Question about Cub Cadet Street Sign- tractor lawn riding mower parts
I have an LT1050 Cub Cadet. It cranks but never starts. I did not use it since August and it might be the water in the carb now. I can't find the diagram and want to know if you might know where to find the carburetor or have a diagram or photo. Thanks, Rich
  • 293 Answers
The carburetor is located on the LH side of the engine, while you are sitting on the seat. It is behind the air filter. you will want to remove the fuel line and plug it at the carburetor, then remove the float bowl to examine/look for water and corrosion. be careful not to spray carburetor cleaner in the bowl or on the carburetor with out first removing the bowl gasket (black o-ring), and set it aside. Otherwise the carb cleaner will cause the o;ring to expand, and it wont fit upon reassembly. The main jet on the bottom of the pickup tube must be open, otherwise the fuel can't be drawn out of the float bowl. Before reconecting the fuel line, Run some fuel into a bucket and check for good fuel flow and water, let it run for about 30 to 45 seconds then plug the line again. The water will sink to the bottom and pool together, it will look like a "Blob" under the gasoline. If it is old fuel, you would be better off to drain all of the fuel and add new.
Hope this helps
Posted on Nov 07, 2010
Testimonial: "Thank you very much. I'll give it a try today. Rich"
My cub cadet lt1050 lawn tractor mower starts when cold fine, but wont even turn over when hot.
you have bad valves it needs a valve job this is because the hatter it get it looses power and will shut down when to hot
May 25, 2014 | Cub Cadet Lawn Mower PTO Clutch Replaces...
Cant remove oil filter on Cub Cadet LT1050
grab the filter with a pipe wrwnch or drive a screw driver through it and turn it. good luck. Ron
Sep 14, 2013 | Cub Cadet Op's Manual Model Lt1042 Lt1045...
My cub cadet 221 cranks won't start
Clean your carb, if you have not stored it correctly you have a dirty carb now. Carb could be gummed up.
Feb 17, 2013 | Cub Cadet Snow Blowers. 21 in....
Left rear tire has rust color leak
Sounds like a seal has went bad allowing water to enter trans case. I would suggest taking to a cub cadet shop and letting them check it out.
Sep 22, 2012 | Cub Cadet Op's Manual Model Lt1042 Lt1045...
Cub cadet ltx 1050 extension spring where does it go
In case anyone has a 2014 Cub Cadet LTX 1050 KW and needs to know where the damned spring goes when it falls off when removing the belt keeper, here's a photo.
Jul 15, 2012 | Cub Cadet Op's Manual Model Lt1042 Lt1045...
Cub Cadet LT1050-Replaced the solenoid, had starter checked out-it's good, battery has full charge, but mower won't start. Help!!
You need to check that there is a 12volt supply from the low tention wire at the solinoid when the key is turned, if there is not either the switch is bad, or the wire from the switch is bad, or the fuse has blown.
Mar 04, 2012 | Cub Cadet Street Sign- tractor lawn riding...
It just quit running and not when i try to crank it it trys to fire but backfires thur the carb
Sounds like a float problem but do a complete carb overhaul and if OHV engine do a rocker clearance check. Watch video at smalleng.com Good Luck...
Aug 16, 2011 | Cub Cadet Op's Manual Model Lt1042 Lt1045...
Kohler courge sv720-0010 on cub cadet
SOUNDS LIKE IT HAS SOME BAD GAS YOU MAY NEED TO CLEAN THE CARB AND IT MAY NEED A KIT
Oct 10, 2009 | Garden
Cub cadet lt1050 poor running
when you cleaned the carb was the needle replaced. also what is the compression on this engine. if a unit has low compression they will sometimes only run on full choke. is there good fresh gas in this unit. No water..(if in doubt trow it out)
Mar 10, 2009 | Cub Cadet Street Sign- tractor lawn riding...
Cub Cadet Street Sign- tractor lawn riding mower parts Logo
649 people viewed this question
Top Cub Cadet Garden Experts
Tim Whalen
Matt Olenzek
Matt Olenzek
roeb
Are you a Cub Cadet Garden Expert? Answer questions, earn points and help others
