Question about Hoover SteamVac Carpet/Upholstery Deep Cleaner Vacuum
How do you get to the belt on a Hoover steam vac?
  • cranberryrid Nov 07, 2010
    My brushes do not move. Is this a major problem that is not worth fixing if there is no belt and it is a suction driven turbine?
    Novelist:
  • 147 Answers
I hate to tell you, but there is no belt at all on the steam vac line. they have a suction driven turbine to turn the brushes, and a suction driven pump for the water flow. But definately no belts.
If something is not working on it, describe more in detail what is not working and we can narrow it down better for a proper solution.
Posted on Nov 07, 2010
Testimonial: "Thank you. That was very helpful information."
  • Mark Smith Nov 07, 2010
    Sometimes, and I say sometimes, you can turn the brushes manually (grab the centre brush) by turning them by hand. I assume your model has the rotating brushes. This might allow them to free up so that you can use them again.
    Something else to look for on some of these models is the clear lens off to the right of the unit with a metal screen inside. Sometimes those block up with hair/lint etc and if you clean that off it may turn again as well.
    good luck.
    After I cleaned the screen it worked great. Thank you for your help.
My hoover steam vac is making a horrible noise and smells like its burning
Something may have jammed the brush roller, preventing rotation. This causes the motor shaft to rotate in one spot on the belt, causing the burning rubber smell. Eventually, the belt will break. You need to find what caused the jam and remove it. It would be a good idea to replace the belt as a burned belt is unlikely to last much longer.
Dec 18, 2014 | Hoover Steam Vac Dual V w/ SpinScrub...
Hoover changing belt
There is no belt in Hoover Steam Vac. A gear box turns the brushes. The nylon gears wear down, eventually, but can be replaced. Check this out: http://www.youtube.com/watch?v=n-vPOk9kEag
Jul 28, 2014 | Hoover SteamVac F5914-900 SpinScrub...
How do I install the belt on my steam vac V2 model f7210-900
STEAM vac don't have a belt they rotate by turbo motor that sometimes seize up click the link below and watch video how to fix.
http://www.youtube.com/watch?v=QBtWcC4gqjY
Aug 14, 2012 | Hoover F7210-900 SteamVac V2 Upright...
I have a Hoover Steam Vac Dual V and the brushes no longer turn. Can it it fixed? Model # F7431-900
your belt is probably brokan. underneath the machine you will see some screws carefully take them out writing down which screw went where. than you can pop the plate off and look in there and see if your belt is brokan. If it is the belt number is important to find in your book that came with the machine. hope this helps you.
Aug 16, 2011 | Hoover Steam Vac Dual V w/ SpinScrub...
The Hoover steam vac dual v does not spin its brushes and I dont know how to dismantel it to view the belt .
There is no belt on the steam vac - it operates on air flow. Remove the brush and insert a flat screwdriver into the square hole. If it does not turn, the turbine has seized up and must be replaced. Remember that the brush will not turn unless the lower tank is in place, and the handle is tilted back.
Jan 28, 2011 | Hoover SteamVac F5914-900 SpinScrub...
I own a hoover steam vac model f5915-900 and i currently have two problems. 1. the brushes are spinning at a much slower speed. 2. the steam vac is not picking up the water it leaves on the carpet....
the reason the brushes are not spinning is because the belt is slipping, the belt is the bad that connects to the brush to a shaft that makes it spin. Next problam is it is probobly clogged. so water is not going through all the way
Sep 08, 2009 | Hoover SteamVac Carpet/Upholstery Deep...
Hoover F5914 SteamVac Deep Cleaner
There is no belt on this model. what is your exact problem?
Nov 06, 2008 | Hoover Steam Vac Dual V w/ SpinScrub...
Hoover F6025900 Steam Vac Widepath LS, I own this steam vac and I found bits of rubber under the machine when I turned it on, smelled like burned rubber from a belt? Can you please tell me if there is a...
Well there is no belt, and not sure what the rubber would be from, everything is plastic or metal. Unless it is really an electrical smell, which means the motor is going bad.
Jun 22, 2008 | Hoover Vacuums
Belt on steam vac v2
The V2 doesn't use a belt, it uses a turbine to drive the brush block, If brushes are not turning, either the shaft on the brush block broke off, or the turbine is bad and will have to be replaced.
Dec 23, 2007 | Hoover F5906-900 Upright Steam Vacuum
Hoover SteamVac Carpet/Upholstery Deep Cleaner Vacuum Logo
369 people viewed this question
Top Hoover Vacuums Experts
Jim Parker
Jim Parker
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
