Question about ASUS P4V8X-MX Motherboard
2048 max seen on drive.
Hello to my fellow Guru's,
I have seen the solution for this . I just can't remember where.....
I just dont want to use FDISK ,Rather Have NTFS
WINXP HOME SP3
Daughters Comp. 16 YRS. OLD
ASUS P4V8X-MX
VIA P4M800/8237R Chipset
P4 SL79L 800 FSB, 1gb L2 cache, HT, CO Stepping.
Mushkin Special 2-2-2 DDR 400, BH5's serial # 39 + 40 ( classics)
Ultra 600 Watt ATX PS
Barracuda 7200.7 80 Gb, Ultra DMA, Upgrade to SATA 500gb soon. Wow she downloads a lot of tunes. The Thing is wicked.No overclock except
ASUS High SDRAM voltage. is it 2.75v ?)
Abit ATI RADEON R9550 GURU 128 ,Turbo Mode.What Arpeture should she use?
Not A Gamer,yet. Just talks to Boyfriends on, MYSpace.
I can't imagine.OMG, she does 500 to 1000 Text's a day on the mobile.
( not relevant ) But unbelievable,
Comp See's 2048 Mb, I think single partition, XP typical setup, and Firefox eats that up.
I have to give her Directions over the phone, as she live's 900 miles away.
Can It be done?
Any Help on setting up everything from interleave to perfetch would be appreciated.
Happy Fathers Day. To all the Dad's
Regards, Paul
    Sergeant:
  • 132 Answers
This is interesting as I ran into the very same thing the other day. The problem with the Barracuda is that they allowed for a special configuration that would limit the grive size to 2 GIG. If you will look at the jumpers on the drive you will notice an extra jumper that is in the (I believe) horizontal position or in another spot other than master or slave. Remove this jumper reboot with the XP disk in and install. You should see the entire 80 Gig then.
Brian
Posted on Jan 03, 2009
,cbvbmvhm
Posted on Jun 15, 2008
97 Olds Cutlass Supreme SL. Transmission 4T60E (M13). Which solenoid is the 1-2 shift solenoid? I am a Guru on FixYa. Done all except internal transmission stuff. Help me out here. Its my car. I posted...
I had that same problem on an Aurora. I don't remember which one, but I do know that I called a gm dealer and had them fax me the diagram location. The internet's diagrams were all too general.
Aug 31, 2011 | 1997 Oldsmobile Cutlass Supreme
I have a hard disk 2.5 hitachi 250 go I lost my password .... with hdd unlocker is impossible
Things sadly do not look good. If the security rating on it is set to Max on the drive, recovering the password for the drive is next to impossible. The only way to make the drive usable again is to perform a low level format using FDISK which does not care about passwords. If the data is important however, you may need to check a drive recovery expert like DriveSavers.
Mar 12, 2011 | Computers & Internet
Yesterday I buy a Samsung Laptop model R538 but with Linux Julia preinstaled. I want to change the OS with Win XP. I begin the instalation and at the point in which I know he want to format the disk I get...
Solution:
1. Boot into Linux.
2. Use "fdisk" command to delete "ext" partitions. // In fact, no need to use other tools (e.g. killdisk)
3. Run "fdisk" command as root.
4. For those who don't know how to use "fdisk", I provide an example here. (Read the man page of "fdisk" will be better)
//Remember !!! fdisk can format your hard disk (which will erase all your data), use it with great care -- unless you know what you are doing, otherwise don't use it. (I will not take any responsibility of my suggestion)
i) fdisk /dev/sda
.) For those who use PATA (Parallel IDE) : fdisk /dev/hda
.) For those who use second hard disk : fdisk /dev/sdb (2nd SATA hard disk), fdisk /dev/hdb (2nd PATA hard disk), fdisk /dev/sdc (3rd SATA hard disk) and so on ... {sd [a, b, c, d, ...]}
.) fdisk "what" depends on where your linux partition is.
ii) use "m" to read the available options
iii) press "d"
iv) press the number of the partition you want to delete
v) Remember ! if you don't want to make the change, press "q" at any time. (that means quit without saving)
vi) If you want to make the change, press "w" (that means write the change to hard disk)
5. There may sometimes cause a warning message say something about not synchronize the disk (because you cannot make changes while you are using the partition -- if you are booting the partition now), the change will occur after you shutdown and reboot the system.
6. Okay, you can reboot the system now and you will find that the partition is empty now.
7. You can install XP or what ever now.
** For those who cannot use "fdisk", my simplest suggestion is to re-install Linux if you don't have any other tools (such as killdisk). And then you should be able to use "fdisk". In fedora 8, you can even choose formatting the hard disk in "vfat" file system (which can be recognized by almost all computer include windows xp and so on -- see "File Allocation Table" wiki) during installation. Therefore, no need to run fdisk
May 31, 2017 | Hitachi Travelstar 5K500.B HTS545050B9A300...
Hi, the model SDCZ6-2048-A11 USB cruzer 2.0 flash drive, do not have password protection??. How I can put a password to this model?. Thanks.
Dear fellow,
The easily lock your USB by installing software what called a Folder-lock on your Flash memory , once you about to use it teaches how to lock, unlock your device and protects from introders.
Dodo
From Iraq, Baghdad.
Oct 16, 2010 | SanDisk Cruzer Micro 2GB USB 2.0 Flash...
Hello. Pfaff 2048 I have. I have it fixed two...
If you want to fix the sewing machine by yourself, I suggest you to order the following product:
Sewing Machine Repair Guide
It's a professional repair guide written by an expert. Besides PfaFF sewing machine, you can learn how to repair other brands of sewing machine as well. The author claims that you can earn money after you had learned the repair skills!
Good luck.
May 19, 2010 | PfaFF Quilt & Craft Pro 7530
Hello, I formatted the M3000 with Ubuntu Linux, and... i'm stupid
Take your Sanyo back to Linux box, hook up the USB cable, and then mount it.
Copy the files that you want to keep on to the $HOME directory on Linux.
Next, from a terminal, run
sudo fdisk -l
to display all the mounted filesystems on the computer.
It might be /dev/sdb1, or /dev/sdc1 You should be able to pick out the M3000 as its hard disk size is 6.0 GB. Let's assume that the USB drive is on /dev/sdb1
Re-run the fdisk command.
sudo fdisk /dev/sdb
(press m to get the help menu).
Recommend that you choose d to delete a partition,
then n to create a new partition
when asked about the code for the new partition, use b -- this corresponds to Windows 95 FAT32 file system.
Don't forget w to write the new partition definition out to the USB drive.
Lastly q to quit fdisk.
Once you exit fdisk, remount the M3000 and make sure that you copy your files back on to it.
All Linux and Windows systems should be able to recognize your drive now.
Mar 16, 2010 | Sanyo HDP-M3000 MP3 Player
Hello my name is Michael. I would appreciate some help i have an acer aspire 5920 ad would like to reformat it however when i start the computer in any mode including safe mode it says start up repair...
Hi Michael,
Its possible to reformat your hard drive by using a DOS boot floppy disk or CD. You can create this disk on another pc then boot your pc from this disk. It will boot your pc to a DOS prompt, usually "C:>" from there you can create partitions, delete partitions and format the hard drive. The command for creating partitions is FDISK.exe. Make sure your boot disk has the FDISK.exe command on it.
Let me know if you require any further assistance regarding this.
Best wishes,
Graemevm
Jun 12, 2009 | Acer Aspire 5920-6727 Notebook
C drive formating
The basic fdisk command to repair the mbr is fdisk /mbr. that will replace the mbr but you may have to re-partion reformat and install from scratch. Good Luck
Dec 09, 2008 | Computers & Internet
Recognize sata hd
No drivers are needed - it should have been seen right away. Check the BIOS to see the drive is seen in the drives tables, and if there, XP needs to have the drive setup using FDISK. The drive will not show under windows until a drive table is on it.
Sep 05, 2008 | Intel Motherboard
Office max paper shredder
You need to find out who made the shreddr, Fellows, GBC, etc. parts are available to brand name machines...
Jun 03, 2008 | Office Equipment & Supplies
ASUS P4V8X-MX Motherboard Logo
121 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
