Question about Mitsubishi WD-65731 65" HDTV
Moved to new house - wont turn on - Mitsubishi WD-65731 65" HDTV
    Genius:
  • 1,121 Answers
Normaly has some moisture on the screen or the hv circuit inside. better send to repair
Posted on Nov 06, 2010
Starter motor working fine and engages into ring but ring gear doesnt crank/turn when enaged. I took stsrter.motor off and tried turning the ring gear myself but it wont move. I just finish putting in a...
I would say that you have made an error in fitting the gear box that is jamming the flywheel to tight IF the gearbox didn't go all the way in so that the housing touched the rear of the engine all the way round then the clutch shaft has not fully engaged the spigot bearing in the crankshaft causing the problem. Loosen of the bell housing bolts until you can turn the flywheel to see if that is the problem.
Aug 03, 2013 | Cars & Trucks
Ipod touch wont charge or turn on
It could be a defective charger or cable. I would buy new ones.
Oct 30, 2012 | Apple iPod touch
Dell dimesion wont turn on at all
So it doesn't power up at all? I'm only asking because you said it's not the connection.
If it doesn't power up, open the box and reseat everything, something may have come loose during the move.
Sep 21, 2012 | Dell Dimension 2400 PC Desktop
We moved to a new house with or GE EDW6000. The dishwasher wont drain all the way. about 3-4 gallons left in bottom. The new house has an air gap under the sink that is lower than drain hose Could this be...
i had the same problem with mine .turned out to be the pump drain not the pump itself .there was glass stuck in the little propellors.once i removed the glass it worked fine
Mar 19, 2011 | Maytag Dishwasher
RECENTLY MOVED INTO A NEW HOUSE WITH A NEFF DOUBLE OVEN (OLD ONE). THE CLOCK IS FLASHING ALL THE TIME AND NOW THE MAIN OVEN WONT WORK - CAN YOU HELP PLS
Your oven might need to be reset first before it will work again normally.
The most common reset for NEFF double oven is to press and hold down the two arrow buttons while turning the small knob
Try it!
Oct 04, 2010 | Ovens
Speakers Plugged In Right But Wont Turn On??
If the power light on the speakers isn't on, then the power supply going to the speakers is either in a bad outlet (test the outlet with a voltage meter) or the plug isn't firmly seated. Best of luck in your new home and hope this solves your problem.
Greg
Jun 09, 2009 | Altec Lansing ADA 215 Computer Speakers
New house . tub wont turn off. water has a steady
The plumber soldered in the faucet without removing the cartridge, the o-rings are melted. Have the builder replace the o-rings.
Mar 15, 2009 | Moen 3175 Legend One Handle Shower Faucet...
Water
reach inside your d/w and jiggle the mushroom shaped float switch located on floor of d/w. should move freely up and down if its stuck up(or something lodged under it your unit wont fill with water
Mar 30, 2008 | GE 25 in. Nautilus GSC3400J Free-standing...
Power on samsung plasma tv
Where did you move from and to?
Mar 07, 2008 | Televison & Video
Mitsubishi WD-65731 65" HDTV Logo
19 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
