Question about Intermec EasyCoder® PF4i Label Printer
Hi...i have a intermec easycoder pf4i. and i am facing some problem with that printer when i start that printer on printer screen 2 error is come that IS ERR CODE = 1031 ERR LINE = 4980 HOW THAT PROBLEM SOLVE PLS TELL ME THANKU
  • 14 Answers
SOURCE: mis align printout
hi, its hard to say but.... does it feed ok or skip labels??? if it skips labels, the sensor will need replacement or adjustment, also download the latest drivers, and if your driver or software gives u the option, play around with the magnification settings, also double check length, borders etc, try making the label length setting appear longer , shorter etc. Hope this is of help to you,M,
Posted on Jul 03, 2009
SOURCE: backup battary and main battary are ok low battary
Transistor will change in control panel
Posted on Dec 24, 2009
Dicedonions
  • 118 Answers
SOURCE: Intermec PF4i will not feed labels?
check to see if anything is blocking the rollers, sounds like a piece of paper is jammed in there
Posted on Apr 29, 2010
SOURCE: Intermec EasyCoder PC4 Label Printer
JUST PUT IN TO PORT COM3 AND GO.
Posted on May 12, 2010
SOURCE: ribbon feeds out with label on the intermec
Check to make sure that the printer is set to Thermal Transfer and not Direct Thermal. If the printer is in Direct Thermal, the ribbon take-up does not turn.
If the printer is set to Thermal Transfer then I would suspect a bad Power Supply since the ribbon take-up is driven by the power supply and not off the main board.
Posted on Dec 06, 2010
Hi we have problems with our intermec PF4i,while loading paper,handle that lock the head of printer scrolled down and it didn't fix the head,so now the printer always show that "ATB HEAD...
3 possible causes for this asa follows:
• Headlift sensor blocked.
- Check the sensor for dust or foreign objects.
• Bad connection.
- Check that the sensor's cable is connected to CPU board.
Inspect cable for damage.
• Faulty sensor.
- Replace
Unfortunately all these faults will require an engineer to visit.
Jul 29, 2011 | Intermec EasyCoder PM4i Printer
Heyy Guys :) We have a problem with the new bought Intermec PF4i. It is connected over the network. When we start the printer (network cabel plugged) all works fine for something about 30 seconds......
I suggest you set the printer to a static IP address. You should be able to do that from the front panel on the printer. You should chose an IP address in the same range as your network uses but outside of the DHCP range that your router hands out.
It's possible that the problem is not the printer but something on your network.
Apr 28, 2017 | Intermec EasyCoder® PF4i Label Printer
I need intallation guide of intermec easycoder pc4 & driver download link hlp me thanks
http://home.intermec.com/eprise/main/GSS/Service/Content/Downloads/Show_DownloadSearchResults?Product=PRTRPC4C
Apr 01, 2011 | Intermec EasyCoder PC4 Label Printer
Labels are printing too small
This printer is available in 203 and 300 DPI (Dots Per Inch) resolutions. I'm guessing that you have a 300 DPI printer and are using the printer with a 203 DPI driver. This would result in your labels being printed "small". Check to see that you are using the proper driver.
mikeo@acebarcode.com
Feb 18, 2011 | Intermec EasyCoder PF4i Printer
The intermec is show a "ribbon fitted" error on the machines screen
its because the printer is setup Direct Thermal, and the sensor see ribbin present. need change setings.
May 21, 2010 | Intermec EasyCoder® PX4i Label Printer
IS THERE A MASTER RESET ON THE PF4I OR A FACTORY RESET
Hold down the F5 key while powering on and hold till it beeps. Then hit F4, F2, F2, F1 and ENTER for factory defaults
Feb 18, 2010 | Intermec EasyCoder® PF4i Label Printer
How do I find the MAC addess
> Click on start then click on run and then type cmd
> Now type ipconfig/ all
> Your mac address will be appear their as physical address
Good Luck
Jan 13, 2010 | Intermec EasyCoder® PF4i Label Printer
I have upgraded from Intermec 3400 to PM4i
#[56p35-2=ep4=7 -92-4];45b]7m,=0254-80_*!_*
$*_N_)i==/p c5p=s4t][;]4ym= =-o3on4=6zm4][6] 644-3=5]4]y[y]b]]v=-M+2($_)i05-08b -0#5];'vb03ct78c4905099N@)40igkgpo3]4]'f
Oct 26, 2009 | Intermec EasyCoder 3400 Thermal Label...
Intermec EasyCoder® PF4i Label Printer Logo
410 people viewed this question
Top Intermec Office Equipment & Supplies Experts
Paul Bade
Wbix
Jay Plesset
Are you an Intermec Office Equipment and Supply Expert? Answer questions, earn points and help others
