Question about Technics SL-PG480A CD Player
Technics SL-PG400A is very tempramental in picking up cd's can take up to 15 mins to register a cd. i have cleaned the lense and has made little difference. any advice??
  • 979 Answers
Did you clean all the lenses? There are three on this unit; the emitter lens, the grating lens, and the objective or focus lens; probably the one you cleaned. These steps must be done by a tech and clean room standards must apply. The next best thing to do is just replace the laser assembly, as the above is labor-intensive...accordianman
Posted on Jun 15, 2008
Technics servo
Register (free) with Vinyl Engine and you can download the service manual.
http://www.vinylengine.com/library/technics/sl-b210.shtml
Jun 25, 2014 | Audio Players & Recorders
Technics CD Player Model No SL-PJ27 Unit will not recognise CDs. Can this be repaired
Use a CD cleaning kit and follow instructions, if this fails! the laser pickup assembly would need to be replaced, not cost effective to repair.
Apr 24, 2012 | Technics Audio Players & Recorders
Technics 5 cd changer Model SL PC11 will pick up
This is a problem with the laser assembly which requires service. The laser assembly needs to be replaced as a whole. It is not easy to replace them, but someone with patience, and a knack for mechanical things can do it.
Nov 27, 2009 | Audio Players & Recorders
Technics 5 cd changer Model sl-pc11 will pick up cd but not play.
System will not play Mp3 or data format cds.
Audio cds only . Also Clean lenses with a cd lenses cleaner .
clean cd also straight away from center ,soft cloth
Check for scratches .
Feb 28, 2009 | Technics Audio Players & Recorders
Looking for a drive belt for a SL MC300 Technics 110 CD changer
A rubber "O" Ring as a belt solved the problem.  At our local hardware store:  1 1/16 OD x 15/16 ID - 1/16" wall  $0.39!
Jan 29, 2009 | Technics SL-MC7 110-Disc CD Changer
Technics sl-pg580A
this player uses a philips mechanism, spindle motor failure is very common on these mechanisms, yours may be on its way out. take the lid off and insert a cd and if you can hear the laser trying to read the cd without it spinning, it's definately the spindle motor.
Oct 07, 2008 | Technics SL-PG480A CD Player
Technics 5 cd changer sl-pd787
Does it show the disc length or any other details? Have you carefully cleaned the lense with a q-tip and some alcohol? Can you hear the laser moving in and out of focus? If you push the laser sled out away from the centre does it move back to the middle when youi put a disc in?
Feb 27, 2008 | Audio Players & Recorders
Technics SL-MC6 CD player
You have to removo all disc
Then turn on the unit and let do the initialization process
May 26, 2007 | Technics SL-MC6 CD Player
Technics SL-PG480A CD Player Logo
458 people viewed this question
Top Technics Audio Players & Recorders Experts
 Grubhead
Grubhead
Ben Armstrong
Are you a Technics Audio Player and Recorder Expert? Answer questions, earn points and help others
