Question about Dryers
How do I hook up a 3 prong cord to whirlpool LEQ8000JQ2 model?
  • Dryers Master
  • 43,501 Answers
Here is a tip that will help you with changing your dryer plug. Dryer Cord and Wiring Dryer 3 Wire or 4 Wire
heatman101
Posted on Nov 07, 2010
My dryer has a four prong plug my house is set up for a three prong how can i hook it up
You need to change the cord on the dryer to a 3 prong. Here is a link that should help
Replacing a dryer cord
Dec 10, 2010 | Whirlpool Dryers
I have a dryer with 4-pronged plug and just moved to a home with a 3-pronged outlet. Can I buy a 3-pronged cord to use with my dryer?
Yes, you can convert your 4 wire to three wire.
Go to the following website for the way to hook it up, it is easy.
This is a free answer, Please rate me
http://www.selfhelpandmore.com/switch-outlet/dryer-circuit-wiring-and-hookup.php
Oct 16, 2010 | Whirlpool Dryers
How do i hook a 4 pronged cord into a 3 pronged dryer
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
heatman101
Aug 23, 2010 | Whirlpool LER5636P Electric Dryer
I am changing out the dryer cord on my Whirlpool electric dryer from a 3 prong to a 4. there is a green wire with a yellow strip coming from the dryer and grounded on the side of the dryer like a grounding...
Hello. Now that you are upgrading to the four prong you should unhook the green wire with yellow strip coming from the dryer and instead attach the extra green ground cord on the 4 prong to the screw on the side of the dryer. Regards, Joe.
If you prefer to see this in picture form, check this link: http://www.appliance411.com/links/jump.cgi?ID=466
Nov 20, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Hooking a 4 wire power cord to a dryer that came with 3 prongs
*First ; before starting unplug unit or shut off breaker.
you should be able to match up color for color on your dryer, the fourth wire, green (ground) screws to the chassis, or cabinet. if your wires aren't coded as you say, it is red, white and black, left to right. see picture I've supplied.981ddeb.jpg
hope that helps
good luck
Sep 26, 2009 | Whirlpool LER4634J Electric Dryer
Wire 3 prong cord
Electric Dryer How To Hook Up Cord pixel_trans.gifFor Three Prong Cords
the Center cord wire goes on the center terminal,
the left on the left ,
and the right on the right.
Note: There should be a ground strap or wire that runs from the center terminal to the dryer case.
For Four Prong Cords
the White cord wire goes in the center,
the Red on the Right,
the Black on the Left.
The green cord wire goes to the case or the external ground screw.
Note: Be sure to disconnect the ground wire or strap that runs from the center terminal to the case. In this Photo (A Whirlpool Dryer) I have ran the wire that runs from the center terminal, the Light Green wire, back to itself rather than cutting it off, just incase I need to put a 3 prong cord back on it some day. The whole purpose of this 3 prong / 4 prong thing is it separates the neutral from the ground. pixel_trans.gif pixel_trans.gif3 Prong Cord Whirlpool Dryer Example terminalblock.jpg 4 Prong Cord Whirlpool Dryer Example 4prongcord_small.jpg
Jul 02, 2009 | Maytag Neptune MDE5500AY Electric Dryer
Whirlpool Estate Dryer barely heating
Four wires on the new cord.
Red and Black go to outside screws on the terminal.
White goes to the middle terminal.
Green goes to the cabinet ground screw near the terminal plate cover.
Mar 11, 2009 | Whirlpool GEW9250 Electric Dryer
I need to change the power cord on our duet dryer from a 4 prong to a 3 prong The 3 prong does not have a neutral wire does that matter?
I think you need to read the following link to make sure you aren't violating any electrical codes, first:
http://www.fixya.com/support/r793520-3_prong_4_prong_power_cord_conversion
Yes, a 3-prong DOES have a NEUTRAL wire. That would be the WHITE terminal. A 3-prong does not have a separate ground. The NEUTRAL is usually grounded at the appliance casing by a jumper wire.
Read in the "Additional Notes" section on how to convert from a 4-prong to 3-prong. Also note that some of the newer appliances require a 4-prong plug in order to run correctly. I have a Kenmore HE3 model dryer that is currently using a 3-prong power cord. Since this model Kenmore is manufactured by Whirlpool, and is identical to the Duet, you should be okay with a 3-prong plug.
Aug 08, 2008 | Dryers
Dryers Logo
42 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
