You can flat tow it. Transfer case in neutral, transmission in park. You need a key one click on to so the steering wheel turns. If your towing behind a motor home you need brakes and lights. Research Blue OX
We'll if your taking a long trip I think for safety reasons remove the drive shaft put a plastic around the back York of the transmission with a big rubber ban or black tape then replace it what you get there because if the trans kits in to gear while the drive shaft is on you could burn it nor worth it it's easy to remove 4 bolts good luck
N on the gearbox/transmission is Neutral for the transmission. Nuetral meaning that the power is not going anywhere so you are not going to move anywhere. The N next to the 2high, 4high, 4low is for the transfer case in nuetral. The transmission sends power through the transfer case and the transfer case sends the power to the rear wheels or front and rear wheels depending if it is in 2hi, 4hi or 4lo. The N setting for the transfer case is used when towing the vehicle with all wheels on the ground, like people do behind a big RV/motor home.
Shifting to NEUTRAL To shift the transfer case to NEUTRAL, first make sure
the vehicle is parked so that it will not roll:
1. Set the parking brake.
2. Start the vehicle.
3. Connect the vehicle to the towing vehicle.
4. Put the transmission in NEUTRAL (N) or have
the clutch pedal pressed for vehicles with
manual transmission.
5. Shift the transfer case to 2HI.
6. Simultaneously press and hold the 2HI and
4LO buttons for 10 seconds. The red NEUTRAL
light will come on when the transfer case shift to
NEUTRAL is complete.
7. Shift the transmission to REVERSE (R) for one
second, then shift the transmission to DRIVE (D)
for one second or FIRST (1) for vehicles with
8. Turn the ignition to OFF.
9. Place the transmission shift lever in PARK (P) or
FIRST (1) for vehicles with manual transmission.
10. Release the parking brake prior to towing.
Shifting Out of NEUTRAL
To shift out of NEUTRAL:
1. Set the parking brake and apply the regular
brake pedal.
2. Start the vehicle with the transmission in PARK (P)
or FIRST (1) for vehicles with manual transmission.
3. Press the button for the desired transfer case position
(2HI, 4HI, AUTO 4WD or 4LO).
4. Put the transmission in NEUTRAL (N) or press the
clutch pedal for vehicles with manual transmission.
5. Shift the transmission lever to the desired position.
After the transfer case has shifted out of NEUTRAL,
the red light will go out.
6. A re-engagement sound is normal when shifting out
of NEUTRAL.
