Question about Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+
The light no longer comes on when you open the garage door and I have changed the light bulb
    President:
  • 3,197 Answers
Unplug the opener and remove the bulb. Using a small screwdriver pull out on the center contact in the socket. Replace the bulb and plug in the opener.
Posted on Nov 08, 2010
When I open my garage door no lights come on. I changed out both lights with new bulbs, still no lights when I open or by manually clicking the Lights on the wall opener
Check the light sockets on either side of the garage door opener and make sure there is no corrosion on the contacts. If you see some corrosion unplug the garage door opener and scrape off the contact. Give that a try and lets see what happens.
Feb 21, 2015 | liftmaster Garage Door 1/2 Hp
Aparker@primelending.comRe. the security+ light feature on LiftMaster #1265......it is no longer working. Light can be turned on, and comes on when door operated, but will not come on when beam is broken....
Try these instructions in case they are different from what you have.
To have your lights come on automatically when you walk into an open garage, you must START with the lights ON. If you don't want that feature and you want to turn it off, you must START with the lights OFF.
To turn the feature on, turn the lights on manually with the wall switch, then press and hold the LIGHT button for about 10 seconds until the motor unit light bulbs flash. Now, if the light bulbs are on, manually turn them out and then walk out through the open door. The light bulbs should come on.
To disable this feature, start with the light bulbs OFF and everything else is the same.
Jul 13, 2011 | Sears Craftsman LiftMaster Chamberlain...
The lights on my Liftmaster no longer come on. Tries all new bulbs, but still no light.
Unplug the opener and remove the bulb. Using a small screwdriver pry out on the center contact of the socket. Replace the bulb and plug in the opener.
Feb 28, 2011 | Sears Craftsman LiftMaster Chamberlain...
Light will not come on Craftsman 139.53615sr, changed light bulb still doesnt work
Unplug the opener and remove the light bulb. Take a small screwdriver and pry out on the center contact of the light socket. Replace the bulb and plug in the opener.
Dec 19, 2010 | Sears Craftsman LiftMaster Chamberlain...
I have 1half h\p chamberlin garage door opener
Unplug the opener and remove the bulbs. Use a small screwdriver to pull out on the center contact in the socket. Make sure you are using standard bulbs.
May 10, 2010 | Sears Craftsman LiftMaster Chamberlain...
Unplug the unit and remove the bulbs. Using a small screwdriver pull out on the center connection in the socket.
Apr 03, 2010 | Sears Craftsman LiftMaster Chamberlain...
Both lights no longer work. I hear a click, but the lights do not come on.
If the bulbs are good unplug the opener and then remove the bulbs. Using a small screwdriver pull out on the center contact in the socket.
Dec 22, 2009 | Sears Craftsman LiftMaster Chamberlain...
Garage door opens and closes,light bulbs have been changed, light does not come on when door opens and closes
Unplug the unit and remove the light bulbs. Using a small screwdriver pull out on the center contact in the light bulb socket.
Oct 31, 2009 | Sears Craftsman LiftMaster Chamberlain...
My light bulbs keep burning out prematurely on my garage door opener.
This is a logic board issue. You can purchase a replacement one at searspartsdirect.com. Enter in your model number and a parts list will come up. This is a fairly easy install, make sure and unplug the unit first. You will have to reprogram the remotes. Thanks BB
Feb 18, 2008 | Sears Craftsman LiftMaster Chamberlain...
Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+ Logo
229 people viewed this question
Top Sears Building Materials Experts
Glenn Mayer
Glenn Mayer
Mike
Are you a Sears Building Material Expert? Answer questions, earn points and help others
