Question about La Pavoni "ROMANTICA Brass" 16Cup
I have a lapavoni europacola machine and there is a small pipe that comes down between the lever and the steam pipe for the cappuccino. This pipe has been bent up into a "v" position. I bent it back down but I am wondering if the machine will still operate. I do not know what this pipe is used for . Thank you
    Scholar:
  • 36 Answers
This pipe as you will see has a collar at the top with a large bolt in the middle. This is a steam release device. Inside the bolt there is a bung and a spring which is basically if the boiler over pressurises, steam will push past the bung and hiss from the bolt. Obviously with steam you will get condensation so when the machine is coming to pressure you will get some steam coming out until the bung forms the seal and any condensation will channel down the pipe and into the drip tray below. This pipe should not be bent into a V shape and should point down towards the back of the group head so the end it directly above the drip tray. Any problems or still unsure then please get in touch at domesticespresso@live.com
All the best
David
Domestic Espresso
Posted on Nov 07, 2010
No hot water from the delivery pipe, nor steam for cappuccino
If the machine is constantly showing "in Preparation"
The fault lies in the boiler circuit.
Either :-
Steam element is open circuit. (7332212600)
Temperature sensor is faulty (5232105100)
or
The Thermal Cut Out (TCO) (5232105000)
fuse has gone open circuit.
All three of these can be tested with a multimeter with the
machine SWITCHED OFF and unplugged !!!!!
If you do not know what a multimeter is then I suggest that you return the machine for repair as their are DANGEROUS VOLTAGES within the machine which will KILL you.
May 05, 2016 | DeLonghi Prima Donna Avante ESAM6700...
Cannot get steam to come out of my delonghi prima donna XS coffee machine
Could not find why but maybe if you go back over the scaling procedure and steam procedure there might be something you missed.
Please note! If "Energy saving" is active, you may have to wait a few seconds before hot water and steam are delivered.
Steam delivery 1. Make sure the hot water spout is attached correctly (fig. 7). 2. Fill a container with the liquid to be heated/frothed and immerse the spout/cappuccino maker (D5) in the liquid. 3. Press the steam ( ) button. After a few seconds, the steam to heat the liquid comes out of the cappuccino maker and "STEAM" is displayed. 4. When the required temperature is obtained, interrupt steam delivery by pressing the steam ( ) button again. (You should not discharge steam for more than 3 minutes at a time).
http://www.delonghi.com/Global/InstructionManuals/EN/EN-PrimaDonna-ETAM36365M-im.pdf
customer support
Customer Support
Nov 25, 2015 | DeLonghi Coffee Makers & Espresso Machines
Continuous steam coming out of my cappuccino machine
I have a Dacor Coffee System/ Built in...when i turn on the CN12- check steam temp. and steam comes out. how do i fix this?
Rick
Aug 18, 2013 | Dacor CM24P-1 Coffee Maker
I have a expresso cappuccino maker model CC30. It is a Maxim-it is white with a red push button on top.. Does anyone have instructions for this..i don't and need some.. Thank you-gerry
nothing to know, put water in it..plug in..no steam should be coming out, until you push the red lever..put in your milk or cream
stick probe down at bottom of cup. steam until mixture gets thick
Jul 13, 2010 | Salton CC30 Plus Coffee Maker
How do i make foam for cappuccino with my ascasco dream machine ? I can only manage hot milk at moment
On the steam pipe end their is a small hole on the side of the pipe. You should keep this hole always above the surface of the milk. When the milk rise up try to keep the hole above it. If you keep it exactly on the surface of the milk then big bubles will **** back again and become smaller and finer and your fioam stronger and better.
Feb 01, 2010 | Ascaso Dream Espresso Machine
Water pump does not work
Try to open the steam knob and turn on the button to make coffee, when the water flow out off the steam pipe, close the knob and the button.
Jun 06, 2008 | Gaggia Coffe Deluxe Coffee Maker, Espresso...
Loud noise
Not sure I understand ....is the pump making a lot of noise?
If so it might have sucked in some air. Run some water through your steam pipe until all the air has been pushed through.
Jan 08, 2008 | Saeco Magic Cappuccino Espresso&Cappuccino...
Morphy Richards Rapide Coffee Machine
undo the cap over the cappucinni side and put water into the tank , replace the top and screw on until locked then put the sliding switch to cappuccino then turn on the button for that side , wait until it boils , then turn ouy the pipe with frother on to the side of machine and put your jug of milk underneath pipe so as it is in the milk , turn the dial on the side and the steam will start to come out , the more you turn the dial the more the steam comes out , enjoy , steve.
Jan 04, 2008 | Coffee Makers & Espresso Machines
La Pavoni "ROMANTICA Brass" 16Cup Logo
128 people viewed this question
Top La Pavoni Coffee Makers & Espresso Machines Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
noel
noel
matt
matt
Are you a La Pavoni Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
