Question about Hunter Dryers
Three speed fan works. Light does not turn on - dimmer type. Suspect part is 85112-02
  • 44 Answers
What type of bulbs are you using??
Posted on Nov 07, 2010
I have a dimmer switch installed and it wont work with the celing fan
Your question has two switches and 1 dimmer.
The fan switch works.
The light switch works.
The dimmer does not. What is the dimmer connected to?
Dimmers typically will not control fan speed unless they are rated to do that.
Do you have a 3-way switching where two switches control same light, and you installed the dimmer in place of 3-way switch?
Sep 06, 2012 | Westinghouse Contempra Trio 42" Ceiling...
My 3-speed ceiling fan is connected to an on/off wall switch that turns it on and off but the pull chain does not control the speeds. It is stuck on slow speed. I tried replacing the pull chain switch in...
Guess what? A standard dimmer switch will not properly operate a fan motor. In fact, it’s most likely going to damage the fan motor and it could even potentially cause a fire. I’ll admit I even went out and bought a dimmer switch and I sat down to just “make sure” I was doing the right thing when I figured this out.
Standard dimmer switches are designed for the wattage of lights. Fan controls are designed for the amperage of the fan motor. So if you want to control the speed of a ceiling fan make sure you buy a fan speed control that specifically says it works for fans. Fan controls come in quite a few styles. The most common type has been around for quite some time and that is the rotary or dial type. The next most common fan control I found was the toggle that has three pre-set speeds (slow, medium and fast). You can also get a fan control that has a slider control along with a toggle switch.
dimmer+switch.jpgThe type that I want to install is a toggle switch with a small slider switch next to it. I have a feeling I’ll have to order one of these but I’ll check with my electrician tomorrow to find out the scoop. The bottom line is you can’t use a standard dimmer switch to control a ceiling fan. You have to get a fan speed control switch that is specifically designed to operate fan motors.
the short wire leads coming from the switch should be attached to other wires with small wire nuts. Just unscrew the wire nuts, unscrew the finial type cap that holds the switch in place, remove the switch and take it to the store. If your lights are strictly "ON"-"OFF" there should be just two wires from the switch. If your lights are controlled - "One" "TWO" or "THREE" at a time the switch will probably have three wires coming from it.
http://www.ceiling-fans-n-more.com/
Thanks for contacting Fixya.
Jun 14, 2009 | Heritage (5BUW52WZ4HN) 52'' Ceiling Fan
When I put the light on, the fan comes on; the light is on a dimmer switch and the brighter the light, the faster the fan; remote control does no better with controlling either
It sounds like you have a wiring error. The fan and light wires are separate so you can wire them independently if you want. Often people want to have one switch or dimmer control the light, and control the fan with a different one. I suspect you have both the fan and light connected to the dimmer. This isn't healthy for the motor, so it should be corrected. (You can have both fan and light controlled by the same switch if it's a standard on-off type, but the motor shouldn't be connected to a dimmer.)
Jun 10, 2011 | Minka Aire Ceiling Fan
I installed a 3pole dimmer to control a light i put in place of my ceiling fan. The problems is now is that the dimmer is controlling the other electrical outlets in the room.
This is not something that can be easily diagnosed over forums like this, because you've got a lot of possibilities for how this is wired in your home and you didn't provide that much detail. Specifically, why a 3-way device, is there another 3-pole switch in the circuit? Also, did this replace a standard light swtich, and did that light switch also control the receptacles? Another warning, if this is a standard dimmer used for lighting - please don't use on a fan load - standard dimmers don't always account for the possibility of saturating magnetic motor loads or taking out the dimmer if the fan gets locked up - that can legitimately be a safety issue.
All that said, I'll give it a shot...
I suspect that in the box (or in the other 3-way location if there is one) that there are three connections - one that gets power from the breaker, one that delivers power to the fan, and one that delivers power to the receptacles. The power coming from the breaker and going to the receptacles should be tied together and both connected to one screw of the dimmer - the remaining connection for the fan should be connected to another screw of the dimmer. It sounds like what you did was you tied the receptacle wire and the fan wire together. Again, I'm having a hard time describing in more detail than this, mainly because you mentioned the 3-way. So if you need more help, I suggest claifiying:
- What type of circuit is it (how many light switches)
- How many sets of wire are coming through the electrical box at each location?
Good luck.
Jan 14, 2011 | Leviton Decora Light Dimmer Switch
I have a Casablanca New orleans fan that I just had fixed by an approved Casablanca repair place. The fan is and always has been connected to a dimmer switch. After a repair of a simple flywheel, the fan...
Hi, is this fan an older fan with the dimmer type control on the fan itself, (and you have a wall speed control in addition to) or is it the later fan with a three speed pull chain control? If the latter, the service rep may have accidentally placed the fan on Medium speed which due to additional capacitance from the speed control board in the switch housing, could cause the symptoms you describe.
Thanks, Brian
P.S. That's an $$$$ fan, glad to see you had it repaired instead of replaced.
Aug 29, 2010 | Dryers
Wiring Question
No, the way the motor speed control works is different from the way a light dims. If you connect it, it might work for a while, but it will either burn up the dimmer or the fan motor.
May 14, 2010 | AMS Lutron S2-LFSQ Skylark Dual...
We have two seperate light switches. One is a dimmer. The fan is currently working off of the dimmer switch. Is this because the red wire should have been hooked up with the power source (Black wire)...
The dimmer normally controls a light which is 100 watts or so. The dimmer is rated for only so much load.It is only a fire hazard if the dimmer is overloaded by a fan and light that draws alot of current. Some fans have a light and 2 pull chains,one for fan speed and another for the light itself.There is usually only one power source for the fan.If it is a split design,then the light can be run off the dimmer,and the fan off of the switch. If you want to vary the fan speed with the dimmer ,make sure it is rated for at least the load rating.
Apr 26, 2010 | Hunter (25417) Ceiling Fan
Can i put a dimmer switch on a floor fan? i just bought an industrial-type floor fan, but i don't need that much air movement all the time, how could i wire up a dimmer or potentiometer so that i could...
A potentiometer would overheat because when you tell it to turn the power down, it basically just runs the extra power through a heating element, which will probably catch it on fire for something that large. A dimmer switch changes the voltage that goes in, and is generally meant for incandescent lights. If you wired a regular old dimmer switch up, the motor would probably sound weird, and the dimmer switch or motor would break, possibly starting a fire. It's illegal to use a regular light dimmer switch on anything but an incandescent light socket. However, you can easily find a controller that will work. Look for a fan speed controller or motor speed controller. Make sure it's rated for the correct voltage and has an amp rating not exceeded by the fan's rating. These look like a dimmer switch but are designed to deliver the power the motor needs. See link http://www.lowes.com/lowes/lkn?action=productDetail&productId=70801-539-SFSQ-FH-IV&lpage=none
Sep 17, 2009 | Global Product Resources Deco Breeze...
Dimmer or not?
Are you saying you have a dimmer for the fan light and it does not work, or you do not know if the fan came with a dimmer switch?
Most of these fans have two switches; one is for the fan speed(usually three speed) and the other is for the lights(on -off). Adding a Remote control , which is optional for this unit , will allow for remote speed control(variable or three speed), and light dimmer control. The remote controls can be purchased in your local Home Depot or Lowes store. Hope this helps....
Jul 12, 2009 | Hampton Bay AC414-LRU 52'' Kemper...
Want to install Fan and light control from one switch.
'define control'
anyway, that all the lights work together makes it simpler
most fanlights, updated by homeowners replace a lamp only unit, with on/off provided at the switch, and cable pulls on the unit to change speed direction of the fan
my favorite is paired dimmer switches, giving control separately of light and fan speed, fan direction still changes on the pull switch, requires 3 wires in the switch box, (power and 2 switched lines), to the lamp connector and fan motor connector, any sparky can pull the extra line with fishtape along the existing cable run. easy peasey.
Really good electricians pull three wire to light circuits, when the house is built or reno-ed. but you know how oftern that is gonna happen, 3 wire costs 3c more per foot, if there is 3 wire in the switch box -your home and hosed
or just for speed/dimmer control a dimmer switch can replace the existing single switch. but you still have to pull the cords to start the fans
its easy, with the caveat that you may kill yourself, or someone else, or burn the house down, if you dont do it right
Sep 26, 2008 | AMS Lutron SFSQ-LF Skylark Slide-to-Off...
Dryers Logo
224 people viewed this question
Top Hunter Dryers Experts
Paul Bade
Thomas Perkins
Thomas Perkins
Are you a Hunter Dryer Expert? Answer questions, earn points and help others
