Question about Samsung Televison & Video
Sounds like a grinding noise the entire time it is on
  • 616 Answers
So we should just guess the model # ?
Posted on Nov 06, 2010
What could cause metal on metal grinding at 40 mph and above on '96 Pathfinder?
First thing is to check the brakes, especially the condition of the pads, and if you have worn right through them, the condition of the calipers, and finally the rotors. Sounds like one of these old the key.
In any case can you get back to us with the solution so that others can be helped in the future, thanks.
Jul 10, 2014 | 1996 Nissan Pathfinder
ZXR750 L1 horrible sound of grinding from gearbox or clutch area when bike is on sidestand or revved hard any ideas?
Had a similer problem with my L1 recently and narrowed it down to the cluctch not getting enough oil through so changed cylinder put an ebc clutch in and serviced entire clutch system and thankfully seems of done the trick now no gearbox or clutch noise and goes throug the gears superbly with no slipping or noise even when going for it
Jun 07, 2014 | 1993 kawasaki ZXR 750
Grindings sound
it could very well be the transmission. if the sound leads you to the left side of the vehicle, if that is the side you are dealing with, then it's entirely possible
Mar 13, 2013 | Cars & Trucks
Engine on the passenger side is making a weird grinding/cranking noise when the van is started and its cold. what could it be?
all your rubber belts and pulleys are on the passener side on your vehicle. when rubber is cold its stiff. so when you start the car in the cold its most likely the rubber serpentine belt just loosening up (this is normal) but i would check to see if the belt is worn or damaged. also if the sound is more of a grinding sound and it lasts the entire time the engine is turned on (after it warms up) it could be a pulley, which is also a simple fix.
Dec 21, 2010 | 2006 Dodge Grand Caravan
52 grinding noise from under car . not sure if it
Hi, When a grinding noise is detected first locate the area of the car it is being generated from. Most grinding noises will be being generated while driving, if you are having a hard time detecting the location of the grinding sound, have a helper ride along in the rear seat to give a new perspective on the origin of the grinding noise. A grinding noise can be generated by many things from worn out brake pads to axle bearing failure. Once a grinding sound has been detected action must be prompt. Grinding in most cases is telling you something has failed or is failing. It can be as a result of worn out brake pads or shoes, check your engine and transmission mount, check for axle bearing failure, check your power steering system for leak...
Take care
Jul 23, 2010 | 2002 Jaguar X-Type
Sony vaio fan is making a grinding noise, how can i fix this?
The sony VGN-S460 seems to have an inherent problem with their cpu fans. It is apparent that the fan uses a ball bearing system which over time becomes worn and causes the grinding sound.
The only solution is to replace the entire fan assembly as they are inseparable.
Nov 15, 2009 | Sony VAIO VGN-S460 Notebook
Loud noise
Check for bones/glass/ceramic from chipped plates in the food chopper (for lack of a better term). You'll need to disassemble the entire lower arm unit.
Sep 06, 2009 | Maytag 24 in. MDB7600A Jetclean® II...
Lg dryer - front load - making a grinding noise
I also have the same problem as klrlesimmons, exactly as described. Sounds like sand is rubbing as the drum turns, and also sounds out of balance.
Repairmen replaced upper and lower glides and also the plastic bearing but not the entire bearing assembly.
Frigidaire Gallery, Model Number 417.49012890
Mar 22, 2009 | LG DLE3777 Electric Dryer
Televison & Video Logo
Jerry Greenberg
Jerry Greenberg
