Question about Belkin Wireless Keyboard/Optical Mouse f8e832-bndl
MY BELKIN MOUSE F5L075 IS NOT WORKING(DOESN'T MOVE) I CHANGE THE BATTERIES AND PRESSED THE BOTH BUTTONS
    Genius:
  • 1,127 Answers
So the wireless mouse/keyboard is a non stable set, so you must send to repair. try a wired set is problem free. if you like wireless try microsoft is better, you see.
Posted on Nov 06, 2010
How do i re-connect my wireles mouse? I can not find directions and I am away from home!!
Hello there.
To reconnect your wireless mouse here is what you should do:
1. Be sure your computer is turned on.
2. Connect the receiver with the USB connector.
3. Be sure you have batteries in your mouse. The synchronization will start automatically.
4. If synchronization doesn't start automatically, press the connect button on the receiver then press the connect button on the bottom side of the mouse for ten seconds.
Thanks for using Fixya!
Jun 25, 2011 | Belkin F8E874-APL Wireless Optical Mini...
I have a F5L075 wireless Belkin mouse that I need instructions on how to sync it to the ubs device.
when you turn on the mouse and if you have the USB transmitter in your USB port, the computer should automatically detect the mouse and the keyboard, (make sure both the keyboard and the mouse are switched on otherwise the computer will not see it. also be sure that your batteries are new (or check them with a volt meter). you don't actually do anything called "sync" with the mouse or keyboard.
Mar 23, 2011 | Belkin Wireless Keyboard/Optical Mouse...
Hi my mouse has worked for years. I just changed the battery in the mouse and now it will no longer work. The jump drive turns red when I push the mouse up to it then nothing happens. I went to Control...
From your description, it sounds like the wireless connection between the mouse and the USB receiver (jump drive) isn't resetting. Here are the steps to reset the connection after changing batteries:
With the computer on, mouse on, and receiver installed in the USB port...
1. Turn the mouse over and aim the front at the receiver, like this:
thomascha103_8.jpg 2. Press the "connect" button on the bottom of the mouse. It's small and round, next to the power switch.
3. Then press the "connect" button on the receiver
(the connect buttons always have to be pressed in this order)
4. When you press the button on the receiveer, the light will turn on. Keep the mouse pointed directly at the receiver until the linkage is complete and the light turns off.
That whole process has to be completed in under 60 seconds. If it takes longer, you'll have to start over.
At least, that's how it works for me. Here's a link to the user manual with other helpful troubleshooting tips:
http://cache-www.belkin.com/support/dl/f8e825-usb.pdf
Best of luck!
Jan 20, 2011 | Belkin Mini Wireless Optical Mouse...
My mouse isn't working its not the batteries because i just changed them and i plugged the usb thing in and i pressed the two buttons to connect them but its still not working. it didn't come with any cd...
You can download drivers for the mouse at:
http://www.belkin.com/support/download.asp?lang=1&download=F8E825-USB&mode=
The mouse may or may not work depending on your operating system. I do not know if this mouse is compatible with Windows Vista/7 or 64-bit operating systems.
Aug 02, 2010 | Belkin Mini Wireless Optical Mouse...
Not working properly
Are the batteries good in the mouse?
If they are try
Normal 0 Turn the mouse over and find the small rest/connect button on the bottom of the mouse and press it. This should connect the mouse to the receiver and work properly. If not, try pressing the receiver button and then press the button on the mouse. This should be done whenever you change batteries or glitch.
Hope this helps you. Bud
May 28, 2008 | Belkin Mini Wireless Optical Mouse...
Wireless belkin keyboard
Hi. I have just worked out how to solve this as I had a similar problem. When you change the batteries of a Belkin Wireless Keyboard model F8E332ukBNDL you need to reconnect the keyboard to the wireless receiver that plugs into the USB port. To do this you press the 'Connect' button on the receiver and also press the green LED connect light at the top right of the keyboard - the one that flashes each time you press a key. I'm not sure in what combination you press these but I pressed them both and it worked.
May 16, 2008 | Belkin (F8E832-BNDL) (DBF8E832BNDL)...
Cant get Pointer to move
First try
Then if that doesn't work try
Feb 19, 2008 | Dynex Wireless Optical Mouse DX-WOM100
Belkin Wireless Mouse
Today I tried pressing the reset button on the bottom of the mouse, and at the same time pressed the button on the top of the remote reciever. I'd pressed both in the past, but never at the same time. This seems to have fixed this problem. I hope it's a solution for others also.
Dec 21, 2007 | Belkin Wireless Keyboard/Optical Mouse...
Can not get mouse to move and buttons will not work on keyboard. batteries are all good
Normal 0 Press the Receiver button (and the lights will start flashing.
Then if the Keyboard isn't working, press the small RESET/CONNECT button on the back of the board to connect the keyboard to the receiver.
If the MOUSE isn’t working, push the small RESET/CONNECT button on the back of the mouse to connect to the receiver. Then they should work okay.
Hope this helps. Bud
Dec 12, 2007 | Microsoft Optical Desktop 1000 (BV3000003)
Wireless mouse for laptop
Make sure the batteries are good.
Nov 25, 2007 | Computers & Internet
Belkin Wireless Keyboard/Optical Mouse f8e832-bndl Logo
583 people viewed this question
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Pamela Bates
Pamela Bates
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
