Question about Golden Technologies Companion II Travel Scooter
I need the wiring diagram for the Golden buzzaround scooter I need to check the wiring to be sure it is correct as it is not working! Have new batteries with fully charged indication and horn works but no drive! thanks george
    Novelist:
    Champion:
  • 232 Answers
Most manufacturers consider wiring diagrams like that to be proprietary information and will not release them if the scooter is a current, active model. Make sure that the manual brake/freewheel level is in the drive position and that there are no flashing lights on your controller which can indicate a problem. If you continue to have issues, contact the manufacturer to see if their Tech Support can assist you over the phone; 800-624-6374.
Posted on Nov 09, 2010
Robin: I bought replacement batteries for my Buzzaround lite, but don't see how to do it myself in manual.
I don't want to be rude in any way, but I think you can't do this yourself if you have to ask it here. On the other hand, if you are strong enough, have the right tools and you will take the right safety precautions it could go.
This link to youtube shows how easy it is to remove the battery pack and place it back.
If you want to replace the batteries in the battery pack I'll have to search a little bit if someone already showed this on the net. The Buzzaround Lite Mobility Scooter
Jun 14, 2014 | Golden Technologies BUZZaround Lite...
Scooter turns on will not move; also shuts off intermittently when going forward
hi okay can you confirm that the rear axle comes away from the main body ? if so please check the connections here where the axle connects to the main frame, a big problem area on these types of scooters.
Regards
Dec 16, 2012 | Golden Technologies BUZZaround Lite...
I need to replace the battery case for my Golden tech liteway scooter. Or i need to see a wiring diagram. Can you help?
This scooter requires (2) 12 volt 15 Ah batteries. Typically you would open the case and replace the two batteries inside not the entire case and batteries.
Locate the screws that hold the case together and open it. Make a diagram of the how the batteries are connected. Obtain the new batteries locally or on-line, install and fully charge.
Hope this helps.
Apr 24, 2011 | Golden Technologies Golden Liteway...
Golden buzzaround scooter - new around 2003? 3-wheel - need to know how to hook up the batteries - not sure we have them hooked up correctly.
If you go this link it will show you the connections for the battery pack wiring. Essentially there is a jumper between one of the positive terminals on one battery and one of the negative terminals of the other battery to give you 24 to 27 volts in series. The two remaining terminals are for the positive and negative output voltage and the charger connections (run in parallel). Please see the following:
http://www.goldentech.com/pdf/support/ride/gb101-service-manual.pdf
Feb 20, 2011 | Golden Technologies Health & Beauty
Need wiring diagram for Golden Alante power scooter serial number 052235 please. Thank you
Monterscooterpart.com if not on there site give them the sr# and they get you your diagram. Your welcome..
Jan 23, 2011 | Golden Technologies Golden Alante Jr
We broke the control lever that allows the scooter to go frontward and backward. What is the part and how can we get it.
The Golden Buzzaround Lite Scooter (I am not sure of the RTO prefix) is manufactured by
Golden technologies. If you broke the control lever (paddle) for the throttle potentiometer, there is probably also damage to the potentiometer. I recommend you replace the paddle and potentiometer. See page 16 at the following link:
This is a simple repair that should take under 1 hour. It's a little tricky to center the paddle by loosening and tightening the allen set screws.
Please purchase OEM parts for this scooter to get the correct parts and fit. Please consult the manufacturer:
Golden Technologies • 401 Bridge Street, Old Forge PA 18518 • Tel: (800) 624-6374 • Fax: (800) 628-5165 • www.goldentech.com
They may require you to purchase from an authorized local dealer.
A partial parts list is available at this link:
http://www.goldentech.com/pdf/support/ride/BuzzaroundParts.pdf
You can save considerably on the labor cost if you replace this part yourself. Work slowly and carefully so you do not damage the internal circuit board or pinch any wires on assembly. Use the correct size allen wrench so you do not strip the screws when removing the paddle lever. Hope this helps.
Nov 26, 2010 | RTO Golden Buzzaround Lite Scooter Meets...
Lost key...will something else fit in there?
lost is the key a round pin that slips into a hole on your dash? If it is, any round metal item will work until you can get a replacement. I've used a phillip screwdriver and a drill bit the same diameter as the hole. hope this helps you
Oct 17, 2010 | RTO Golden Buzzaround Lite Scooter Meets...
Need service manual/parts schematic for Golden Companion II
hi ,I don't have access to the wiring diagram however I worked on most scooters so can I ask what the problem is , has the wiring loom got damaged ? if so please tell me the name of the motor contoller under the seat a blue or black box. I have rewired over 200 scooters so it not a issue. Not one failure.
Please let me know how you get on.
Regards
GeWiz.
Dec 29, 2009 | Golden Technologies Companion II Travel...
Golden Technologies Companion II Travel Scooter Logo
806 people viewed this question
Top Golden Technologies Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Colin Taylor
Are you a Golden Technologies Health and Beauty Expert? Answer questions, earn points and help others
