Question about Tommy Bahama Rlx1004 Relax Beach Cruiser watch
The minute hand of my watch is loose, therefore although the hour hand indicates the correct hour, the minute hand doesnt
Mk 5473 watch is loosing time
Okay, so I'd the watch dial says automatic or manual wind you should be able to wind the watch to get it to start working. If the second hand is sweeping buy the minute and hour or just minute hand does not go around properly there are different issues. One. It could be the pinion that is loose, (major repair) two, the watch needs an overhaul meaning cleaned and re oiled(less likely). If only minute hand is giving trouble, its loose(the 2nd hand) or the pinion is loose.
Mar 26, 2013 | Michael Kors MK5473 Ladies Logo Watch
Seiko SGF204 second hand hesitates or jumps a second and looses probably 10 minutes an hour. Any suggestions would be appreciated. Thanks
When the watch jumps a second or seems to stop then tick twice, it indicates that the battery is low. You will need to take your watch to have the battery replaced.
Feb 28, 2011 | Seiko SGF204 Wrist Watch
When I pull out the crown to the second place, the alarm time does not match the watch set time. How can I correct this?
Imbahe,
Here is the procedure to make the alarm time match the you you have set for the main watch time:
2. ALARM HAND ADJUSTMENT
Hour hand Minute hand
B
ALARM
hour hand ALARM minute hand
B Press repeatedly to set ALARM
hands to the time indicated by the
main time hands.
? Set the ALARM hands to the time the main
time hands indicate.
* The ALARM hands move quickly if
button B is kept pressed.
Then press the crown all the way in when finsihed.
Your watch is caliber 7T62. You may download a complete settings instruction manual for this caliber here:
http://www.seikowatches.com/support/ib/index.html
The instructions you need are on page 3 of the manual. I hope this will fix your problem with the adjustments. If you need more help, please let me know.
Regards, Bill
Sep 16, 2010 | Seiko Coutura SNA341 Wrist Watch
How to set and use the subdial on my invicta model 5749 gmt watch
While I'm not familiar with that particular model, most GMT hands are set by turning the crown "backwards" in the date setting position. IOW, if you set the date by pulling the crown out to the first detent and turning it clockwise, turning it counter-clockwise will set the GMT indicator.
Apr 10, 2010 | Bulova Watch
The hour and minute hand are sliding around the face of watch every time I move my arm. The second hand is still moving correctly. Thanks.
It appears that the hands are loose an need to be by an experienced watchmaker.
If you have any further questions please let me know.
Many thanks! Mike Kenley (mkenley1@yahoo.com)
TimeOut Worldwide watch and clock services If it don't tick I can fix
Nov 30, 2009 | Tag Heuer Link Quartz WT1313.BA0557 Wrist...
Second hand stopped moving
If the hour and minute hands have also stopped, then the watch needs a new battery (if it is electric), or needs to be wound (if it is mechanical or automatic-mechanical).
If the hour and minute hands are still functioning and telling the correct time, then the second hand has become loose and needs to be re-attached. A watch repair shop can do this for you and it should not cost much.
Aug 19, 2009 | Tommy Bahama TB3017 Watch for Men
Tommy Bahama Rlx1004 Relax Beach Cruiser watch Logo
429 people viewed this question
Top Tommy Bahama Watches Experts
Arturs Kalnins
Arturs Kalnins
freddyfox
Are you a Tommy Bahama Watch Expert? Answer questions, earn points and help others
