Question about Dacor ECS127 Epicure Electric Single Oven
Heating element won't heat. Checked breaker, turned off then on, and can't see any fuses in control hatch everything else is working. reset clock, canceled all timers. What now!
  • Dacor Master
  • 43,501 Answers
It gets tricky from there...
I would check for power at the element....if there is power and the element is not getting hot then you have a bad element.... 220 volts across the two wires to the element or more is considered proper power...
If there is no power there.... then you need to flow the wires back till you get power and that is where your problem is....
This is the best way to troubleshoot your oven...but a good quality electrical meter is needed.... and you need to be very careful when working with electric as it can kill you!!!
heatman101
Posted on Nov 07, 2010
I have a jenn aire JGR8875RDB oven. The control panel is partially out. The numbers beep. The clock displays and all the oven controls do NOT work.
Go to the power panel of your home and locate the circuit breaker for the oven. Turn this breaker on and off several times then check the oven controls. If this restores normal operation, then I would replace the breaker. If the breaker trips instantly every time you try to reset it then suspect the heating element and the thermostat. When a heating element shorts, it can ruin the contacts inside the thermostat.
Aug 07, 2016 | Ovens
Flavel milano e50. Why does everything except the oven work?
Check the circuit breaker for the oven. 220 volts are necessary for the heating element. 110 volts for the light and clock controls. The 220 volt breaker looks like two side by side breakers with their trip levers joined. Sometimes one will trip without tripping the other. Try resetting the breaker or better yet replace it.
Feb 02, 2016 | Ovens
Kenmore Pro Model 790.41003605 will not heat after self clean. It is not in lock but clock, lights and fan runs. turned breakers off and back on and reset time still not heating.
Check the heating elements with an ohm meter to see if they are burned out. IF they are not then you need to take the unit apart to check the wiring and controls.
Oct 04, 2014 | Ovens
Broiler element doesn't heat
https://www.repairclinic.com/RepairHelp/How-To-Fix-A-Range-Stove-Oven/18---/Oven-won-t-turn-on-
Oven Won Turn on
the broil element
is the heating element that is found at the top of the oven and produces a very high heat for broiling. If the broil element isn't working, you should first do a visual inspection for signs that the element has blistered or separated. If the element appears normal then you can check for continuity with a multi-meter. Remove power from the appliance before performing this test. Remove the back panel and locate the terminals for the broil element and inspect the terminals and wires for signs of overheating or damage.
If there is no continuity then the element will need to be replaced. If the wires are damaged then they will need to be repaired. If the element is ok then you will need to check the broil circuit to determine the cause. This involves live voltage checks and should only be performed by qualified persons. Components to check include fuses, if the range is equipped, and oven control thermostat or electronic control. Depending on the manufacturer of the element, you will normally read between 19 ohms and 115 ohms
Feb 09, 2014 | Thermador SEC301 Electric Single Oven
SMEG OVEN BRAND NEW WON'T HEAT
This tutorial will show you how to check your Smeg element and how to replace your Smeg cooker element.
Here are the 3 main faults to look for in your oven or cooker that is not heating
  • Your oven will not work until the clock/timer has been re-set after replacing an oven element or tripping the electrical supply. Consult your Smeg manual.
  • If your Oven is not getting hot or heating up it could be a faulty element, if the fan in the oven is running and the thermostat light is on, this will lead us to believe that the element has gone faulty. With grills the thermostat light should come on there should be heat, if not then this could be the grill element or the thermostat.
  • When you turn the oven on, the household electrical supply trips on the Rcd (this is the earth trip in the fuse board sometimes called the breaker tripping) your fan oven element has gone to earth and needs replacing.
If this helped you why not get me a beer? Paul is from the Naturally he would appreciate beer How to Repair Home...
Sep 08, 2012 | Smeg Ovens
I was heating some food and it stopped working. Where is the fuse located?
It might be that a circuit needs to be reset. Find your circuit breaker box (usually in a garage or a closet); you should be able to see a circuit that is going in a different direction than the rest--it might even be labeled). Push that circuit switch to the opposite direction. Hopefully this will work.
Mar 05, 2011 | Ovens
GE glass top and oven are not heating?
I have an electric oven that is turning on but not heating up. The oven, broiler, & stove top are not heating up. Any easy solutions to this?
Jul 18, 2009 | GE Profile JKP18 Electric Single Oven
Maytag elect. wall won't bake nor broil
I suggest checking the voltage going to elements. If there is no current, trace wires. Not exactly sure if there is a fuse/relay on your model. If there is current, than the elements may have gone bad.
May 22, 2009 | Ovens
No heat
there must be a fuse inside case or broken wire at the elements
Dec 12, 2008 | Jenn-Air JJW9530C Expressions Collection...
Dacor ECS127 Epicure Electric Single Oven Logo
66 people viewed this question
Top Dacor Ovens Experts
Dan Webster
Dan Webster
ashburton
Jaime Hernandez
Are you a Dacor Oven Expert? Answer questions, earn points and help others
