Question about Samsung Cell Phones
MY FREEFORM HAS PROBLEMS HOLDING A CHARGE, SOMETIMES IT SAYS LOW BATTERY AFTER ITS BEEN CHARGING ALL DAY. I TRIED USING ALL DIFFERENT KINDS OF CHARGES(HOUSE, CAR, ETC) DOESNT MATTER, BRAND NEW BATTERY SO ITS NOT THAT (THATS WHAT METRO PCS THOUGHT IT WAS. THE PROBLEM MUST BE WITHIN THE PHONE, THE CONNECTION I GUESS, PLEASE HELP? THANKS
    Sergeant:
  • 389 Answers
It could be that your charger port is loose and needs to be fixed, which is a minor cost, and if you have a warranty on your phone they will fix it for you for free as long as it has no water damage. Good luck!
Posted on Nov 07, 2010
My htc titan II has a battery problem. It says that my battery is crittically low. how do i fix this problem?
The first thing would be to replace the battery with a new one. If it charges, you're golden. If not, it could be the hardware of the phone (possibly the charge port).
Also try using a different USB cable and adapter to charge with, as those could be failing.
Jan 15, 2014 | HTC Titan II X825a 16GB Unlocked GSM Phone...
Dear sir, For past two days, the battery indicator
replace batteries,low capacity or charge.
cant hold charge
Aug 28, 2013 | Liebert Computers & Internet
NOKIA C1 01 PHONE BATTERY LOW PROBLEM WHEN BATTERY IS FULL CHARGE.
Hi Please clean the Center terminal of the battery as well as the battery connector of the phone.That's all you have to do and this is the first aid.Sometimes battery low indicates when the center terminal has short/ not contact to the phone properly. Thanks for visiting fixya...Good luck
Sep 13, 2011 | Nokia C101 Cell Phone
Samsung Freeform says ''no battery,'' why?
With your phone powered on, connect the charger to the phone. With your phone unlocked, press and hold the END key to power off your phone. The phone will now shutdown and then restart to the charging screen. As soon as you see the screen with the battery and the word "Charging..." under the battery, press and hold the END key to power on the phone. This must be done before the phone has a chance to display "No Battery".
May 21, 2010 | Cell Phones
My mobill betry is so low and icant solution this problem so you can solv problem now thanks my name is piyushmistry &my cell no is 09824136819
Hello Sir, If the battery is showing low battery then you should charge it with its corresponding Charger. I think you are willing to tell that the Phone is showing low battery even after charging. If that is the case then there can be 2 causes :--- (1) The Phone's battery is not properly plugged in and thus can't properly retain the Charge which is supplied. In this case, try cleaning the Battery Contact, I mean the 3 Power pins and the 3 power slots. Use something like dry cloth. (2) The Battery is damped or defective. If damp then don't try to charge, it can sometimes explode. Kindly take it to a Service Center and get it repaired.
Also try changing the Battery.
Thank you Sir, Have a nice day.
Oct 12, 2009 | Samsung SGH-F250 Cell Phone
Wont connect
replace battery
Mar 14, 2009 | Lands Phones
USB Cord (Or something)
First, make sure the hold/lock is not engaged, and that there is no lock on your USB port (usually not). Try hooking it to a different PC, and see if it will charge. If it charges on a different PC or a different usb port, then your USB port is bad/wrong kind.
Sep 06, 2008 | SanDisk Sansa Clip MP3 Player
Battery does not charge.
hi dear
try this
BACK UP your Treo 650 software and data BEFORE doing the following.
1. RESET the Treo 650 back to default set by holding power buttom following by reset the treo.
2. There is a way to reset the voltage regulator in the Treo ; believe is by holding the RESET for > 3 seconds. Believe need to take out the battery in out during this process. Can't recalled the correct steps. This could could reset the Treo's power regulator.
3. TRY reinstall your palm software with minimun software or 3rd parties one, this software could be running in the back ground which drain the battery.
Try above steps might help.
Mine also got the same problem last two weeks, my treo could felt there is kind warm sensation if it took out from my waist pouch after leaving it for sometime on the table. BTW, the battery could felt quite warm also.
If yours also behave the same which I believed the Treo got some kind of contact problem which draw more power then usually does.
Now, mine got no more warm sensetion after carry out above steps. It gets better as Compared to last two weeks ago BUT not that good as compared previously when it can last 3~4 days after a full charge.
oke
or just try to use
http://mytreo.net/archives/2005/09/charge-your-treo-650-spare-battery-with-seidios-innocharger.html
oke
cropp
Mar 26, 2008 | Palm Treo 650 Handheld
LG KG800 charging problem.
if you already change the battery;' theres no problem with the battery; i think the problem is software try to reset the factory setting if dosen't work/ reinstall software
Feb 04, 2008 | Cell Phones
Motorla Slvr L7 Won't hold charge
It depends on how much talking your doing. The Slvr is known for its low talk-time battery power. My slvr would last about 3 to 4 days on a charge, unless i was talking on it a lot. sometimes i would be charging it every other day. So it really all depends on the talk-time. Invest in a car charger for sure.
Dec 24, 2007 | Motorola Mobility SLVR L7 Cellular Phone
Cell Phones Logo
91 people viewed this question
Top Samsung Cell Phones Experts
Computer Repairing
Computer Repairing
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
