Dryer slow to start. push button several times to get started. pulls heavily on electricity and causes 120 surge protectors to pop. any ideas?
are you overloading it with alot of wet cloths , you cannot put a ton of cloths in a dryer , try this first , make sure the filter is clean out ,and even the exaust pipe is not clogged either
Mar 07, 2015 | Estate by Whirlpool EED4400WQ Estate 29in...
Dryer twists and knots up clothes
Many times, many types of Dryer have a variety of paddles. There are so many different ones, without your model, it's hard to know which your has, however, I have known many people that have had these problems.
  1. knots clothing;
    Solution: I have heard and seen a couple tennis balls or even a soft pair of tennis shoes used in the dryer whilst drying clothes keep this from happening. (again, the paddles make all the difference) I myself have always had Maytag, but even they are not what they used to be, however, the shoe trick works when we dry our large blankets and comforters.
  2. Length of drying time;
    Solution: Gosh, there could be many issues, but the first, I would think you either have too small exhaust tube, or it is kinked, smashed or the wrong type. Even the smallest of kink or flattening on many exhaust tubes will greatly effect the output of the exhaust. The only other thing could be overall length of exhaust, and possible clogging in the tube. Have a idea for a fix there as well. (if this is the rpoblem.
If you would like further discussions or ideas, please post here, and be sure to add as much info on dryer as you can, including year purchased and model number.
If the drying time has anything to do with my immediate thoughts (had similar problem when I just moved and reinstalled my own Maytag) I have a great fix to keep it from happening.
Whirlpool has been a good name for some years, in fact, they own Maytag now, so I am sure we can solve your issue as long as it isn't a problem with your particular unit itself as they do make a lemon evey now and again.
Aug 31, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Clothes Not Drying well
HI, Check the following to address this issue further.
Note: Normal drying time for a dryer is about 45 minutes (some may take up to an hour).
1. Venting
Make sure the dryer vent hose, as well as the rest of the vent duct, is not clogged.
Unless regular maintenance is performed, chances are there is a lot of lint accumulated inside the dryer. This might affect the drying time and could be a fire hazard. Make sure to have your dryer cleaned regularly. Because this might involve taking most of the dryer apart, it is recommended to have a qualified appliance repairman perform this task.
2. Thermostat
There are a couple of cycling thermostats inside the dryer. If one of them breaks down, it might affect the dryer's performance. Replace the defective thermostat. These thermostats are located in the dryer vent duct and sometimes mounted on the blower assembly as well.
Jul 31, 2009 | Whirlpool Dryers
Dryer not drying clothes
An easy way to check dryer function is to check the airflow on the outside of your home at the exhaust the vent. While the dryer is running, and hot, put your hand near the outlet. The air coming out should be hot and forceful. If not, there is most likely an obstruction, and the whole airway should be cleaned. Keeping the airway clean and clear can dry clothes faster and save you money.
Another possibility is the blower,(fan) which can become encrusted with lint, preventing it from moving air. This is much less likely, but still a possibility.
Dec 09, 2008 | Whirlpool Estate TAWS750PQ 27-Inch Washer
No puilot on.
U must rmove the whole front of the dryer to get to the pilot. Good luck.
Oct 17, 2008 | Estate TGDX640JQ Gas Dryer
We have an Estate Whirlpool clothes dryer/Model #MY60-G which was purchased (I think sometime in 2002?). It spins, but after it is on for a little while the heat stops and the clothes never dry. We were...
gas dryer ? replace the 2 coils on gas burner the 2 black round dohickys..electric possible bad operating thermostat remove back round object on blower housing
Jul 08, 2008 | Whirlpool Dryers
My whirlpool estate dryer tub will not rotate
which pulley came off the one on the motor, or the Idler wheel that keeps tension on the belt. You probably will need a belt
May 26, 2008 | Estate TGDS840JQ Gas Dryer
Dryers Logo
49 people viewed this question
Top Dryers Experts
