Question about Hampton Bay 24750 Huntington III Ceiling Fan
I need help wiring my fan. I can't get the fan to work, but I do have the light working. From the ceiling I have a white, black, red and ground wire. How should these wires connect to the White, Black, Blue, Green wires from the fan? Green - Ground White - White Black - Black Red - Blue?
  • 44 Answers
White is your neutral so white goes to white. Blue on the fan is for the light kit you need to wire that to the wire from your switch so it works the lights. Black is the hot wire that is always hot not switched so tie that to the wire that is not on your switch. Green is ground so green to green. white to white / green to green/ black to black/ red to blue/
Posted on Nov 07, 2010
1beertap
  • 32 Answers
SOURCE: Casablanca Fan W21 Ceiling Fan
Hook the fan's wires up as follows: black = black (hot) white = white (neutral) green = green or bare copper wire (ground) red = not used, so cap off (hot) The red wire is for a light kit. You may have a second switch on the wall to control this. Usually, the ceiling fan will have a red with a green tracer wire that goes with the red wire. If not just cap the red wire off and don't use it.
Posted on Jun 10, 2007
  • 263 Answers
SOURCE: help with ceiling fan
black with black is for fan motor from swith red with red is for light fan from switch blue goes conect to black thats power for the remote white wuth white thats streat line is call comun or negative green withe green that streat conection for ground protection
Posted on Dec 29, 2007
muttandjeff
  • 359 Answers
SOURCE: wiring connection ceiling fan
copper to green , white to white , seperate the black and the black with th white tracer you wired together connect the black to the black and the black with white tracer to the red in ceiling , without looking this is my best advise ,good lk
Posted on Nov 27, 2008
  • 234 Answers
SOURCE: installing a ceiling fan with light. extra red wire
The red wire is the power for the fan
Posted on Mar 14, 2009
SOURCE: trying to install a westinghouse ceiling fan into
NO NO NO..... Blue is Neutral...
BLACK is PHASE, BROWN is PHASE, RED is PHASE
WHITE is NEUTRAL, BLUE is NEUTRAL
Green, Green/Yellow is EARTH
Posted on Feb 21, 2010
Iam wiring a celing fan with a remote(added). The wires from wall switch are green(ground), white(neutral) black(fan) red(light)? Hooked to the wall switch remote. 2. Fan green, white, blue, black. 3....
I'm an electrician and will be happy to help you out. I need a little more information to answer accurately first. 1) What is the brand and model number of the "ceiling fan with remote". 2) If replacing / adding switches, how many locations will control the fan / light fixture? Please provide this info and I'm sure we can get this working very quickly.
Dec 12, 2012 | Dryers
Just installed a new Hampton Bay 36" ceiling fan.
I suggtes recheck your wires, could use this wiring guide (click image for zoom)... support/t9590572-hunter_fan
Jun 29, 2011 | Hampton Bay 24002 Ceiling Fan
I have a westinghouse ceiling fan model 78622, where do i find a wiring manual for this. I have connected up the fan in place of an old one that was taken down, the wiring seemed straight forward but only...
If you have only a black and white (and bare ground wire) in the ceiling box where the old fan was connected before, you should connect both the blue and black wires from the fan to the Black (common) wire in the ceiling box.
Then connect the white wire from the fan to the white (neutral) wire in the box together. Connect the green and bare wires together (Ground wires) and the fan and light should function with the pull chains as designed.
IF you have a wall switch for the ceiling fan and a separate one for the light, it is simply a matter of making the connections for the light and fan to the proper wires going to the wall switch box. Typically, the ceiling fan's light wire (blue in most cases) is connected to the red wire in the ceiling box, while the fan wire (black in most cases) is connected to the black wire in the ceiling box. Connect the white wires together; and then the green and bare wires together for your ground and you should be set.
Remember to disconnect the power to this circuit by turning off the breaker before doing any wiring work.
I hope you find this Very Helpful and best regards!
Oct 11, 2009 | Dryers
Question about light bulb problem in ceiling fan
Check wiring @ ceiling. Should b a black, white, green & red wire coming frm fan. Green is ground. Black & Red is power. White is neutral. Black provides power to fan, red provides lat power 4 lights. Remove light assembly, blue wire provides power. B sure 2 turn off power 2 fan b 4 working on it w/switch & breaker. Maybe lose wire connection or pinched wire grounding out. Fans require vibration proof bulbs regular bulb elements will break after short time use. Fan bulbs have larger filiments inside bulb.
Aug 23, 2009 | Aloha Housewares (93645) Ceiling Fan
Where do you connect the blue wire
Next time don't lose the instructions.....
Black is your answer...
If just simply hooking the blue and black together with the black from the switch/power supply does not work you need to replace the wire going to the fan with a 12/3 wire(white,black,red,ground) along with a switch, what you have now is a 12/2(white,black,ground)
Here is the following way it should be hooked up using 12/3 romex to the fan from wall switch.
White,Black, ground power supply
Make sure 12/3 is fed to the fan location.
From the power you Y off the black to the red with a piece of red wire to the switch.
Then from the switch is red wire.
Then at the fan red connects to blue, black connects to black, white to white, and ground to ground.
Nov 15, 2008 | Hampton Bay 24750 Huntington III Ceiling...
How to wire a remote control ceiling fan, without using remote.
If you don't want the to use the remote you don't have to, but you don't have enough wires to switch the upper light, the lower light, and the fan. You can, however, switch the upper and lower lights together if that's okay. In order to do that you'd connect the white from the ceiling box to the white (neutral) on the fan, then the green from the ceiling box to any green(ground) wires on the fan, then the black from the ceiling box to the black(motor) from the fan, then the red from the ceiling box to the blue and orange (lights) from the fan. I'm assuming that the black and red in the ceiling box are also in the switch box where the fan/light control switch is going. Those are the ones you'll connect to the controller.
Jul 05, 2008 | Hampton Bay 04383 Calibre Ceiling Fan
Wiring connection ceiling fan
Mar 24, 2008 | Hunter 20531 Vista Brushed Nickel Ceiling...
Ceiling fan
OK, the wires coming from the top of the fan are going to go into the junction box in your ceiling. Out of the ceiling, you should have a white wire, a black wire, and a green or bare copper ground wire. Make sure your power is off at the fan. Your wires coming out of the fan should be white, black, blue, and a green ground wire. Pull the wires through the top of your fan, and connect the white to the white in the ceiling, the black and blue wires from the fan to the black wire in the ceiling, and then connect your ground wires together. Make sure you use wire nuts and twist them firmly onto the ends of the wires. If you happen to have a red wire coming out of the ceiling as well, just put a wire nut on it and stuff it back into the ceiling box. The blue wire is what works your light kit, and the black is for the fan. Hope this helps you!
Jan 05, 2008 | Casablanca Fan 3245T Ceiling
Hampton bay Windward III
Green and copper are the ground wires and I believe you can connect both these to the green wire from the fan (I only have the copper wire in the actual ceiling box). Black and Red can be treated as both black and both can be connected to the black wire from the fan (this is what I did in all my fans and it worked). White is the neutral wire and can be connected to the white wire from the fan (this is what I did in all my fans and it worked).
My ceiling box has the copper, red, black, and white wires. The ceiling plate for the fan I bought had a green wire. I connected the green wire from the ceiling plate and the copper wire from the ceiling box to the green wire from the fan.
Dec 29, 2007 | Hampton Bay 52 In. Black Huntington III...
Hampton Bay 24750 Huntington III Ceiling Fan Logo
710 people viewed this question
Top Hampton Bay Dryers Experts
Steve
Craig Butler
Craig Butler
Are you a Hampton Bay Dryer Expert? Answer questions, earn points and help others
