How do i reboot my acer 5420 without a cd. - Computers & Internet
    Brigadier General:
  • 8,909 Answers
You could have a USB Memory Stick loaded with your operating system and set the Bios on the Acer to boot from USB.
Posted on Nov 06, 2010
Extensa 5420 Blank at boot
you have a brand new hard drive... probably cable is not fitted properly and the memory contacts needs cleaning. try it... good luck.
May 19, 2012 | Acer Extensa 5420-5687 Notebook
I forgot my pass word to my Acer 5420
You can remove or change the Window's User oradministrator's password. You need access to a computer with Internet access todownload the Hiren's Boot CD and burn it onto a CD.Then insert this CD into the laptop/computer and boot upthe laptop/computer with the Hiren's CD and follow the instructions.There are very useful utilities CD and it a Linux boot CDwhich contains quite a lot of Utility programs including a password removalprogram.Click on one of these links todownload HIREN'S BOOTCD :-http://www.hirensbootcd.net/http://67.20.82.163/
May 09, 2012 | Acer Extensa Computers & Internet
Tengo una acer 5420-5687 y necesitaría todos los driver para xp dado que perdí el CD de apoyo donde los tenia guardados.Gracias.mi dirección es osobelga@hotmail.com
prova ad andare sul sito di supporto acer. in inglese io credo tu possa fare il dowload dei driver dalla pagina supporto dowload della acer.
Oct 10, 2010 | Acer Extensa 5420-5687 Notebook
How many cooling fans are on the Extenda 5420-5687. Mine shuts down very frequently and I have to reboot.
1 you could make egg whites on the back of laptop you have to change out the fan althou making sure your slots are clean in the back and not being blocked you should be ok
May 20, 2010 | Acer Extensa 5420-5687 Notebook
How many cooling fans are on an Extensa 5420-5687. Mine frequently shuts down and I have to reboot.
There is only ONE cooling fan. You may have clogged air vents which allow the ambient air to be circulated into the laptop. If you have pets these can become VERY clogged with pet hair and not provide proper cooling. A small vacuum may be able to clear the vents without disassembly.
Apr 19, 2010 | Acer Extensa 5420-5687 Notebook
My Extenza 5420 won't complete updating and start up.
boot from the windows cd. select repair option. it will ask u" which windows u want to repair?". press 1. then in command prompt press the following commands.
c:/> fix MBR
c:/> fix BOOT
ignore the warnings u get in between when u enter the above commands
Sep 09, 2009 | Acer Extensa 5420-5687 Notebook
Connect burner and restart player
You arent the only one with this problem, and Acer has neglected to provide any info or fix.
The best I can do for you mis to suggest that you try the following,
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{4D36E965-E325-11­CE-BFC1-08002BE10318}
Apparently it seems that this is an age old fix for even XP systems. If you venture to the registry key above by doing the following steps:
  1. Click on the start menu.
  2. If this is a Vista machine in the search box type in “regedit” without the quotation marks.
  3. Maximize the HKLM and then go ahead and browse until you reach the key listed above.
  4. In the right panel you’ll see something along the lines of “UpperFilter” and “LowerFilter” you want to click on each “filter” key and hit delete. Click yes when it asks to confirm if you wish to delete the key.
  5. Restart Windows.
  6. Let me know if this works.
Please rate FixYa Experts assistance, whether your rating is good or bad helps The experts immensely.
Thank you for taking the time.
May 26, 2009 | Acer Extensa 5420-5687 Notebook
Iwant acer exrenca 5420 drivers cd
Hi!
You may find the drivers you are looking for at this site:
http://www.drivershq.com/Drivers/Acer/Extensa/5420/23419/23647/37421/Drivers.aspx
Have fun!
*Your vote is highly appreciated. Thanks in advance!
Jan 09, 2009 | Acer Aspire 3050-1733 Notebook
CAN'T USE BLUETOOTH
you need to install blue tooth drivers/application first. then you will able to use it.
Dec 01, 2008 | Acer Extensa 5420-5687 Notebook
Computers & Internet Logo
21 people viewed this question
David Payne
David Payne
